solved: grinding sound from rectifier
U_W v2.0
PostPosted: 08:09 - 07 May 2012    Post subject: solved: grinding sound from rectifier Reply with quote
new here, first time post and in need of some help Smile
i have a huoniao HN125-8 125cc motorcylce and i removed the left and right switches to install replacement switches as my headlamp main beam wasnt working but dip and possition lights where, even with a new bulb. so i thought new switches might aid in fixing that problem.
thing is, now that i've installed the new switches, my rectifier sounds like its chewing on metal with cast iron jaws!
i thought "ah bugger" so i swapped them out and stuck the old ones back on.
same thing, and to boot, this happens on the electric start, dont want to try the kick start but will if needs be. when using the electric start, all the electrics cut out for a while, presumable while the rectifier....rectifies itself after what ever is going on.
the battery has been charged and is putting out a steady 12.48v DC.
so um.....anyone have any ideas? haha.
i can post a pic of the wiring inside the headlamp (cause of the switch replacements) and a wiring schematic if it would help Smile.
thanks in advance everyone.
PostPosted: 08:18 - 07 May 2012    Post subject: Reply with quote
I never heard of a rectifier making a noise - but if I did it would be off the bike in a flash before it went up in smoke.
Are you sure it's the rectifier, not the starter solenoid?
Usher4566
Are they correct switches ? Have they been wired correct .I never thought a reg//rec could make noise
New cd200 benly owner
Usher4566
PostPosted: 08:22 - 07 May 2012    Post subject: Reply with quote
I agree pete whip it off .and yea starter solinoid can make some noise
U_W v2.0
PostPosted: 08:25 - 07 May 2012    Post subject: Reply with quote
its definatly the rectifier.
i jsut went out and checked, looking AT the rectifier at the time and the sound defo came from that and it moved like 1mm when it clicked and killed the electrics.
they're the correct switches.
only wire i wasnt sure about is a LIGHT BLUE wire for the fromt right indicator, otherwise all wired up correctly as the connectors they use will only go into the one its meant for.
PostPosted: 08:31 - 07 May 2012    Post subject: Reply with quote
Rectifiers don't click.
Let's get this straight - you push the button to start the engine and you get a click or a metallic chattering? Is so, that's the starter solenoid jumping in and out.
Check the battery terminals are tight. Make sure you don't have a small ring clamped under the main battery lead on either terminal, if they have more than one connection. Find the frame earth on the battery neutral wire and check it's tight. Do the same for the engine earth. Check the red leads onto the starter is tight.
U_W v2.0
PostPosted: 08:37 - 07 May 2012    Post subject: Reply with quote
heres a photo of the area
https://i48.tinypic.com/4hqdfk.jpg
its the bit with the 2 red wires on it that jumped and is making the noise. which according to my wiring diagram is the rectifier. although i may have miss read it because according to the diagram theres a bunch of other bits too lol
the fuse is fine btw.
i checked the battery terminals and they look fine too. also the battery ground goes directly to the engine block and thats nice and solid as well.
incase it helps, heres the wiring diagram. it seems pretty accurate for what i've observed so far Smile
thanks for all the help so far too
p.s after google imaging "motorcycle starter selenoid, your completely correct lol.
Usher4566
PostPosted: 08:54 - 07 May 2012    Post subject: Reply with quote
That's the starter solinoid
U_W v2.0
PostPosted: 08:55 - 07 May 2012    Post subject: Reply with quote
any reason why it sounds like chewing out something horrible?
U_W v2.0
PostPosted: 08:57 - 07 May 2012    Post subject: Reply with quote
never mind, loose connection.
fee like a total prat now. still im new to all this, utter noob mistake i spose, still VERY embarrased thugh
Usher4566
Pete may no why its clicking but maybe you should bump start or kick .they ushally click when stuck ? Pete ? Or battery flat.when I was youger I used to ark a screw driver across to get um going agen Pete ?
Usher4566
PostPosted: 08:59 - 07 May 2012    Post subject: Reply with quote
Have you fixed ? If so never mind because you are learning you now no what a starter solinoid looks like .reg/ rec usually have fins
U_W v2.0
PostPosted: 09:05 - 07 May 2012    Post subject: Reply with quote
yeah just had it running for a minute or two (need to adjust the idle mixture screw, doesnt like to start up properly at the moment) but had it running and no noise at all.
still, i spose gotta laugh at it lol
thanks guys! im sure i'll be back to try and fix the headlamp problem.
actually, i'll start up a new thread about that.
Usher4566
PostPosted: 09:08 - 07 May 2012    Post subject: Reply with quote
Be carefull if you start messing with mixture screws only one to fiddle with is idle screw.not air or oil mixture screws
No need to feel bad mate, we all gotta start somewhere.
No shame in not knowing, only in not trying.
Usher4566
PostPosted: 09:09 - 07 May 2012    Post subject: Reply with quote
Also at some point could you put pic of bike up am curious what one of them lookslike
U_W v2.0
PostPosted: 09:11 - 07 May 2012    Post subject: Reply with quote
https://i813.photobucket.com/albums/zz55/reeve1987/Hyrinmaru.jpg
viola
my first motorcycle Very Happy
im in the process of changing the black (including the seat) to white.
hoping this will make me more visible for night riding.
also added LED strip lights for being more visible at night and added a dimmer to them if i need to make them brighter/dimmer
https://www.youtube.com/watch?v=vr-KdsDJXSk&feature=plcp
PostPosted: 09:17 - 07 May 2012    Post subject: Reply with quote
It won't help with night visibility but it will look grubby as hell in a very short while.
Might also attract you some unwanted attention outside the Blue Oyster Club Smile
U_W v2.0
PostPosted: 09:18 - 07 May 2012    Post subject: Reply with quote
i dont know what the blue oyster club is lol
i intend on keeping it nice and clean, getting some custom made vinyl stickers for the tank to add a little colour, but not alot, they're black stencil type ones as i want to keep it simple
cb1rocket
PostPosted: 09:23 - 07 May 2012    Post subject: Reply with quote
i would leave the bike as it is, you will only make it worth less in value.
Unless its a proper airbrush chopper style graphics that cost ££££££
https://www.youtube.com/watch?v=a-xFidwDbHI
Very Happy
U_W v2.0
PostPosted: 09:26 - 07 May 2012    Post subject: Reply with quote
oh, that blue oyster bar lol.
meh doesnt bother me much haha.
karthead
PostPosted: 09:33 - 07 May 2012    Post subject: Reply with quote
Yeah he is right. At least he didn't start a thread asking if you can use a safety pin as a circlip Laughing
U_W v2.0
PostPosted: 09:36 - 07 May 2012    Post subject: Reply with quote
so not even going to ask about that lol.
its funny, i've been fixing problem after problem with this bike. only paid £200 for it though so cant complain.
had to tighten the gear change lever bolt, scrub off the indicator contacts, got the headlamp issue then this, idle speed was too high.
wonder what else this bike has in store for me haha
loving it all the way though!
Usher4566
PostPosted: 09:37 - 07 May 2012    Post subject: Reply with quote
There is one of them for sale near me for 150 make good spares
The last post was made 14 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 125.41 Kb
