Todays Task - Stripping and Cleaning Brakes
StevenF
PostPosted: 20:14 - 17 May 2012    Post subject: Todays Task - Stripping and Cleaning Brakes Reply with quote
First challange was to get the pistons out. I had a dry system so couldn't use fluid to push then out. I resorted to using a car/tyre pump, was a pain in the arse and it took forever. Trying to get a good sealed air connection was a nightmare. Anyway eventually took the first piston out and gave it a little clean:
https://i4.photobucket.com/albums/y118/Wonderboy_001/7d891cf2.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/d4b9a557.jpg
Taada!
Took the slider pin out of the rear calliper, needed a bit of a clean!
https://i4.photobucket.com/albums/y118/Wonderboy_001/3ea53996.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/504aaeff.jpg
Took all the seals off and cleaned behind them
https://i4.photobucket.com/albums/y118/Wonderboy_001/19e03712.jpg
This was was a bit of a mess!
https://i4.photobucket.com/albums/y118/Wonderboy_001/c219fe49.jpg
After a clean
https://i4.photobucket.com/albums/y118/Wonderboy_001/aa8fba1f.jpg
There was also a chip out of this one, but it didn't seem to be leaking before so should be ok.
Everything went well for a change! Nothing broken (unheard of) Smile I need to get done red rubber grease before re-assembling everything. Am I right in thinking the slider pin pictured above should be greased, as well as the two sliders in the two pictures bellow?
https://i4.photobucket.com/albums/y118/Wonderboy_001/cf82aa9a.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/e572ab06.jpg
neil.
PostPosted: 21:31 - 17 May 2012    Post subject: Reply with quote
Yes red rubber grease is the one to use on the sliders. Thumbs Up
The last post was made 13 years, 231 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 34 Kb
