clutch not working
Usher4566
PostPosted: 13:01 - 25 May 2012    Post subject: clutch not working Reply with quote
My clutch when pulled in does not fully engage .so wheel turns when clutch pulled in.I've ordered plates and springs do you think they will cure it.
New cd200 benly owner
fatjames
PostPosted: 13:10 - 25 May 2012    Post subject: Reply with quote
Probably just need to do a routine adjustment to the clutch cable.
Martay
PostPosted: 13:17 - 25 May 2012    Post subject: Reply with quote
Id certainly try adjusting it properly before ordering parts. If you cant, pop it in somewhere,quick adjustment for beer money Wink
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
Usher4566
PostPosted: 13:46 - 25 May 2012    Post subject: Reply with quote
Hi I've already tryied adjusting cable .not happening
fatjames
PostPosted: 14:16 - 25 May 2012    Post subject: Reply with quote
Usher4566 wrote:
not happening
Tell us some more info. Not happening, as in, you don't know what to do, or you can't do it, or it makes no difference?
Did you try just at the bar end, or both?
Usher4566
PostPosted: 14:42 - 25 May 2012    Post subject: Reply with quote
Tryied both ends doesn't make much difference .any tips ?
PostPosted: 15:22 - 25 May 2012    Post subject: Reply with quote
Do it properly. If the clutch is got released you don't need new plates.
Usher4566
PostPosted: 15:45 - 25 May 2012    Post subject: Reply with quote
Any tips chris or any body
PostPosted: 17:15 - 25 May 2012    Post subject: Reply with quote
Hold on, quick point do you mean the bike pulls you forward with the clutch in or when the wheel is off the ground it turns?
Usher4566
PostPosted: 17:40 - 25 May 2012    Post subject: Reply with quote
Well when wheel is off ground yea it turns .and when its on ground you can here it trying to pull but not pulling .both with clutch in
Wet clutch = viscous coupling = wheel will turn while the bike's up on its stand.
If you can stop it easily enough with your hand, then there's no problem.
Usher4566
PostPosted: 17:44 - 25 May 2012    Post subject: Reply with quote
For got to say bit of slipping when give it hard .but not if change gear graceful
Usher4566
PostPosted: 17:45 - 25 May 2012    Post subject: Reply with quote
How would you guys adjust from fitting new cable let me start from basics and see
fatnfast
PostPosted: 20:12 - 25 May 2012    Post subject: Reply with quote
You need to set/check the clutch pushrod first. Slacken the cable at both ends. Where the cable goes into a side engine case you will find the locknut/screw for the pushrod. You may have to remove the cover, you may have a large rubber bung covering it. Undo the locknut and back it off a few turns. With a screwdriver turn the slotted head adjuster until it lightly seats. Now back it off a quarter of a turn. Hold it in this position and tighten the lock nut. Finally adjust the cable to give you the correct freeplay (around 5mm at the lever). This is a general guide, you have got a workshop manual ? From you sig at the bottom I take it we are talking about a cd200? I doubt its clutch plates or springs as these are plod to work type bikes and p/o generally dont slip clutches and hoik wheelies Smile
Usher4566
PostPosted: 21:10 - 25 May 2012    Post subject: update fixed Reply with quote
Just went out and fitted.New plates and springs works great many thanks for advise wat a great clutch
Usher4566
PostPosted: 07:36 - 26 May 2012    Post subject: Reply with quote
what do you meen clutch on small bikes get over used as small engine .they didn't just have to be for work they can be fun too .
The last post was made 14 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 91.83 Kb
