is my engine okay to paint now ???
mickfulton
PostPosted: 16:19 - 25 May 2012    Post subject: is my engine okay to paint now ??? Reply with quote
I am stripping paint from an engine using nitromors, wire brush and wet dry sand paper and think I have stripped it enough. However, there are some areas that are a little tarnished. This is shifting a little bit with autosol metal polish. Do I need to completely remove the tarnished areas before painting. I want a decent job done and time is a luxury I have ( but no money to spend on professionals unfortunately.)
The pictures are what I hope to begin painting on, is it okay ? Any help is greatly appreciated.
Thanks,
Mick
Current half-cars :2004 SV650, VX535 1991
Exes: YBR 125 2007,GPZ500S 1998
shippy
PostPosted: 20:10 - 25 May 2012    Post subject: Re: is my engine okay to paint now ??? Reply with quote
Thanks,
Mick
Pretty much looks good to go.
Make sure you do a few light layers of metal primer first.
Remember its better to do many light coats that one heavy one Thumbs Up
andym
PostPosted: 21:17 - 25 May 2012    Post subject: Reply with quote
the second picture looks like it has some deep scratches in it. you might need to put several layers of primer and keep sanding it down to make it smooth again... but then I've only brush painted my engine
Ariel Badger
PostPosted: 21:50 - 25 May 2012    Post subject: Reply with quote
You will need to use an etching primer JFGI
mickfulton
PostPosted: 00:11 - 26 May 2012    Post subject: Reply with quote
Thanks so far guys......why etching primer or indeed why not ? I can only find cock n. balls videos on this topic. I'm a man of science so any chance of a decent tutorial link with lots of info as im in the dark here =D
karthead
PostPosted: 05:11 - 26 May 2012    Post subject: Reply with quote
mickfulton wrote:
I can o my find cock n.
What was that? you cant find your cock? i think you just might have a worse problem on your hands than painting your engine... Wink
Nick_Giles
PostPosted: 10:27 - 26 May 2012    Post subject: Reply with quote
Aluminium needs etching primer to make a strong bond between it and the final paint.
If you don't there is a high chance all your hard work will have been wasted as your new paint layers will quickly flake off.
Nick.
The last post was made 14 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 53.91 Kb
