Any insight on the FZR400 3TJ
PostPosted: 16:04 - 20 May 2012    Post subject: Any insight on the FZR400 3TJ Reply with quote
Some nice person has just offered me their bike, free of charge as its sitting in their garage doing nothing Mr. Green
Ideally I'd track it...but I'd like a road bike for the summer.
Its got 44k on clocks but had a 16k engine popped in 2 years ago and has covered 450 miles in that time.
It has 12 months MOT and 1 month tax...so its a fairly ok condition bike.
I've not really had a 400 before, the one I borrowed was shereens VFR and that was awesome, handled superb! But is the FZR that good of a bike?
Looking at reviews they are ~60hp, rev to about 14k and pretty reliable...but a personal insight would be nice!
T0MMY
PostPosted: 16:54 - 20 May 2012    Post subject: Re: Any insight on the FZR400 3TJ Reply with quote
Well how good does it need to be to be good value at £0?
I think they look absolutely gorgeous but I preferred my CBR400RR to ride. Nearly bought one with an FZR600 engine recently...
ZX6R + CBR600RR
V2
PostPosted: 17:23 - 20 May 2012    Post subject: Reply with quote
If you dont want it ill have it Laughing
Al
PostPosted: 19:15 - 20 May 2012    Post subject: Reply with quote
I've had my 3tj for over 6 years now, haven't had any reliability problems, other then the rec/reg dying and taking out the battery.
I'm not sure what info you are really after but they are typical 400cc sportsbikes. small, uncomfortable, revvy and quite good fun. The engine is a bit electric sounding, although it makes a nice high pitch scream when you have it pinned on track.
Not an ideal track bike as they are probably more like 50-55hp which is probably half the power of most other bikes you'll come across on track, it doesn't take away from the fun but can be a little frustrating if you get stuck behind somebody a tiny bit slower then yourself as they keep coming back past you on the straights Razz
I've done over 10 trackdays on mine, toured around Europe and used it to commute. Great little bike really.
I'll have it if it's free, I need some spare bits Mr. Green
Should probably mention that I'm only 5'5 and 9.5st so this may be why the suspension and size works for me.
https://img.photobucket.com/albums/1003/big_al/Eurotrip%202011/P1010140.jpg
https://img.photobucket.com/albums/1003/big_al/af4590b0.jpg
Yamaha FZR400RR 3tj
My Instagram Thingy
PostPosted: 20:30 - 20 May 2012    Post subject: Reply with quote
Fucking hell that looks tiny Laughing
I'm 5' 11 ish...but loved the VFR400 size wise.
I'm not knocking it till I've tried it, but it was more are there any bad issues like things corroding faster than most, what tends to fail quickly etc.
Any idea on mpg?
That photo in the sun on the beach... love it, where was that Thumbs Up
Al
PostPosted: 20:51 - 20 May 2012    Post subject: Reply with quote
I''ve only sat on an nc30 but it felt the same size.
The down pipes rot and the exup valves seize up but there are normally 2nd hand ones available on ebay for fairly cheap and if the bikes free.
I think I get about 50-55mpg on normal road riding.
The photo is taken in Cannes Thumbs Up
Yamaha FZR400RR 3tj
My Instagram Thingy
PostPosted: 21:04 - 20 May 2012    Post subject: Reply with quote
Sounds pretty good then!
Any way on checking exup? Obviously need to inspect the exhaust...been there a while!
Nice picture, tried to look at album but its passworded Laughing
Hopefully its all ok and needs minimal work Praying
Al
PostPosted: 17:36 - 21 May 2012    Post subject: Reply with quote
I don't know loads about the EXUP valve as I removed mine when my exhaust cracked and replaced it with a non exup valve s/s system.
You lose a little low and mid range power without the valve but it seems to rev a bit cleaner at higher revs.
It's just a little servo motor that moves some cables to open and close a flap in the exhaust, I think it starts to open at about 7000rpm and you could feel a slight change in acceleration, not a 'yo v-tec just kicked in' change Smile just a small one.
The suspension will more then likely be knackered like most 400's. A common mod is to fit the 06-07 R6 rear shock which is a little shorter then the FZR one, you can buy/make an adapter to make it fit. I don't think there is any straight swap for the front end though, as most people just rebuilt the originals with stiffer springs and thicker oil.
The photobucket photos you were trying to access are in here Thumbs Up
www.bikechatforums.com/viewtopic.php?t=227012
Yamaha FZR400RR 3tj
My Instagram Thingy
hawky66
PostPosted: 08:06 - 22 May 2012    Post subject: Reply with quote
Great bikes the 3tj..
so much so i'm shifting my fz750 to grab one yet again for the road b road blasts..
Had quite a few and says somthing that i keep going back to them as road bikes as so much fun ..
I also have a full blown 74bhp kitted race bike and one on the bench at the mo with thundercat engine being installed Mr. Green ..
Once the fz's gone i will have 3 lol..
std exhaust's rot and just make sure if you unplug or run without the exup connected you get the cdi de-restricted as this takes out the error safe mode etc..
use good oil...service properly...maintain brakes...loadsa miles with smiles. Thumbs Up
garth
PostPosted: 08:40 - 22 May 2012    Post subject: Reply with quote
You bastard, who gives that away for free?
hawky66
PostPosted: 08:59 - 22 May 2012    Post subject: Reply with quote
_Iain_ wrote:
This!
Got anymore lol Laughing
PostPosted: 09:05 - 22 May 2012    Post subject: Reply with quote
I've got one as a track bike. Its very very very good. Its up there with the best bikes I've ridden on track. A mite underpowered perhaps, but for technical circuits it is an absolute dream.
It takes the same size tyres as an SV650 so minitwin race scrubs fit well.
The EXUP valve bushes are expensive, and parts can be a pain. Getting an air filter for a 1989 3TJ is very difficult and I had to pay a lot of money for one.
However, they are really really good bikes, and as long as you get one in good nick will make an excellent trackbike and reasonable toy roadbike. I wouldn't want to use one as my daily as its so uncomfortable.
PostPosted: 09:38 - 22 May 2012    Post subject: Reply with quote
Hmm technical circuits, currently my only locals are Brands and Lydden, I'll obviously be happy to travel if its a good bike and lasts.
Its a 1992, I think. Its an old workmates...he owes me a few little favours so wiping clean with this Mr. Green
They really that uncomfortable? I suppose about 30 mins in the seat racing won't be too bad though? If I was to say get an exhaust system minus the EXUP, would solve the issue but would I lose "track usable" power at the same time?
Will be going to look at it tomorrow Thumbs Up
PostPosted: 09:42 - 22 May 2012    Post subject: Reply with quote
If the EXUP works, keep it.
The 1992 has adjustable forks and is easier to get filters for etc.
Damn you!
PostPosted: 09:51 - 22 May 2012    Post subject: Reply with quote
Laughing I'm still sceptical as its a 400 IL4, the last one I rode was a CB400SF and from memory it was a nice ride, smooth and had some power in the mid range but wasn't ballistic.
Damn me Laughing
UnspeedySam
PostPosted: 06:50 - 23 May 2012    Post subject: Reply with quote
Damn me Laughing
When you get rid of it, give me a pm! Really like these bikes, and I can use my girlfriend who will hopefully be doing her test soon as an excuse to buy one. Razz
T0MMY
PostPosted: 09:08 - 23 May 2012    Post subject: Reply with quote
Damn me Laughing
No, you're right, it'll be rubbish.
Tell you what, as a favour to you, I'll get rid of it for you and I won't charge you a penny Whistle
ZX6R + CBR600RR
PostPosted: 09:13 - 23 May 2012    Post subject: Reply with quote
Oh T0MMY, that would be awesome if you could take it. I mean for free too?! Such a nice guy Laughing
T0MMY
PostPosted: 10:45 - 23 May 2012    Post subject: Reply with quote
Yes, you're right...it is a bit generous.
Tell you what; You can pay my fuel costs to collect and just chuck me a crate of beers...
ZX6R + CBR600RR
mistergixer
PostPosted: 11:19 - 23 May 2012    Post subject: Reply with quote
I want a cheap bike, sell it to me.
Profit.
Space Monkey #7
PostPosted: 11:48 - 23 May 2012    Post subject: Reply with quote
Thats one sick deal for me. Laughing
mistergixer... I'll pm when I get it... It might be a shed but it might be alright Laughing
hawky66
PostPosted: 12:07 - 23 May 2012    Post subject: Reply with quote
Damn you!
Agreed with the exup but wont be of any use for tracks!!
Only the rrsp's came with adjustable forks..but you never no...could have em in there and that would be result no2 Mr. Green
mistergixer
PostPosted: 12:45 - 23 May 2012    Post subject: Reply with quote
Don't mind a shed.
Space Monkey #7
The last post was made 14 years, 176 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 132.74 Kb
