What does TRE mean
timboellis
PostPosted: 18:14 - 13 May 2012    Post subject: What does TRE mean Reply with quote
Looking at some bikes and a few say TRE what does this mean?
L-Jam
PostPosted: 18:27 - 13 May 2012    Post subject: Reply with quote
It means, "They're Really Easy" (to ride).
Journalist, student, egotist.
stevo as b4
PostPosted: 18:28 - 13 May 2012    Post subject: Reply with quote
Is it a Suzuki sportsbike thats for sale your looking at ad's for?
If so TRE could mean timing retard eliminator, which is a little piggyback black box that plugs into the bikes ECU loom usually, and it removes the softening of the power delivery in the lower gears, so that the bike has as much go throughout the rev range in the lower gears as it does in top etc.
It's a bit like with some high performance turbocharged car's when the manufacturer uses the ECU to restrict the boost pressure in the lower gears with the aim of making the have better traction and be able to use the power better, instead of smoking the tyres or causing violent torque steer etc.
PostPosted: 18:50 - 13 May 2012    Post subject: Reply with quote
Its kinda the first part of a few model of Benelli bikes..
If so TRE could mean timing retard eliminator, which is a little piggyback black box that plugs into the bikes ECU loom usually, and it removes the softening of the power delivery in the lower gears, so that the bike has as much go throughout the rev range in the lower gears as it does in top etc..
Or allows you to go past the 186 limit Wink
Villers
PostPosted: 18:53 - 13 May 2012    Post subject: Reply with quote
The TRE for the Hayabusa (the cheap ones at least) tricked the bike into thinking it was in 5th gear, that way theres no limiter in 6th at the 186mph mark!
If I remember correctly that is! Confused
timboellis
PostPosted: 18:58 - 13 May 2012    Post subject: Reply with quote
Its a tl1000r
hmmmnz
PostPosted: 19:23 - 13 May 2012    Post subject: Reply with quote
its the limiter removal in 1st and second gear on the tls,
they put in the limiter when too many people went over the back
ar the time the tl had a little too much of everything Very Happy it dealt to the retards and born again bikers Very Happy
the humans are dead
I kick arse for the lord
Cunnington
PostPosted: 21:40 - 13 May 2012    Post subject: Reply with quote
On the SV, Suzuki restrict the performance in lower gears (2nd and 3rd from memory), to ease compliance with Euro noise regs or similar. You could buy a little box to trick the ECU into not recognising that is in these gears.
'82 C50, '81 CB100, '84 GS125, '95 NTV650, '00 Bandit 600, '06 SV650, '56 Z1000, '89 NTV600
The Shaggy D.A. wrote: "You are invisible. Those who can see you are trying to kill you."
Slacker24seve...
PostPosted: 21:44 - 13 May 2012    Post subject: Reply with quote
Terrible Rectal Explosion?
Banger rallies are ace
Teflon-Mike
tl;dr
PostPosted: 22:02 - 13 May 2012    Post subject: Reply with quote
Track-Rod-End
Grrh27
PostPosted: 07:29 - 14 May 2012    Post subject: Reply with quote
Tempore Regis Eduardi
DrDonnyBrago
PostPosted: 16:30 - 14 May 2012    Post subject: Reply with quote
After one of Warped's posts, TRE means "The Real Events" and describes what actually happened.
I.e.
warped wrote:
I was a suicide bomber and I blew up an illegal pharmaceuticals factory in the Gaza strip
TRE
Warped farted in Boots.
The last post was made 14 years, 170 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 72.5 Kb
