| JustGraham |
 JustGraham Could Be A Chat Bot
 Posted: 21:01 - 26 May 2012 Post subject: Yamaha diversion s 600 98 new clutch fitting ? |
Looking for a little advise guys, my dad has fitted the new clutch, but when you pull the clutch leaver inn it doesn't disengage, do you know what could be the problem ?
Thanks
yes the the plates have been in oil  |
 Posted: 21:57 - 26 May 2012 Post subject: |
Has the mechanism correctly "caught". From memory with the Divvy the mechanism on the clutch cover works on a rack and pinion setup to pull a top hat shaped part on the clutch release bearing. Trouble is this is a bit of a pain to get hooked on (not that difficult, just mildly tricky if you don't realise what it is doing). However I would expect this to leave the clutch lever fairly loose.
However the Divvy thrust bearing can also be quite short lived. When these go you can land up with the gearbox stopping rapidly when you pull the clutch. Possibly caused by people following the Haynes manual (it tells you to lube the thrust bearing with oil, while the Yamaha manual says to use moly grease)
| JustGraham |
 Posted: 16:46 - 27 May 2012 Post subject: |
Yes it'll move a bit, but it should have a flat washer and a flat thrust bearing under it. If these are missing it won't disengage. ____________________ a.k.a 'Geri'
| Pol Anorl |
 Pol Anorl Banned
 Posted: 19:44 - 27 May 2012 Post subject: |
had this problem loads!
put it on centre stand and start it up
put it in 1st gear
Make sure back wheels off the floor!
give it some revs then stomp reasonably hard on the rear break
should losen it up near instantly. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
 Posted: 20:24 - 27 May 2012 Post subject: |
Well, we've had plenty of haha's out of you, and now we've had the dumb too  ____________________ a.k.a 'Geri'
| JustGraham |
 Posted: 09:18 - 28 May 2012 Post subject: |
Thanks for your replies guys
My dad put it back together again
Someone sujusted what hahadumball wrote but didn't mention about the braking bit.
put it in 1st gear
Works fine now Woop Woop |
| JustGraham |
 Posted: 09:23 - 28 May 2012 Post subject: |
Thanks for all your replies guys, much appreciated as always folks
| Pol Anorl |
 Pol Anorl Banned
 Posted: 09:35 - 28 May 2012 Post subject: |
So my method fixed it
told you it works
and Pete. i do have some brain cells
unlike my dad who had this issue once after the other xj was stood for ages, put it in gear and nearly fucked off down the road lol ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| JustGraham |
The last post was made 14 years, 110 days ago. Instead of replying here, would creating a new thread be more useful? |
