YBR Neutral
gsmunn
PostPosted: 22:07 - 17 May 2012    Post subject: YBR Neutral Reply with quote
Having a bit of a larf with this one.
I can't seem to get my bike into neutral while the engine is running, if i pop it into first, engine off then on, it will go into neutral. If I do the same but using the kickstand to kill the engine, it will go into neutral, If the machine is running, can't get it into neutral for love nor money.
I have no issue going up or down any other gears and trying to go from 2nd to neutral results in it bumping right down to first.
Is this quite common or is something needing adjusting?
Alpha-9
PostPosted: 22:09 - 17 May 2012    Post subject: Re: YBR Neutral Reply with quote
I find it's easier to drop to first and pull up very slightly into neutral, hae you had the bike long? It was tricky for me at first i could almost never do it, then i got the nack
Fzr-600 1999
arry
PostPosted: 22:10 - 17 May 2012    Post subject: Reply with quote
Check the adjustment / condition of the clutch cable
gsmunn
PostPosted: 22:12 - 17 May 2012    Post subject: Re: YBR Neutral Reply with quote
The bulk of the post was referring to it being in first then trying to go up, it either jumps to 2nd or wont move atall.
As for clutch cable, the condition is fine, I dont know about adjustment though, hence the asking Razz
Teflon-Mike
tl;dr
PostPosted: 22:29 - 17 May 2012    Post subject: Reply with quote
1/ Get a Workshop Manual Check 'Routine Maintenence' section
2/ Do Oil Change
3/ Read CAREFULLY the section in works-hop manual hon HOW to Adjust the Clutch.
HINT, you DO NOT do it with teh screw on the handle-bar lever! That is there MERELY to adjust the 'free-play' AT the lever.
Another Hint: Cable may move in sleeve, dont mean its 'fine'. Oil helps enormousely. But constantly tugged by hand fisted newbies tought poorly to keep tension on teh cable and constantly 'slip' the clutch as seems to be vogue now, they STRETCH and as they stretch, they get more and more bungee like and more and more of the lever travel gets used to take up the springiness in the cable, rather than actuially move stuff about inside the engine. For sake of a £10 likely to be worth swapping out for sake of anyway.
Further Hints: Clutch usually adjusts in three places. Often a screw and lock-nut type of adjustor on or behind plate on teh engine. This adjusts length of actuation rod that actually pushed plates apart inside the engine, as they get thinner to compensate for wear. Second is at the engine end of cable, where it pulls the lever that works the cam that poushed actuation rod, so that you can compensate for cable stretch. If you ONLY adjust teh cable, then you are using cable travel and clutch actuation cam travel to take up slack that should be adjusted with teh screw and lock-nut. Results in having to use twice the cable adjustment or more, but worse, pulling the lever round to the least effective range of travel, beyond 'centre' so you dont get as much clutch motion for your lever motion.
Another Hint: Hard-Worked learner bikes, with learners now tought to constantly slip the clutch, wear out clutch plates, and more the clutch springs. These are not expensive or difficult to replace.
However. Styart at the top and work through the list. Get manual. Change Oil, adjust to the book.
Also, for gear change 'slopiness' or general nastyness, see this thread:-
Missing second gear - is it me or the bike.
Hard used Learner-Bikes also get thier transmissions hammered by clumsy gear changes and jerky take-offs.
4/ Check condition of rear wheel 'Cush-Drive' - replace rubbers if at all 'sloppy'.
5/ Correctly Adjust Chain & lubricate
BASIC MAINTENENCE goes an awful long way.
PostPosted: 22:37 - 17 May 2012    Post subject: Reply with quote
CBR was the same, put in 2nd and lean on the lever, seemed to roll into neutral if bike was moving, sitting at lights...leave in first, parking..leave in 1st Laughing
Tomzo47
PostPosted: 22:42 - 17 May 2012    Post subject: Reply with quote
neutral was a ball ache on my YBR, wouldnt seem to go into it from first, only from second, and even then got to give it a shove. Then after trying to get it into neutral, pull off again later and slips straight into it when i pull off making me sound like a twat Evil or Very Mad
Ybr 125 > Bandit 650SA > GSXR 600 > Triumph Sprint St1050 > CB1300 > Z1000SX + FJ1200 (written off) > VFR750 >FJ1200
PostPosted: 01:03 - 18 May 2012    Post subject: Re: YBR Neutral Reply with quote
It seems to be more of an issue with smaller engines. My 125 needed quite a bit of ticking to find neutral when hot, it's not so much of an issue with the larger bikes.
gsmunn
PostPosted: 06:15 - 18 May 2012    Post subject: Reply with quote
Clues in the title rogerborg Razz It be a ybr 125
Tef, the oil's been changed recently, cheers for the post though, will have a work through it all at the weekend when i'm of work.
At least for me anyway, having a duff neutral isn't the apocalypse, everything else works fine and the gearing elsewhere is spot on, it just doesn't like going into neutral while running
PostPosted: 10:53 - 18 May 2012    Post subject: Reply with quote
I'm sorry, miss, I have a cold. Middle FingerWinkMiddle Finger
I've give the clutch cable a little tighten-up, it may just not be disengaging the clutch fully.
Teflon-Mike
tl;dr
PostPosted: 13:34 - 18 May 2012    Post subject: Reply with quote
Was it sticky before you changed oil? Or has it got worse since?
Begs question, what oil did you use? Too thick & It can make plates drag.
gsmunn
PostPosted: 15:48 - 18 May 2012    Post subject: Reply with quote
It's always been like that, didn't have much Luck on the schools CBT bikes either, the bike goes into neutral from first if the revs are high enough sometimes.
It's 10w40 oil, halfords
gsmunn
PostPosted: 08:47 - 19 May 2012    Post subject: Reply with quote
_Iain_ wrote:
If its car oil that can cause greif specificly with the clutch - or so i've heard. Why not just chuck the proper yamalube in it from a bike shop? Less than a tenner a bottle & you know its fit for purpose!
With that said, the YBR's are a right shit to get into neutral at the best of times, mine always has been. Tightening up the gear selector lever helps get a better feel for it. If it doesnt go straight in i'll click 1st, little bit of revs and let the clutch out till it bites, clutch in and then it'll go.
It's motorbike oil, I'm special, but not THAT special.
I spent yesterday when I was on my 50mile run deliberately trying to get it into neutral as often as possible and I am finding it easier now after advice earlier, bout bumping it while still moving, and as you say, keeping the revs high and it goes into neutral no trouble, so I think it was technique on my part that seems to have effected it.
The last post was made 14 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 90.18 Kb
