Pavilion DM1 screen issue
stuartadair
PostPosted: 10:50 - 06 May 2012    Post subject: Pavilion DM1 screen issue Reply with quote
Hello all,
HP Pavilion dm1 was working fine. Turned it on a couple of days ago and the screen display was just blue lines. Moved the screen up and down and the picture came back, then went again. Now its split, the left 50% is grey an the right 50% is white. No issue using an external screen.
No loose wires so suspect either the motherboard - screen cable, or screen itself. It looks like the inverter is integral into the screen. Any thoughts ?
Stu
boundy
PostPosted: 17:07 - 06 May 2012    Post subject: Re: Pavilion DM1 screen issue Reply with quote
stuartadair wrote:
Hello all,
Stu
Had the same issue on the Wifes Compaq, it was a broken wire at the hinge leading to the screen, it was well hidden under the fabric tape that holds the wires togeather. Used some wire and patched it up.
stuartadair
PostPosted: 17:10 - 06 May 2012    Post subject: Reply with quote
Hi Thanks for the reply
I've been doing some more research on the web and it looks like its quite a common fault with the screen packing up. The action of moving it around makes it work for a short while before it dies completely. So, I've ordered a new screen. However, whilst I've got it apart I'll check the cable too.
boundy
PostPosted: 17:16 - 06 May 2012    Post subject: Reply with quote
Not sure why you would order a new screen before checking its not as simple as a broken wire.
stuartadair
PostPosted: 17:18 - 06 May 2012    Post subject: Reply with quote
Well... I ordered the screen before you replied, so too late to cancel it now.
boundy
PostPosted: 17:25 - 06 May 2012    Post subject: Reply with quote
Ahh well, hopefully it turns out to be a broken wire and you can fix it for free and return the screen.
The last post was made 13 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 47.56 Kb
