| von1papen |
 von1papen Spanner Monkey
| nightshaddow |
 nightshaddow Nearly there...
 Posted: 19:01 - 14 May 2012 Post subject: |
if you have a compresion tester that would give you the right answer, from what you are saying it could be 1 or 2 different things,
best whip the plugs out this can be the first indication if something is wrong, also check your valve clearances,
i suspect piston rings as you said but it could also be valves/ valve stem seals ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| Compo |
 Compo Nova Slayer
| von1papen |
| von1papen |
 Posted: 11:46 - 31 May 2012 Post subject: |
Turns out it was the rings, one of the pistons had fully chewed itself to bits and welded to the top of the barrel at some stage, the other piston had just shattered its top compression ring!
A 0.5mm rebore, new oversize piston kits on the way from wee-moto and we're back on track
Lapped the valves last night though I've yet to stick the springs back in and test them for leaks.
Head was full of carbon and mashed aluminum from the piston, had to scrape it off, thankfully the valves seemed to be fine.
Yes I thrashed the wee engine at the top end on the motorway but I didn't expect it to blow within 3 months! (Kept her topped up with oil) Still with all this work done she'll be like brand new, £110 for the boring, honing and piston kits which IMO isn't bad for an essentially new top end to be run in  |
The last post was made 13 years, 266 days ago. Instead of replying here, would creating a new thread be more useful? |
