Just bled the brakes...
EazyDuz
PostPosted: 13:50 - 13 May 2012    Post subject: Just bled the brakes... Reply with quote
Think we did it right. Tube over bleed nipple with other end in jar with brake fluid in it.
Pull brake lever, open nip half a turn, close nip, let go of lever. We did it until the tube was flowing with clean fluid.
Tested the brakes by rolling the bike forward and putting them on.
Before going out on the bike to properly test them, should i expect them to fail suddenly? Or will i know if they will just by roll testing the brakes?
THanks
AlexW
PostPosted: 14:35 - 13 May 2012    Post subject: Reply with quote
Just take it easy, dont go up the road and slam on and expect it to stop. Play it safe.
Thats the right way, I tend to go on feel, if you pump the lever and feel for spongyness etc.
Nick 50
PostPosted: 14:55 - 13 May 2012    Post subject: Reply with quote
For the front brake, you should feel it is right simply by pushing the bike and applying the brake.
Also double check everything is back where it should be and tightened correctly. Thumbs Up
harscot
PostPosted: 19:42 - 13 May 2012    Post subject: Reply with quote
Smile Hi bud, just take it easy initially, try them out in a quite place just in case, hopefully everything should be ok...ride safe out here Thumbs Up
First bike R reg Suzuki 125 GT twin in 1978:
2nd bike X reg Honda 650 Deauville in 2011:
Wish bike a Triumph Thunderbird: Dream bike Triumph Rocket........
EazyDuz
PostPosted: 19:55 - 13 May 2012    Post subject: Reply with quote
Gave them a test, worked fine.
Dont know what i was worrying about, bleeding the brakes took 10 minutes, job done, braking performance is much better now too
harscot
PostPosted: 20:01 - 13 May 2012    Post subject: Reply with quote
Clapping well done bud, stay loose and safe out there Thumbs Up
anthony_r6
PostPosted: 21:33 - 13 May 2012    Post subject: Reply with quote
Took me about 3 days... two of me not getting them to brake properly and another day while it sat in the garage getting done properly Laughing
The last post was made 14 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 51.1 Kb
