Gilera DNA 50 won't start! Help please
GDNA
PostPosted: 12:56 - 01 Jun 2012    Post subject: Gilera DNA 50 won't start! Help please Reply with quote
I bought my Gilera DNA 50cc couple of days ago, its a 03 plate and the bike started first time through the kick start when I was buying it from the previous owner. When I got home with the bike it wouldn't start and has been like this since now and when trying to start the bike with the button it made a weak noise so I replaced the battery with a new one and now it sounds like it's about to start but doesn't.
The previous owner told me that it has problems getting the fuel through this orange pipe but he said it wasn't blocked. https://s15.postimage.org/cpi38ay4b/Brent_20120601_00141.jpg
Also I noticed that there's a black pipe sticking out not connected to anything which leads to the fuel tank.
https://s16.postimage.org/fgr7h7kdx/Brent_20120601_00140.jpg
Leads to:
https://s7.postimage.org/mirfsj0or/Brent_20120601_00143.jpg
I have no experience in fixing bikes so I don't know where the carb, spark plug or things like that are located so please help in a detailed way, thank you.
at106
PostPosted: 17:45 - 01 Jun 2012    Post subject: Reply with quote
Does the bike have a fuel tap? If not apply a vacuum to the hose not connected to anything (you can use a syringe). If fuel goes into the carb then that spare hose should be connected somewhere either on the carb or inlet manifold.
lukamon
PostPosted: 19:35 - 01 Jun 2012    Post subject: Reply with quote
You need to ckeck the fuel tap. easy enough to check. there are two pipes from the bottom of the fuel tank. disconnect the fuel pipe (it wont leak) then follow the other pipe to the carb and disconnect it. when you suck on this tube hard (oo-er missus) fuel slow flow out of the tank, and stop when you stop.
btw, how many miles has it done?
killa wrote: Im an ass man myself
Beez
PostPosted: 22:29 - 01 Jun 2012    Post subject: Reply with quote
Black pipe is your overflow if i remember correctly.
grahamd1
PostPosted: 14:58 - 02 Jun 2012    Post subject: Reply with quote
the Gilera is the same as the zip, that pipe needs changing, it must be air tight, it connects from the inlet (outlet of the carb) to the fuelcock (fuel tap). The gilera (like the zip and many others) use a vacuum automatic petrol tap, when negative pressure is applied to the tap, fuel flows, hence no fuel, no vacuum. ie fuel/air being drawn into the engine, I bet if you undue the screw at the bottom of the carb (the float bowl) you find nothing in there....
Get a new pipe (you can buy similar called tygon in model aircraft/boat shops its used as petrol fuel tubing on models and will do fine. Connect it to the fuelcock, suck for a second and check if fuel now flows down the yellow feed pipe to the carb. Keep the vacuum going till fuel runs out of the overflow from the carb bowl (you will see it dripping on the floor), now put the pipe onto the manifold inlet (carb outlet) and try starting it.
XV1100, XV750
CD175 (Rebuild)
CF70 (Chaly - Rebuild),
GDNA
PostPosted: 17:12 - 03 Jun 2012    Post subject: Reply with quote
Took it to a garage and turns out it was the fuel pump, the guy didn't replace it he just fixed it for me. It was working fine for a couple of hours but then died out again! Now it won't start just like before, would I need to replace the fuel pump or just the fuel pipe?
Also, the oil needs changing and I was wondering if I would be able to use 'Tesco petrol mineral motor oil 10w/40', if not then which type of oil? (oil and fuel tank are seperate).
lamnea
PostPosted: 20:31 - 03 Jun 2012    Post subject: Reply with quote
if it is a two stroke (sounds like as it has a fuel and an oil tank) then you need to use two stroke oil and not four stroke in that tank.
Honda Vision Ne50mff!
grahamd1
PostPosted: 10:08 - 12 Jun 2012    Post subject: Reply with quote
WHAT THE F**** there is NO fuel pump on that model. Read my post above and test the fuel tap/valve
XV1100, XV750
CD175 (Rebuild)
truslack
PostPosted: 11:18 - 12 Jun 2012    Post subject: Reply with quote
There is a vacuum fuel pump on the DNA, it is a commonly failing item. Replace it, they're relatively cheap.
grahamd1
PostPosted: 12:33 - 12 Jun 2012    Post subject: Reply with quote
Its not a pump, its a valve
https://www.ebay.co.uk/itm/Gilera-DNA-50-Fuel-Petrol-Tap-/270580942792?pt=UK_Motorcycle_Parts&hash=item3effe187c8
https://i.ebayimg.com/22/!Btm7YyQEGk~$(KGrHqIH-EYEvov7vQY4BL8srwGkTQ~~_35.JPG
XV1100, XV750
CD175 (Rebuild)
truslack
PostPosted: 13:00 - 12 Jun 2012    Post subject: Reply with quote
Not the tap in the tank.
https://www.ebay.co.uk/itm/GILERA-DNA-50-GENUINE-FUEL-PUMP-/270710981002#ht_1781wt_905
lukamon
PostPosted: 18:29 - 12 Jun 2012    Post subject: Reply with quote
They definitely havve a pump. The fuel tank is lower than the carb. Replace pump, job done. Does it work if you brim the tank with fuel? Just a thought.
lukamon
PostPosted: 18:31 - 12 Jun 2012    Post subject: Reply with quote
Also, fail. Fuel will not cone out of the overflow.if you suck on the tap pipe, that's what the needlevalve stops happening.
lukamon
PostPosted: 18:33 - 12 Jun 2012    Post subject: Reply with quote
lukamon
There is a gap of 3 years, 59 days between these two posts...
Jones11292
PostPosted: 14:31 - 11 Aug 2015    Post subject: Dna Reply with quote
I'm having a similar problem with mine Iv tryed replacement lines and tryed self vacuuming still no joy it will start and run for all ov 30seconds but as soon as you touch the throttle it dies out. Any advice would be really helpful
D.jones
The last post was made 11 years, 28 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 88.49 Kb
