Bent handlebars
Lostboy02
PostPosted: 17:39 - 07 May 2012    Post subject: Bent handlebars Reply with quote
Hi All,
Does anyone else think these bars are slightly bent, or out of line?
Or is it just my eyes playing tricks on me, one side just seems higher than the other
https://img403.imageshack.us/img403/4900/photo2qt.jpg
shereen
PostPosted: 17:46 - 07 May 2012    Post subject: Reply with quote
They do look slighty out IMO, is there any sign of damage on them?
PostPosted: 17:52 - 07 May 2012    Post subject: Reply with quote
If anything the clocks look a bit bent.
But my eyes say left handle bar is bent more towards rider.
groovylee
PostPosted: 17:58 - 07 May 2012    Post subject: Reply with quote
+1 on clocks being on the wonk.
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
Lostboy02
PostPosted: 18:30 - 07 May 2012    Post subject: Reply with quote
Yeah i thought the left handlebar looked closer to me than the right one, didnt even notice the clocks!
No signs of Damage at all on the front of the bike that i can see.
Should i be worried?
shereen
PostPosted: 18:55 - 07 May 2012    Post subject: Reply with quote
Now you say this............
If you look just above the ignition, you can see its not aligned right. This might make the bars appear bent....
PostPosted: 19:03 - 07 May 2012    Post subject: Reply with quote
Looks like it has been dropped on the left hand side.
Check the footpegs, especially underneath them for signs of damage.
Lostboy02
PostPosted: 19:13 - 07 May 2012    Post subject: Reply with quote
Spot on paddy, Just been out there and it does have scratching and a split to the rubber on the left footpeg and what looks like scratching on the bar end.
Should this be cause for concern?
shereen
PostPosted: 19:14 - 07 May 2012    Post subject: Reply with quote
Slight thread jacking but.............. Paddy that has got to be the worse advert for your bike EVER!! And its about £1000 overpriced!! Laughing
HTH Thumbs Up
PostPosted: 20:31 - 07 May 2012    Post subject: Reply with quote
meh, its as it is.
Seen some other examples, gone for 2300 with no tax or mot with about 5000 less miles.
doesn't matter if it sells or not, It'll just get nicked otherwise
MyCarVsYourHe...
PostPosted: 01:42 - 08 May 2012    Post subject: Reply with quote
I've had this image in a photo editing program, the left handle bar does appear to be bent towards the rider by about 3% in comparison to the right side when measured against the yolk.
Edit:
on closer inspection, after altering the contrast ratio I see there's a shadow on the left hand bar that makes it appear more bent then it looks, but there is still a small difference.
https://i.imgur.com/m0DZJ.jpg
pike
PostPosted: 06:12 - 08 May 2012    Post subject: Reply with quote
I'd say it's the Clocks. Also the indicators throw things out a bit.
https://i150.photobucket.com/albums/s94/weird_andy/m0DZJ1.jpg
HD
PostPosted: 07:12 - 08 May 2012    Post subject: Reply with quote
It's all good and well drawing lines on them but who says the yoke is perfectly straight? If you drew a straight line across a point of reference on the yokes and matched it inline with the handlebars, then that will give you solid results. As it stands, it could just be they were 97% straight when taking the photo, hence 3% error.
Redoko
PostPosted: 08:28 - 08 May 2012    Post subject: Reply with quote
Measuring by pixels?
The image isn't orthographic, nor a properly set up perspective photo. Pointless.
Check for damage, move the clocks back into position, how you missed the ignition being way off I'll never know.
/end thread.
The last post was made 14 years, 190 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 78.44 Kb
