something i found strange
U_W v2.0
PostPosted: 15:09 - 31 May 2012    Post subject: something i found strange Reply with quote
so if you change to LED indicators you need a LED flasher unit because its the heat in the current that makes the indicators flash.
well i THOUGHT that if you put LED dash bulb in the indicator bulb sockets in your dash you'd still need a LED flasher unit and change to LED indicators...
well i thought i'd rip my dash apart, install the LED dash bulbs into the indicator bulbs and well it all works perfectly, the leds flash, the indicators flash.
all to the correct timing.
i thought it wouldnt work as your putting resistors in the circuit.
any ideas why it DOES work?
edit: im not complaining, now i can see the indicators in the dash, but just trying to work out why it does work because i cant figure it out lol
PostPosted: 15:16 - 31 May 2012    Post subject: Reply with quote
Is it because they have built in resistors?
U_W v2.0
PostPosted: 15:18 - 31 May 2012    Post subject: Reply with quote
well the led dash bulbs have the resistors in them and the current just passes through the bulbs. so the current leaving the led bulbs is restricted.
i guess you can see why i find it a little wierd it all worked fine lol
map
Mr Calendar
PostPosted: 15:37 - 31 May 2012    Post subject: Reply with quote
Dilligaf_NO wrote:
well the led dash bulbs have the resistors in them and the current just passes through the bulbs...
I thought this was now the case for all LED replacement bulbs whether just for the dash or in the indicators, tail light, brake light, etc.
U_W v2.0
PostPosted: 15:42 - 31 May 2012    Post subject: Reply with quote
depends on if your bikes indicators or parallel or serial i suppose but yes, the current will go through the led bulb and what leaves would be restricted due to the build in resistors.
lihp
PostPosted: 16:54 - 31 May 2012    Post subject: Reply with quote
Not all indicators require resistors fitting, the flash rate on some systems is controlled by load on the circuit, others externally by means of flasher relays etc.
If the flash rate is controlled by an external system then changing to LEDs will not require any additional modifications.
The last post was made 13 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 48.03 Kb
