| Compo |
 Compo Nova Slayer
| Fizzer Thou |
| neatbik |
 neatbik World Chat Champion
 Posted: 10:38 - 01 Jun 2012 Post subject: |
I use Moly grease too.
Just get a tub of it, i have one i bought 10 years ago and its still a quarter full.
| Compo |
 Compo Nova Slayer
 Posted: 11:48 - 01 Jun 2012 Post subject: |
Moly it is then lads, if you been through what ive been through getting this linkage off the frame bolts and bearings out you'd realise my concerns.
thanks  |
| Johnser |
 Johnser Renault 5 Driver
 Posted: 22:26 - 01 Jun 2012 Post subject: |
Moly (molybdenum disulfide) grease is particularly good at stopping dry contact (and therefore wear) between bearing surfaces
https://www.molyslip.co.uk/theory_of_lubrication/
what this translates to is that when normal greases have been all spooged out the side of the bearing, the moly grease should continue to provide some more protection as the surfaces have some chemically adhered lubrication...
what this translates to is that if you're going to forget to grease the bearings regularly, moly grease will help extend their life. If you do it regularly, the benifits of the moly are unlikely to be realised - especially in a needle bearing which unlike a a simple bush tend to hold on to their grease better (always some space for grease to lie between the rollers) |
| stinkwheel |
 Posted: 01:24 - 02 Jun 2012 Post subject: |
You don't say what application these bearings are being used in but I'm going to assume a shock linkage of some sort.
In which case one of the best things you could do is drill and tap the linkage and fit a grease nipple in an appropriate place while you have it apart. Then you can pump grease into them every time you do an oil change.
Failing that. The packs of moly grease they use for car CV joints is absolutely superb. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Compo |
 Compo Nova Slayer
The last post was made 14 years, 139 days ago. Instead of replying here, would creating a new thread be more useful? |
