So I'm changing the clutch on the Hornet...
m0l0t0v
PostPosted: 23:08 - 06 May 2012    Post subject: So I'm changing the clutch on the Hornet... Reply with quote
And I need to change the plates... there's a big locking nut which I need to get out, however... whenever you spin it the clutch case thingy spins... even in gear it basically moves the bike. So I need this Special tool which looks like it'll cost about 60 quid for something I'll use once... maybe twice in my lifetime
And I have no way of getting the bike to a garage to get it out for me, let me replace the plates and springs and put it back on for me...
So... Anyway I an somehow stop this bugger from spinning or anyone have the tool specifically?
It's a Hornet 6 98-03....
groovylee
PostPosted: 23:11 - 06 May 2012    Post subject: Reply with quote
impact driver? you know, the air powered type.
not sure if it's advisable, just a thought.
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
m0l0t0v
PostPosted: 23:13 - 06 May 2012    Post subject: Reply with quote
Actually, just looked at a website on changing something to do with the clutch and it says to use that or a breaker bar....
Anyone got one I can borrow? Razz
herulach
PostPosted: 23:21 - 06 May 2012    Post subject: Reply with quote
Everyone should have a breaker bar.
25 squids https://www.machinemart.co.uk/shop/product/details/clarke-pro230-1-2-drive-breaker-bar?da=1&TC=SRC-breaker%20bar
assuming you have 1/2" sockets job jobbed. 3/4" ones are about the same price, but really big stuff tends to need a 1/2" anyway
YBR 125>FZS600
haroman666
PostPosted: 23:26 - 06 May 2012    Post subject: Reply with quote
Got my breaker bar for £15. But that was through a cheap tool man that used to come down the garage every weds.
No idea about the nut though... Use a powered gun + socket if you can.
Or karate chop it.
m0l0t0v
PostPosted: 23:28 - 06 May 2012    Post subject: Reply with quote
Yeah I know I need to get one. Just trying not to spend so much money atm Sad
Noxious89123
PostPosted: 23:40 - 06 May 2012    Post subject: Reply with quote
Don't you need a special tool to lock the clutch so you can undo the centre nut? I've also heard something about having to "unstake" the nut? And "stake" the new nut once you've put it on a tightened it up.
It's not something I have yet ventured into myself, so am certainly not an authority on the matter.
m0l0t0v
PostPosted: 23:52 - 06 May 2012    Post subject: Reply with quote
Did you not read my first post? Saying I need this special tool?
And yes, unstaking the nut is fine. Easy job. Done that. And have a new one... easy job.
It's jut I need to remove it. But as other people have mentioned (and on other websites) I can just use an impact driver or a fat bastard and a breaker bar. So I'll probably use those as pies are cheaper than a special Honda tool which I will use once.
PostPosted: 00:06 - 07 May 2012    Post subject: Reply with quote
If you've got a decent 1/2" wrench you can usually stick a big bar on the end of it - just a piece of steel pipe or similar.
When needed, I've often used a bit of a paddock stand etc.
For a breaker bar, I'd consider getting one of those cheap 3/4" socket sets at some point. You get a breaker bar, a big beefy ratchet and sockets from 19-50mm for around £20 delivered.
If you ever end up needing a 36mm for a big rear spindle or similar you've pretty much 'broken even' and have the rest of the tools there as needed.
Obviously an air compressor and air impact wrench if you ever get the need to justify it is nice, as well as a 24v rechargeable impact wrench.
PostPosted: 08:49 - 07 May 2012    Post subject: Reply with quote
I have a 12v nut knocker, It just plugs into a lighter socket. I'm not sure if it would be powerful enough, but it works on car wheel nuts OK.
Triumph Trophy Launch Edition
Quote Me Happy
PostPosted: 09:05 - 07 May 2012    Post subject: Reply with quote
Impact wrench, has worked for me in the past.
cb1rocket
PostPosted: 10:15 - 07 May 2012    Post subject: Reply with quote
+1 12v impact wrench for removing car wheels nuts did the job, its actually very useful for undoing loads of stubborn nuts.
mine was 5 quid new from the car boot Very Happy
Ichy
PostPosted: 10:46 - 07 May 2012    Post subject: Reply with quote
I always use an air impact wrench but I did make a tool out of some old clutch plates for the CBR. Something similar to this but I used old steel plates and welded it together.
https://farm5.staticflickr.com/4007/4505212409_82f2db3233.jpg
orac
PostPosted: 12:06 - 07 May 2012    Post subject: Reply with quote
from what i understand when you turn the centre nut for the clutch it turn the rear wheel while in gear (will just turn the gearbox input shaft in nutreul. you can get over it in many ways, put in gear and have some one stand on the back break, ot at your own risk put it in gear and put a metal bar through the wheel and against the swing arm (pad with some rags or something).
on the other hand just get universal clutch holder
https://www.ebay.co.uk/itm/Sealey-Tools-VS1812-Motorcycle-Clutch-Flywheel-Pulley-Holder-Universal-Motorbike-/140666811895?pt=UK_Motorcycle_Parts&hash=item20c06535f7
Ichy
PostPosted: 12:08 - 07 May 2012    Post subject: Reply with quote
Have you used one? I'm always a bit nervous that they will break the teeth off the basket.
orac
PostPosted: 12:12 - 07 May 2012    Post subject: Reply with quote
i have, i own one, works fine. you can even mod them with a couple of wholes and bolt and use it as a fly wheel holder.
basically you use it to grasp the inner basket/drum, tighten it down with the thumb screw.
i will see if i can dig out my spare clutch and post a pic of how it goes if yal like
orac
PostPosted: 12:28 - 07 May 2012    Post subject: Reply with quote
that would stop the clutch outter from spinning, the centre nut is ona splinned shaft atatch to the centre, unless if have misunderstood something
instigator
PostPosted: 12:33 - 07 May 2012    Post subject: Reply with quote
I have a 24" breaker bar and electric impact gun that you can borrow. I'm in Ashford, right by Staines.
Either that or go to Halfords, buy breaker bar, use it then return it and say it is the wrong size or something. Refund. Thats what I did when I needed a tool to take out some valves from a cylinder head. (didnt buy either tool for that though!)
serlant
PostPosted: 12:58 - 07 May 2012    Post subject: Reply with quote
I changed the clutch on my offroader on friday, it involved me standing on the pegs, then putting one foot on the rear brake and one foot on the ratchet on the clutch nut, i then pulled myself down with the bars on the ratchet, which undid the nut while the rear brake stopped the clutch moving, make sure its in top gear aswell as it makes it easier for the rear brake to stop the wheel turning.
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
PostPosted: 13:09 - 07 May 2012    Post subject: Reply with quote
Vincent wrote:
OP, if you're just changing the plates, are you sure that you need to remove the inner hub? Or is the top cover also held on with the boss nut?
Honda clutches are generally badly designed in that manner - a chunk more hassle than others which can be done with 2 tools in a lot of cases (ie 8mm socket and 5mm allen key say).
orac
PostPosted: 13:24 - 07 May 2012    Post subject: Reply with quote
well from that exploded picture its looking like you will either have make a tool, or just use the great box and brake/something throught the wheel method
The last post was made 14 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 132.51 Kb
