| gsmunn |
 gsmunn Nova Slayer
| Alpha-9 |
 Alpha-9 Super Spammer
| arry |
 arry Super Spammer
| gsmunn |
 gsmunn Nova Slayer
| Teflon-Mike |
 Posted: 22:29 - 17 May 2012 Post subject: |
1/ Get a Workshop Manual Check 'Routine Maintenence' section
2/ Do Oil Change
3/ Read CAREFULLY the section in works-hop manual hon HOW to Adjust the Clutch.
HINT, you DO NOT do it with teh screw on the handle-bar lever! That is there MERELY to adjust the 'free-play' AT the lever.
Another Hint: Cable may move in sleeve, dont mean its 'fine'. Oil helps enormousely. But constantly tugged by hand fisted newbies tought poorly to keep tension on teh cable and constantly 'slip' the clutch as seems to be vogue now, they STRETCH and as they stretch, they get more and more bungee like and more and more of the lever travel gets used to take up the springiness in the cable, rather than actuially move stuff about inside the engine. For sake of a £10 likely to be worth swapping out for sake of anyway.
Further Hints: Clutch usually adjusts in three places. Often a screw and lock-nut type of adjustor on or behind plate on teh engine. This adjusts length of actuation rod that actually pushed plates apart inside the engine, as they get thinner to compensate for wear. Second is at the engine end of cable, where it pulls the lever that works the cam that poushed actuation rod, so that you can compensate for cable stretch. If you ONLY adjust teh cable, then you are using cable travel and clutch actuation cam travel to take up slack that should be adjusted with teh screw and lock-nut. Results in having to use twice the cable adjustment or more, but worse, pulling the lever round to the least effective range of travel, beyond 'centre' so you dont get as much clutch motion for your lever motion.
Another Hint: Hard-Worked learner bikes, with learners now tought to constantly slip the clutch, wear out clutch plates, and more the clutch springs. These are not expensive or difficult to replace.
However. Styart at the top and work through the list. Get manual. Change Oil, adjust to the book.
Also, for gear change 'slopiness' or general nastyness, see this thread:-
Missing second gear - is it me or the bike.
Hard used Learner-Bikes also get thier transmissions hammered by clumsy gear changes and jerky take-offs.
4/ Check condition of rear wheel 'Cush-Drive' - replace rubbers if at all 'sloppy'.
5/ Correctly Adjust Chain & lubricate
BASIC MAINTENENCE goes an awful long way. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| P.addy |
 P.addy Red Rocket
 Posted: 22:37 - 17 May 2012 Post subject: |
CBR was the same, put in 2nd and lean on the lever, seemed to roll into neutral if bike was moving, sitting at lights...leave in first, parking..leave in 1st  |
| Tomzo47 |
 Tomzo47 Brolly Dolly
 Posted: 22:42 - 17 May 2012 Post subject: |
neutral was a ball ache on my YBR, wouldnt seem to go into it from first, only from second, and even then got to give it a shove. Then after trying to get it into neutral, pull off again later and slips straight into it when i pull off making me sound like a twat  ____________________ Ybr 125 > Bandit 650SA > GSXR 600 > Triumph Sprint St1050 > CB1300 > Z1000SX + FJ1200 (written off) > VFR750 >FJ1200 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 01:03 - 18 May 2012 Post subject: Re: YBR Neutral |
It seems to be more of an issue with smaller engines. My 125 needed quite a bit of ticking to find neutral when hot, it's not so much of an issue with the larger bikes. ____________________ Biking is 1/20th as dangerous as horse riding.
| gsmunn |
 gsmunn Nova Slayer
 Posted: 06:15 - 18 May 2012 Post subject: |
Clues in the title rogerborg It be a ybr 125
Tef, the oil's been changed recently, cheers for the post though, will have a work through it all at the weekend when i'm of work.
At least for me anyway, having a duff neutral isn't the apocalypse, everything else works fine and the gearing elsewhere is spot on, it just doesn't like going into neutral while running |
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:53 - 18 May 2012 Post subject: |
| Teflon-Mike |
| gsmunn |
 gsmunn Nova Slayer
| _Iain_ |
 _Iain_ Banned
 Posted: 07:23 - 19 May 2012 Post subject: |
If its car oil that can cause greif specificly with the clutch - or so i've heard. Why not just chuck the proper yamalube in it from a bike shop? Less than a tenner a bottle & you know its fit for purpose!
With that said, the YBR's are a right shit to get into neutral at the best of times, mine always has been. Tightening up the gear selector lever helps get a better feel for it. If it doesnt go straight in i'll click 1st, little bit of revs and let the clutch out till it bites, clutch in and then it'll go. ____________________ Please be aware that the above post may be full of complete nonsense.
| gsmunn |
 gsmunn Nova Slayer
 Posted: 08:47 - 19 May 2012 Post subject: |
| _Iain_ wrote: | If its car oil that can cause greif specificly with the clutch - or so i've heard. Why not just chuck the proper yamalube in it from a bike shop? Less than a tenner a bottle & you know its fit for purpose!
With that said, the YBR's are a right shit to get into neutral at the best of times, mine always has been. Tightening up the gear selector lever helps get a better feel for it. If it doesnt go straight in i'll click 1st, little bit of revs and let the clutch out till it bites, clutch in and then it'll go. |
It's motorbike oil, I'm special, but not THAT special.
I spent yesterday when I was on my 50mile run deliberately trying to get it into neutral as often as possible and I am finding it easier now after advice earlier, bout bumping it while still moving, and as you say, keeping the revs high and it goes into neutral no trouble, so I think it was technique on my part that seems to have effected it. |
The last post was made 14 years, 158 days ago. Instead of replying here, would creating a new thread be more useful? |
