Push/pull throttle cables
HD
PostPosted: 18:03 - 17 May 2012    Post subject: Push/pull throttle cables Reply with quote
Can you use just the pull?
My old carbs had just a single cable but the new ones have a push/pull mechanism. They spring back on their own so could I use just the pull cable? Not even 100% both cables will fit through my throttle housing/switchgear as I don't know how they connect up.
Marmalade
PostPosted: 18:29 - 17 May 2012    Post subject: Reply with quote
Yes. Just a pull is fine, push is just a safety in case of an unlikely failure really
HD
PostPosted: 18:38 - 17 May 2012    Post subject: Reply with quote
Ideal, thought it would be. Thanks!
map
Mr Calendar
PostPosted: 19:43 - 17 May 2012    Post subject: Reply with quote
Yes you can.
The old Kawasaki GT550 should according to the specs have a push-pull. However mine came with just the single cable. I know this as it had to be replaced recently. Caution though as for me for some reason new cable not quite same as old so low speed work is a pain.
HTH
Marmalade
PostPosted: 20:09 - 17 May 2012    Post subject: Reply with quote
My pull cable snapped and i had no throttle so i swapped them round on the carb and had to use the twist the opposite to normal.
Only 100 miles to home but nearly killed myself several times
herulach
PostPosted: 20:15 - 17 May 2012    Post subject: Reply with quote
Surely it'd have been short work to swop at the bar as well?
YBR 125>FZS600
Marmalade
PostPosted: 20:16 - 17 May 2012    Post subject: Reply with quote
no, the cable ends are different so it couldn't be done
The last post was made 13 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 53.63 Kb
