Building a Garage/Workshop
UnspeedySam
PostPosted: 10:45 - 20 May 2012    Post subject: Building a Garage/Workshop Reply with quote
So I'm moving house soon and will find myself with no garage, but also in a position to build one.
I would like something pretty decent sized, but am not set on either a concrete or wooden structure. However I guess concrete would last significantly longer.
I've found this for about £2k but that is a lot of money and I was wondering if anyone had any cheaper alternatives? Maybe even a second hand option.: https://www.kirtonbuildings.co.uk/product_detail.php?id=381
Timber option same price: https://www.kirtonbuildings.co.uk/product_detail.php?id=319
daemonoid
PostPosted: 10:59 - 20 May 2012    Post subject: Reply with quote
Can't really help with a cheaper option other than build it yourself. Get a builder in and it'd cost way more than 2k.
Don't forget a pit though!
current: ducati monster 750
UnspeedySam
PostPosted: 11:04 - 20 May 2012    Post subject: Reply with quote
Just found a self build concrete section garage for £125 on gumtree. would have to take it down and built it up again myself...and might be gone already. But it's good to know they come up.
I'm just shocked at how much (even the kits from the above link) go for new.
swampy
PostPosted: 11:08 - 20 May 2012    Post subject: Reply with quote
beechbone wrote:
Just found a self build concrete section garage for £125 on gumtree. would have to take it down and built it up again myself...and might be gone already. But it's good to know they come up..
Would you be able to get it in the back of a Corsa though ?? Very Happy
Renton
PostPosted: 12:19 - 20 May 2012    Post subject: Reply with quote
Why not build the main structure yourself, and buy the garage door separately?
Find the garage door that you want. Using it's dimensions as the starting point, you can then build around it.
When I was younger my dad built a brick shed at the bottom of the garden which was probably just smaller than a double garage. He's no builder, but he did a great job of it!
You can get tools that make brick laying a lot easier:
https://www.brickytool.com/index_eng.html
This is my motorcycle. There are many others like it, but this one is mine.
Without me, my motorcycle is useless. Without my motorcycle, I am useless.
UnspeedySam
PostPosted: 14:25 - 20 May 2012    Post subject: Reply with quote
I'm going to need to hire a van to move house anyway. So I'll move it there. The guy selling it seems fine with it...the dismantling will be the hard bit...
UnspeedySam
PostPosted: 14:26 - 20 May 2012    Post subject: Reply with quote
Good idea. If this cheap garage turns out to be rubbish I'll probably end up doing that. Bricks are pretty cheap...
kawakid
PostPosted: 14:32 - 20 May 2012    Post subject: Reply with quote
Build as big as you can. The prices have gone up though, about 10 years ago a single 28' one cost around £2K.
One thing, the people who built the garage didn't lay the base, I had to get that done.
I've a twin and a 4.
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
UnspeedySam
PostPosted: 20:00 - 20 May 2012    Post subject: Reply with quote
Went and saw the £120 garage this evening. Decent enough size and going to be easy enough to take down/rebuild. I know I'll need to lay a concrete base, but luckily I have a mate who has done it before so I'll just hire a cement mixer and do it on the cheap I guess.
UnspeedySam
PostPosted: 20:03 - 20 May 2012    Post subject: Reply with quote
Mk1GSF wrote:
Make sure it's a deep enough base then. Thumbs Up
How deep do you reckon is deep enough?
mad4it028
PostPosted: 20:12 - 20 May 2012    Post subject: Reply with quote
https://www.ebay.co.uk/itm/16x10-tongue-and-groove-shed-solid-sheet-floor-/110869212068?pt=UK_Home_Garden_Garden_Structures_Fencing_CV&hash=item19d051eba4
yen_powell
PostPosted: 20:17 - 20 May 2012    Post subject: Reply with quote
I once priced up a concrete floor for a mate's barn (he was going into cider production and needed something better than a dirt floor) and it worked out cheaper to get Readymix to deliver than to mix it himself.
XT1200Z and a DR350 in bits
UnspeedySam
PostPosted: 20:54 - 20 May 2012    Post subject: Reply with quote
About the same size as what I'm getting for £120 but thanks. Smile
UnspeedySam
PostPosted: 20:55 - 20 May 2012    Post subject: Reply with quote
I guess if I dig the hole and do the prep it'll probably be quite cheap. Can they deliver to a back garden with only a little side-way for access though?
Tenko
PostPosted: 21:08 - 20 May 2012    Post subject: Reply with quote
Sorry to add the boring stuff, but you also need to read this:
https://www.planningportal.gov.uk/permission/
before you start. If you don't, you could end up having to take it down.....
Amreet
PostPosted: 21:17 - 20 May 2012    Post subject: Reply with quote
Prefab concrete garages can go bad very quickly, we have one and the metal rods inside rust away frighteningly fast and one bad frost leaves chunks of concrete missing. Would be much better to build a block/brick structure.
UnspeedySam
PostPosted: 22:13 - 20 May 2012    Post subject: Reply with quote
Thanks for the link. I've done a bit of reading on the subject and it seems that I fall within the bracket of 'temporary structure' so no planning permission. I will have a chat with my local planning office to make sure though.
UnspeedySam
PostPosted: 22:14 - 20 May 2012    Post subject: Reply with quote
True. But if the worst comes to the worst and the thing becomes knackered, it has cost me £120 and I already have a concrete base to build something more permanent, which requires planning permission but will last me longer.
MG
PostPosted: 22:31 - 20 May 2012    Post subject: Reply with quote
I was under the impression that if you follow the rules on height, positioning, maximum size etc, then you don't need planning permission even if you made it out of bricks.
'03 Honda Cityfly 125 > '02 Honda CB500S > '98 Honda CBR600F
Cunnington
PostPosted: 22:32 - 20 May 2012    Post subject: Reply with quote
I would recommend a 150mm thick slab with some crack control reinforcement - steel mesh. You need to get the base right (level and square, no ponding at door) otherwise you will never get the garage right.
Based upon a 16' x 10' garage, with a 6" thick slab, you are looking at just over 2 cubic metres of concrete.
Standard readymix wagons hold 6 cube, therefore you have to pay a part load charge (the profit on the concrete you haven't ordered), which makes small volumes of readymix fairly pricey. You can go down the minimix route which use 3 cube wagons, but the rate for them is higher than standard wagons.
If you have a restricted access, you may also get stung with standing time - from memory, they allow 10 minutes per cubic metre, therefore you are looking to place around 5 tonnes of concrete in less than half an hour.
On another topic, if you are buying a new door, I recently replaced my up and over for a Gliderol roller door (£400 delivered from fleabay). The headroom is slightly compromised, but the inside space that you free up is well worth it in my eyes.
'82 C50, '81 CB100, '84 GS125, '95 NTV650, '00 Bandit 600, '06 SV650, '56 Z1000, '89 NTV600
The Shaggy D.A. wrote: "You are invisible. Those who can see you are trying to kill you."
UnspeedySam
PostPosted: 22:48 - 20 May 2012    Post subject: Reply with quote
Thanks for the detail. I'll probably just do it myself then. Sounds like it will get expensive otherwise.
On the subject of doors I have no idea what I'm doing. If the current one is ok then I'll keep it. Don't want to spend a fortune on it at the moment. Especially as the garage is a good few years old and has some cracked bricks already. No idea whether I'll be able to find some bricks of the right size to replace them.
The last post was made 14 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 134.22 Kb
