what spare parts do you keep?
U_W v2.0
PostPosted: 00:10 - 20 May 2012    Post subject: what spare parts do you keep? Reply with quote
so, what parts do you keep a spare of? i.e constant replacement set (like you use it, you replace the backup immediatly)
personally i like to keep a spare set of:
complete bulb set (front, rear, possition, dash, clock, indicators)
spare battery
spare brake pads and disk (front disk brake)
spare brake shoes (rear drum brake)
spare engine oil
spare brake fluid (hydrolic front disk brake)
obviously the only spare parts i ride with are the bulbs and a multi-head screw driver. sod getting fined. if i where to get pulled over for a bad bulb i'd at least be able to say "oh, must've just gone, one second" pop out the screw driver n relevant spare bulb, change it on site and hopefully avoid that darned ticket as the copper can then see its working lol
Rob W
PostPosted: 00:18 - 20 May 2012    Post subject: Reply with quote
None.
If it's gone, replace it.
If it looks like it's going soon, order it.
CaNsA
PostPosted: 00:27 - 20 May 2012    Post subject: Reply with quote
RobW1983 wrote:
None.
Ditto
Sako
PostPosted: 00:31 - 20 May 2012    Post subject: Reply with quote
pack of cigarettes
mad4it028
PostPosted: 00:33 - 20 May 2012    Post subject: Reply with quote
dont carry any spares , have lots and lots of spares for lots of bikes
strangly no spares at all for my own bike tho other than tyres
pendulum
PostPosted: 00:35 - 20 May 2012    Post subject: Reply with quote
I went through a stage of stockpiling stuff for my old car once; I still have most of that stuff but no longer have the car. Once you start buying parts because you "might need it in the future" it's easy to turn in to a hoarder, so I only buy stuff on an as needed basis now.
1998 CG125 (Sold) CB500 [+ Clio 172]
Usually_Wrong: I tend to fail more than pass. [Speaking about Theory Practice]
Usually_Wrong: im on unemployment at the moment
U_W v2.0
PostPosted: 00:37 - 20 May 2012    Post subject: Reply with quote
this is why i only keep the spare parts for those bits essential to riding as my bike will be my only main form of transport i cant exactly "ride to get a replacement stop light" or battery ect ect
Marmalade
PostPosted: 00:38 - 20 May 2012    Post subject: Reply with quote
I keep a complete set of pads, one pair on the bike.
Oil and filters
Bulbs kept on bike
Front wheel bearings kept on bike
Starter relay kept on bike
Enough parts in the shed to build a complete bike plus so it's never left off the road waiting for bits.
pendulum
PostPosted: 00:39 - 20 May 2012    Post subject: Reply with quote
Well, you can...
Robby
Dirty Old Man
PostPosted: 00:40 - 20 May 2012    Post subject: Reply with quote
For the Harley, nothing.
For the Honda, two complete spare bikes.
Dazbo666
PostPosted: 00:48 - 20 May 2012    Post subject: Reply with quote
Small pack of fuses and the exhaust baffle under the bike seat.
Spare bulbs, engine oil, filters, brake fluid, spark plugs, wheel bearings and normally a full set of brake pads in the garage.
Also been replacing the swiss cheese OEM allen bolts with stainless alternatives, and recently replaced the rear brake disk with a new one that I'd bought 4-6 months earlier
Word of the day : DILLIGAF
U_W v2.0
PostPosted: 01:39 - 20 May 2012    Post subject: Reply with quote
oh ya! fuses! i keep the piggy back fuse holder spare fuse bit full.
keggyhander
PostPosted: 02:20 - 20 May 2012    Post subject: Reply with quote
Drive belt
groovylee
PostPosted: 03:27 - 20 May 2012    Post subject: Reply with quote
brake / clutch levers. but then mine only cost £5 a pop, so not too much of an outlay for me. used the brake lever the other day dropping the bike on the driveway. replaced it there and then. new replacement turned up yesterday Thumbs Up
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
plugger147
PostPosted: 03:49 - 20 May 2012    Post subject: Reply with quote
Dunno why you'd keep a spare battery, the bugger sat doing nothing is more than likely gonna be shagged before the one your using everyday....
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
yen_powell
PostPosted: 07:52 - 20 May 2012    Post subject: Reply with quote
For my Africa Twin I have got, spare downpipes and collector box, spare wheels (with discs and tyres on), CDI, starter solenoid, vacuum fuel pump, electric fuel pump, complete set of bodywork, clutch basket, clocks, digital trip meter, all three brake calipers, swing arm, rack, seat, lock set, levers, brake pedal, gear lever, alloy bash plate, coils, inner tubes, oil filters, rear suspension linkages plus rebuild kit, speedometer drive.
In other words I never sold all of my previous AT, just the engine, carbs, forks, petrol tank and frame.
For my Varadero I have got spare downpipe gaskets (had one go and I hear it will do it again and again, dodgy design) and an oil filter.
XT1200Z and a DR350 in bits
jjdugen
PostPosted: 09:51 - 20 May 2012    Post subject: Reply with quote
Always carry a spare reg/rec with me, (have a voltage monitor fitted, any sign of overcharging and I can swap it out at the roadside. Mind you, thats from my Honda days!) Plus fuses, tail and headlight bulbs, a small allen key kit, multi head screwdriver kit and a split link. All can fit under the seat along with the chain and lock. (But thats the beauty of the ZZR, lots of storage space).
Deckx
PostPosted: 10:06 - 20 May 2012    Post subject: Reply with quote
I have 2 x zx6r's '03... one road and one track.. great for spares, getting mixed up whats what now Laughing atm have only one battery due to sheer laziness of buying one... have a load of spare crap around as well, levers, sprockets, fairings, etc.
PostPosted: 12:11 - 20 May 2012    Post subject: Reply with quote
A wallet with cash and an RAC card in it.
.Chris.
PostPosted: 12:15 - 20 May 2012    Post subject: Reply with quote
I'm terrible for hoarding spares. For my car, I have 3 spare engines, 2 spare gearboxes, a complete set of doors, plus loads of other mechanical bits and pieces. For the RXS, I've got a spare frame, engine, plus a couple of large boxes of stuff. Nothing for the GN as of yet, but that's going to change soon Laughing
Chris
1985 Kawasaki Z550F
Slacker24seve...
PostPosted: 12:44 - 20 May 2012    Post subject: Reply with quote
This. My bike has NO storage.
Banger rallies are ace
DrDonnyBrago
PostPosted: 12:58 - 20 May 2012    Post subject: Reply with quote
I replace it when it breaks/looks close to wearing out.
I usually order parts quite early in advance of them failing or if I see a good deal on stuff like pads/tyres I'll stock up. I also have fluids (oil/coolant) ready for the next change (tend to buy brake fluid as and when I need it).
I don't keep spare non consumables or stuff with a short shelf life if I can help it as I'll either end up binning it or keeping it unused forever. I do however tend to keep all old components, not sure why but I have rather a lot of crap I should weigh in when I get a chance.
kawakid
PostPosted: 13:07 - 20 May 2012    Post subject: Reply with quote
The ER has zero zilch nothing klein nichts underseat storage so nothing at all.
On the Z I have a pack of bulbs and fuses of every design.
In my garage, I have some spare pegs and some oil filters, oil and crush washers that's about it.
I've a twin and a 4.
PostPosted: 13:43 - 20 May 2012    Post subject: Reply with quote
I am bad for hoarding and do have loads of spares. Probably not the ones I need though. Load of spare bodywork for the older Aprilias. Load of brake pads. Oil filters. Load of Aprilia engine spares. Etc.
PostPosted: 13:48 - 20 May 2012    Post subject: Reply with quote
Few hundred frames, wheels, disks.... basically, a dealers amount of spares Laughing
The last post was made 14 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 125.79 Kb
