lights flickering
ashleybrooke1...
PostPosted: 22:45 - 02 May 2012    Post subject: lights flickering Reply with quote
peugeot speedfight 2 when i have the lights on they flicker so does my dashboard but when lights are off my dashboard is perfect. could it be a loose wire ? any suggestions ??
thanks
Kawikyle
PostPosted: 15:18 - 03 May 2012    Post subject: Reply with quote
Its either a bad earth connection, poor wiring/connection or just low power output from the battery - does the flicker go away when you rev up? if not try looking at the seating of the headlight bulb? might be dodgy?
Curse of the GPZ; Crash - new head & piston; MoT fail - warped discs & rotted exhausts; Slip - new indicators & handlebar; Crash - bought crash protectors; Blown over - bent subframe; Dogstrike - dead pitbull, broken humerus, buggered knee, smashed fairing...& still going.
MyCarVsYourHe...
PostPosted: 16:28 - 03 May 2012    Post subject: Reply with quote
How are you able to turn the lights off on a speedy?
at106
PostPosted: 17:14 - 03 May 2012    Post subject: Reply with quote
On earlier models there is a switch normally above the starter button (i think) but on newer bikes (not sure which year) the lights have to be permanently on.
MyCarVsYourHe...
PostPosted: 04:13 - 04 May 2012    Post subject: Reply with quote
Must be really old, I have a 10 year old speedy with permanent lights. I thought speedfight 2 was released around 2004?
SteveSV650
PostPosted: 16:55 - 04 May 2012    Post subject: Reply with quote
definatly sounds like an earth problem, there should be a black wire bolted to a metal part of the bike somwhere probably the frame, unbolt it, rub it down with some emery cloth and a bit of oil, clean it up and put it back, and do the same to terminals on battery, light switches, and bulb holders
Ride it like you stole it! Wink
ashleybrooke1...
PostPosted: 19:51 - 08 May 2012    Post subject: Reply with quote
ok cheers will check it out. I can only turn them on/off because I disconnected the normal beam lights because i didn't want them flickering and people thinking im flashing them at a junction and they pull out on me and yh when i rev high they still flicker. but when the normal lights were connected still flickered
The last post was made 14 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 50.84 Kb
