| EazyDuz |
 EazyDuz World Chat Champion
| Efes123 |
 Efes123 World Chat Champion
| supZ |
 supZ World Chat Champion
| Efes123 |
| robbieguy2003 |
 robbieguy2003 World Chat Champion
 Posted: 13:36 - 08 May 2012 Post subject: |
It's reasonably easy to do, I bled my front and back when I switched to braided lines.
If you're doing it, and you've got an ok toolkit, it'd be worth trying to clean up the pistons, even in the seats, just using a toothbrush and removing the gunk off the top of them will help somewhat.
As for the bleeding, the tool on the link from Efes looks quite good. I had a one way valve type thing that connected to the bleed nipples.
I basically done the following (from memory);
1) opened bottom bleed nipples, bled system dry
2) removed calipers, cleaned pistons, checked rings/seals, replaced pads
3) connected new lines
4) refilled system slowly from the top
5) old school method of pump level, hold lever on, open nipple, close nipple, rinse and repeat until good feel.
Section 5 is the trick. I'd do your best to make sure the system is as dry as possible (i.e. all fluid out). If you mix the old with the new, then you'll never get a good change. If you mix them at all, you'll end up with a boiling point of somewhere between the dry and wet boiling points of your new mix, and possibly worse depending on how much it manages to mix with your old fluid.
It's a relatively easy job, but it's obviously an important component, so if you're not 100% confident afterwards then just have someone check it over for you. ____________________ Current Bikes: Honda CBR 600RR - '07, Suzuki GSX1250 FA ST '11
Old Bikes: Suzuki Intruder 125 LC - '2001, Honda CBR 600F - '92, Honda CBR 600RR - '03 |
| harscot |
 harscot Crazy Courier
 Posted: 13:48 - 08 May 2012 Post subject: |
| robbieguy2003 wrote: | It's reasonably easy to do, I bled my front and back when I switched to braided lines.
It's a relatively easy job, but it's obviously an important component, so if you're not 100% confident afterwards then just have someone check it over for you. |
Ditto to the above, and take it easy over the first few miles, just in case.  ____________________ First bike R reg Suzuki 125 GT twin in 1978:
2nd bike X reg Honda 650 Deauville in 2011:
Wish bike a Triumph Thunderbird: Dream bike Triumph Rocket........ |
| bunglehaze |
 bunglehaze Brolly Dolly
 Posted: 14:36 - 08 May 2012 Post subject: |
I bought a large 100ml syringe and tube from ebay, you may find you have to bang the end of the tube in boiling water to soften u and then wrestle it to stretch over the bleed nipple but it is a one shot deal.
Attach the syringe in fully closed, open your fluid reservoir and top up, open bleed nipple and gently pump the lever until you get to fluid low line, add more fluid and repeat until what you see in the syringe is cleaner.
As you do this you may need to pump and hold lever, close off bleed nipple, detach hose and squirt out the old fluid for disposal, attach the hose again and open the nipple.
easy job to do on your own with a few minutes, zero mess and removes all your nadgery air bubbles that may otherwise be trapped.
https://www.ebay.co.uk/itm/Large-Syringe-Hydroponics-100ml-80cm-Handy-Tube-/270964996297?pt=UK_HomeGarden_Garden_PlantsSeedsBulbs_JN&hash=item3f16c5b8c9 ____________________ https://bikechatter.net
Motorcycle Products Reviews and News
06 - ZZR600 > 07 - ZX6R J1 > 08 - ZX6R J2 > 09 - ZX636 A1P > 11 - ZX10R C1H |
| Deckx |
 Deckx Nearly there...
 Posted: 15:06 - 08 May 2012 Post subject: |
replacing fluid should be a piece of piss once you don't get air in the system.... get some correct diameter rubber tube for the caliper bleed nipples and connect to the top of an empty water/coke bottle, open bleed nipples/pump brake lever slowly whilst topping up the reservoir.. go through a few reservoirs full just to make sure the system is full of fresh fluid and job done... just be careful not get air in the system as you have to go all the pump/bleed saga... which can take a fcuking age  |
| EazyDuz |
| harscot |
 Posted: 15:55 - 09 May 2012 Post subject: |
| Deckx wrote: | replacing fluid should be a piece of piss once you don't get air in the system.... get some correct diameter rubber tube for the caliper bleed nipples and connect to the top of an empty water/coke bottle, open bleed nipples/pump brake lever slowly whilst topping up the reservoir.. go through a few reservoirs full just to make sure the system is full of fresh fluid and job done... just be careful not get air in the system as you have to go all the pump/bleed saga... which can take a fcuking age  |
THE ABOVE, and YES you need a tube, rubber or plastic, just make sure its a very tight fit on the bleed nipple, or air will seep in defeating the purpose, dont no about nitro RC tubing so cant tell you, if in doubt, 1 google for info, 2 Pay over inflated garage prices, 3 do you know someone that could do it and/or show you how, and sorry to sound harsh but its not brainiac science, good luck  ____________________ First bike R reg Suzuki 125 GT twin in 1978:
| bunglehaze |
| janner_10 |
 janner_10 World Chat Champion
The last post was made 13 years, 288 days ago. Instead of replying here, would creating a new thread be more useful? |
