Honda cb250 won't start
TattooedBandi...
PostPosted: 21:22 - 15 Jun 2008    Post subject: Honda cb250 won't start Reply with quote
I recently had a problem with my electrics cutting out and have fixed the problem (i think). While trying to fix the electrics I ran the battery flat so the bike wouldn't start. Managed to push start OK. Charged battery overnight then tried starting and fired immediately. I left the bike for a few hours and then tried to re-start and now it won't fire. Checked battery seems fine. It seems to want to go but it doesn't quite get there. Spark plugs appear to be sparking OK. I tried push starting with no luck, but after a little while of trying it let out a huge backfire and a lot of black smoke. I'm a bit worried that maybe i've done more damage.
Any help would be hugely appreciated. It's a 1999 Nighthawk type model. Thanks.
TattooedBandi...
PostPosted: 23:05 - 15 Jun 2008    Post subject: Reply with quote
Never mind. Finally managed to fix it.
Maybe admin can delete this for me. Thanks.
hmmmnz
PostPosted: 05:56 - 16 Jun 2008    Post subject: Reply with quote
,may be you could say what it was, so next time some one with a cb250 might be able to search for the answer Very Happy
the humans are dead
I kick arse for the lord
There is a gap of 3 years, 351 days between these two posts...
Houseparty
PostPosted: 13:07 - 01 Jun 2012    Post subject: Honda Cb250n 1982 no electrics whatsoever... Reply with quote
hiya im new to this and can seem to find where to start a new post so i hope its ok to carry on from here... anyway...
I have a 1982 cb250n in good running order right up untill i got it Mot,d, it actually passed and i was quite suprised, all they had to do was fit some rear indicators.... anyway i picked it up and rode it home but broke down about a miles away, the bike just instantly died like some sort of electrical fault, i pushed it home and it just would no start, i removed the spark plugs and held them against the cylinder head and no spark at all when engine turned over..... i replaced the plugs and now i dont have electrics full stop, no ignition lights nothing?? the battery is fine and tested and i have had a go at fault finding and here is what ive found and got stuck with...
i have 12v from battery to connector block behind headlight that goes to the ignition switch, once i turn the ignition switch on the 12v goes to zeroand when off i have 12v back... so i disconnected all connector blocks behind headlight and then turned on ignition and my 12v stayed, i replaced the connector blocks one by one untill the 12v went to zero again and the fault seems to lay with the connector block supplying the indicators etc, i unplugged all indicators front and back and i still loose the 12v so it cant be them.... this is how far ive got to and i think if i look any more im may well explode lol... any help would be sooo appreciated as this is now driving me insane!!
thanks peeps ever so much...
houseparty
No Muff Too Tuff...
The last post was made 13 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 40.63 Kb
