That could have ended badly....
chrisw
PostPosted: 20:01 - 12 May 2012    Post subject: That could have ended badly.... Reply with quote
Currently rebuilding my CB750 engine, this is what's left of the big end bearings (GL1100 bearing added as a reference).
https://i.imgur.com/MqEvq.jpg
Looks like the last person to do this put the wrong sized bearings in. Rolling Eyes
PostPosted: 20:08 - 12 May 2012    Post subject: Reply with quote
Would not have lasted long if they did. Looks like plain and simple wear to me, with a touch of oilchange neglect thrown in for good measure.
chrisw
PostPosted: 20:15 - 12 May 2012    Post subject: Reply with quote
I can't believe this is just wear and tear. The 'good' bearing came from a 40k engine....so did the bad ones.
I suspect these bearings have less than 2k miles on them. The guy I bought the bike from mentioned having the engine apart and judging by the other bodges I've found he was clueless.
U_W v2.0
PostPosted: 21:06 - 12 May 2012    Post subject: Reply with quote
bit like me then because i have to ask.
that do those things do in an engine?
(gimme a break, im new to all this lol)
Sako
PostPosted: 21:13 - 12 May 2012    Post subject: Reply with quote
they keep the powerband under tension.
U_W v2.0
PostPosted: 21:25 - 12 May 2012    Post subject: Reply with quote
lol this could spiral into a million questions which would leave with a very intimate knowledge of engines as i have no idea what a power band is or what that does and how it in turn affects those metal things lol
totalllama82
PostPosted: 21:30 - 12 May 2012    Post subject: Reply with quote
Those are the bearings that the crankshaft rides on. The crankshaft is the shaft that the pistons connect to at the bottom end of the engine. The shaft, besides being connected to the bottom of the pistons, is connected to the clutch at one end.
The bearings you see assist it turning in the engine casing. They shouldn't look like the OP's picture though!
Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F
Paris2
Now now, play nice Laughing
Current Ride: Daytona 600
chrisw
PostPosted: 21:32 - 12 May 2012    Post subject: Reply with quote
Google can answer everything....
flumpy7
PostPosted: 21:33 - 12 May 2012    Post subject: Reply with quote
Im a nurse and whenever we get a new student nurse or doctor on the ward we start by asking them to fetch a fallopian tube from the equipment cupboard. They fall for it every time. Im afraid you just fell for a similar joke.
https://en.wikipedia.org/wiki/Power_band
2012 Sinnis apache
Sako
PostPosted: 21:52 - 12 May 2012    Post subject: Reply with quote
here is a powerband - https://i136.photobucket.com/albums/q187/FoxMulder_R/powerband.jpg
U_W v2.0
PostPosted: 22:16 - 12 May 2012    Post subject: Reply with quote
ah well, like my first post on the thread says,
im new to all this!
bound to fall for jokes and general stuff like that. all good and fun though
flumpy7
PostPosted: 22:22 - 12 May 2012    Post subject: Reply with quote
im new to all this!
Thumbs Up Nobody likes a serious sidney
2012 Sinnis apache
pendulum
PostPosted: 00:35 - 13 May 2012    Post subject: Reply with quote
GL1100 bearing looks twisted
1998 CG125 (Sold) CB500 [+ Clio 172]
Usually_Wrong: I tend to fail more than pass. [Speaking about Theory Practice]
Usually_Wrong: im on unemployment at the moment
yen_powell
PostPosted: 09:16 - 13 May 2012    Post subject: Reply with quote
How stupid are they? Everyone knows that fallopian tube comes on a roll, you just cut off the amount you need.
XT1200Z and a DR350 in bits
Beelzebob
PostPosted: 09:25 - 13 May 2012    Post subject: Reply with quote
You are describing main bearing shells, that stay in the engine block and that the crank rotates in. Big ends such as those shown above are at the big (crank) end of the conrod, and are the point at which the bottom of the conrod revolves around the crank Thumbs Up
'09 YBR 125 -> '92 XJ600 S Diversion -> '99 Hornet 600
"Stronger than your average female lifeguard"
totalllama82
PostPosted: 10:07 - 13 May 2012    Post subject: Reply with quote
My bad, I stand corrected! I blame too many sherbets last night Wink
sickpup
Old Timer
PostPosted: 10:12 - 13 May 2012    Post subject: Reply with quote
Are those the top shells by any chance?
chrisw
PostPosted: 10:40 - 13 May 2012    Post subject: Reply with quote
You should see the subframe! And the chains a bit loose, not sure which chain though.
Both bottom and top are the same. No.3 & 4 are a little worse but there is no difference between top and bottom.
I've been looking at them a bit more closely. It looks like a couple of the bearings have spun in the rod at least a few times.
So the story looks to be something like wrong sized bearings moving in the rod blocking the oil way leading to massively increased wear.
This is not how I expect bearings to sit in the rod:
https://i.imgur.com/FPqrR.jpg
mentalboy
PostPosted: 15:07 - 16 May 2012    Post subject: Reply with quote
Only takes a short while with a lack of oil to do this, think how much friction is created in there when that crank's lobbing round at red line revs, once that crank grips them 'cos she's dry they'll just spin.
Are the faces good? I've recently done a 'Blade that looked a lot worse and ended up throwing away the crank - got any friendly old timer engineers nearby who'd make sure it's still true, always best to check for the cost of a couple of pints!
Make mine a Corona.
Cheeseybeaner
PostPosted: 15:23 - 16 May 2012    Post subject: Reply with quote
Sako wrote:
Ha ha ha! Just £29:95! Fully adjustable for greater tuning...
bunglehaze
PostPosted: 15:45 - 16 May 2012    Post subject: Reply with quote
which one though? I thought the pink one didnt use a bearing
https://bikechatter.net
Motorcycle Products Reviews and News
06 - ZZR600 > 07 - ZX6R J1 > 08 - ZX6R J2 > 09 - ZX636 A1P > 11 - ZX10R C1H
The last post was made 13 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 115.43 Kb
