burgman hid's query
jpderv
PostPosted: 10:03 - 24 May 2012    Post subject: burgman hid's query Reply with quote
hi everyone i have a suzuki burgman 125 2005 model as it is the lights are great but i usually upgrade all my bikes to hids for slightly more power most scooters usually only have one light going at a time but this one has two going constantly.
the bulbs that are in the bike at the moment are halogen h4 35w and im wondering if i can run two hid's which are also 35w theoretically it should work but wanted to confirm it first.
thanks in advance Smile[/b]
1st bike= skyjet 125 2nd bike= suzuki ts 50 x 3rd bike= peugeot speedfight 2 100cc 4th bike= suzuki katana 50cc 5th bike honda cg125 6th bike = yamaha dt125 r 7th bike honda rebel 125cc 8th bike hartford vr 125cc current bike = honda mtx 125
EazyDuz
PostPosted: 10:44 - 24 May 2012    Post subject: Reply with quote
Gonna drain a lot of juice but should be doable. Bit OTT having 2 HID kits though imo
jpderv
PostPosted: 11:55 - 24 May 2012    Post subject: Reply with quote
yeah i just thought as the bike had 2 bulbs running all the time it would be ok with 2 hid bulbs running aswell just remembered these use more current than halogens.
PostPosted: 13:12 - 24 May 2012    Post subject: Reply with quote
They use less power than standard bulbs.
EazyDuz
PostPosted: 13:22 - 24 May 2012    Post subject: Reply with quote
Not on startup
map
Mr Calendar
PostPosted: 13:36 - 24 May 2012    Post subject: Re: burgman hid's query Reply with quote
jpderv wrote:
hi everyone i have a suzuki burgman 125 2005 model ...wondering if i can run two hid's which are also 35w...
It may be possible but IIRC just changing the bulbs isn't legal.
This is because the the beam generated is wrong because the reflector bit and the light is shows is designed (and approved) for whatever the default bulb is. Just changing the bulbs changes this so isn't right.
However, I think if you change the whole lens assembly then it's ok.
Can do it but might be picked up on come MOT time, might not. If stopped by the police and they want it looked at request a deferred inspection.
I mention this because I believe the law still specifies a certain wattage for bulbs yet with cars using LEDs this obviously isn't the case (unless I missed an update).
jpderv
PostPosted: 13:57 - 24 May 2012    Post subject: Re: burgman hid's query Reply with quote
yeah i know what your saying about the light pattern police around here dont give a toss and for mot i just slip the originals in again. i may just try it and see its the only way il know for sure thanks for the advice guys.
The last post was made 14 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 59.99 Kb
