| buddha |
 buddha Renault 5 Driver
 Posted: 21:16 - 04 Oct 2004 Post subject: Stranded, bike will not start, need help ASAP |
Hi all, need you advise or help, just about to leave work, started the bike to warm the engine up, suddenly the engine stop running, so i press the electric starter, nothing happen, only a ticking sound coming out under neath the seat when ever i press it, what can i do? can i get out of london tonight?? |
| Silver |
 Silver World Chat Champion
| Reevo8 |
 Reevo8 World Chat Champion
| buddha |
| Reevo8 |
| stinkwheel |
 Posted: 21:37 - 04 Oct 2004 Post subject: |
CBR6 right?
Sounds like the battery is nearly flat, the ticking sound is most likley the starter solenoid (the electromagnetic switch that sends power to the starter motor) chattering. This is almost always a symptom of low power in the battery.
You wil either need to find someone with jump leads or try to bump start it down a hill. Second gear, clutch in, ignition on, get some speed up down the hill then pop the clutch and sit heavily on the seat at the same time to help stop the back tyre from sliding. Hopefully it will fire up. Don't stop the engine until you get home! ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Kickstart |
 Kickstart The Oracle
| Ste |
 Ste Not Work Safe
 Posted: 22:02 - 04 Oct 2004 Post subject: |
Check the kill switch, check the side stand switch and be sure it's not in gear. When you do manage to get home, join the AA.  |
| buddha |
| jonboy |
 jonboy Trackday Trickster
| buddha |
| jonboy |
 Posted: 00:38 - 05 Oct 2004 Post subject: |
quite possibly, if you haven't done many long journeys regularly. If it does turn out to be the battery, get a atrickle charge like an optimate.
And make sure your little bugger of a brother doesn't keep unplugging it  |
| buddha |
| Ste |
 Ste Not Work Safe
 Posted: 00:44 - 05 Oct 2004 Post subject: |
Ask them for a bike to borrow, explain about how you need your bike for transport and it breaking so unexpectably will cause major problems as you need transport.  |
| buddha |
| stinkwheel |
 Posted: 00:50 - 05 Oct 2004 Post subject: |
It is the time of year for spontaneous battery death but from what you describe, there is a more fundamental problem somewhere as once started, the bike should keep running on the power it is generating even on tickover. It is possible that your voltage regulator is malfunctioning (not unheard of on honda sportsbikes?) or something is drawing a lot of current. Bit of a moot point if it is still under warranty though, not your problem  ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| sickpup |
 sickpup Old Timer
| Frost |
 Frost World Chat Champion
| jonboy |
The last post was made 22 years, 47 days ago. Instead of replying here, would creating a new thread be more useful? |
