Help me mount this sissy rack bag for karma
EazyDuz
PostPosted: 18:02 - 02 Jun 2012    Post subject: Help me mount this sissy rack bag for karma Reply with quote
Got this leather bag for my bike, but the straps it comes with dont work well. Mainly because my sissy bar is stubby and not long like some other bikes, so the straps cant go over it. So i need a solution on how to fix it to the bike securely, but at the same time so its easy to remove. Pics to show what i mean:
Was going to clip this together under the leather sissy back rest but its too short even on its longest setting:
https://i605.photobucket.com/albums/tt134/Kurt_V/SV206346.jpg
https://i605.photobucket.com/albums/tt134/Kurt_V/SV206345.jpg
https://i605.photobucket.com/albums/tt134/Kurt_V/SV206347.jpg
https://i605.photobucket.com/albums/tt134/Kurt_V/SV206348.jpg
Any advice would be great. Im thinking maybe a thick luggage strap going from between the back plate and leather back rest, looped under the sissy bar and over the top and tightened, holding the bag in place. Any other ideas?
EazyDuz
PostPosted: 20:08 - 02 Jun 2012    Post subject: Reply with quote
would a bungee cord do the job? Though would look a bit naff
snikks
PostPosted: 20:34 - 02 Jun 2012    Post subject: Reply with quote
Could you not loop it so that the strap is wrapped around the bars on both side, then adjust it good and tight?
That would prevent it from sliding up and coming off, which seems to be your main problem from what I can see.
- CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F
EazyDuz
PostPosted: 20:38 - 02 Jun 2012    Post subject: Reply with quote
No, its too short to even do that. Its literally been designed to hug close up to a high up sissy bar, so its no good realy. I could cut the clips off and replace them with some other mounting hardware, or extend them somehow?
nowhere.elysium
The Pork Lord
PostPosted: 20:42 - 02 Jun 2012    Post subject: Reply with quote
Don't buy bags that are designed for long sissy bars? Seriously - the design of that indicates that most of the anchoring work is done by the large elastic straps, that would presumably have the chromework hidden behind them. You're not going to get it to sit securely, at least not without some major surgery to either the bag or the bar.
PostPosted: 21:11 - 02 Jun 2012    Post subject: Reply with quote
You could jubilee clip some flat bar to each upright of the backrest to extend it as an A frame, but it'll be fugly. If the bag is intended to be a permanent fixture, I'd be tempted to cut the short rest off and get some bar bent to suit to slot in the holes left.
EazyDuz
PostPosted: 21:13 - 02 Jun 2012    Post subject: Reply with quote
No its not permanent. It came with a barrel bag which i will use most of the time, the large one is for road trips/staying round peoples houses/a lot of shopping, so not used all the time. So it doesnt need to be fixed on amazingly, just easy enough to remove and put on when needed.
I was thinking a thick luggage strap all around it, and maybe a black bungee cord going from left to right and hooked on both sides of the rack?
EazyDuz
PostPosted: 22:33 - 02 Jun 2012    Post subject: Reply with quote
anyone else got any ideas?
Rob W
PostPosted: 22:43 - 02 Jun 2012    Post subject: Reply with quote
Surely Warped could weld that, I mean he invented plastic coated teryllium carbonic alloy welding wire after all?
yambabe
PostPosted: 02:00 - 03 Jun 2012    Post subject: Reply with quote
Turn it round and have it on the rear of your seat rather than the rack. Still have the elastic bit over the sissy bar but as the bag will sit lower it may grip better. If it doesn't, possibly cable tie or strap the top elastic bit to the top of the sissy bar.
EazyDuz
PostPosted: 08:16 - 03 Jun 2012    Post subject: Reply with quote
Thanks, theres a longer sissy bar going on Ebay at the moment, fairly local pickup too, might just get that lol
EazyDuz
PostPosted: 09:46 - 03 Jun 2012    Post subject: Reply with quote
although it looks a bit naff actually
Easter Bunny
PostPosted: 09:52 - 03 Jun 2012    Post subject: Reply with quote
What ever you do stick a cargo net around it, I'd rather it looked a bit shit & I had all my stuff intact
pits
PostPosted: 09:59 - 03 Jun 2012    Post subject: Reply with quote
ratchet strap hrough handles and around sissy bar
Beelzebob
PostPosted: 10:22 - 03 Jun 2012    Post subject: Reply with quote
https://media.commsandsound.com/media/catalog/product/cache/3/image/9df78eab33525d08d6e5fb8d27136e95/8/5/853502_CO1.jpg
'09 YBR 125 -> '92 XJ600 S Diversion -> '99 Hornet 600
"Stronger than your average female lifeguard"
Nick_Giles
PostPosted: 11:52 - 03 Jun 2012    Post subject: Re: Help me mount this sissy rack bag for karma Reply with quote
You should have listened during your physics lessons at school. Laughing
Nick Wink
EazyDuz
PostPosted: 16:52 - 03 Jun 2012    Post subject: Reply with quote
So the best solution is a thick luggage strap going around the front, and another strap going across?
Suntan Sid
PostPosted: 21:43 - 03 Jun 2012    Post subject: Reply with quote
Go to Poundland, (other cheap shops are available), find a bum-bag, or similar with the same size fittings as your strap, remove strap from bum-bag and attach it to your strap, you now have a longer strap!
Job done for a quid!
WULFSTAN
PostPosted: 21:59 - 03 Jun 2012    Post subject: Reply with quote
100% agree Thumbs Up
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
jimspeed
PostPosted: 22:15 - 03 Jun 2012    Post subject: Reply with quote
this.. or I'm sure somewhere have seen extension straps for those kind of quick release fittings (rucksack's??)
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
Matt578
PostPosted: 22:50 - 03 Jun 2012    Post subject: Reply with quote
https://www.ebay.co.uk/itm/50mm-x-1-5m-Side-release-Luggage-Suitcase-TieDown-Strap-/360381668090?pt=UK_Tickets_Travel_Luggage_CA&var=&hash=item92aff89703#ht_2358wt_1396
Use that to extend your strap Thumbs Up
Your Daddy, Everyone's Friend.
flumpy7
PostPosted: 23:42 - 03 Jun 2012    Post subject: Reply with quote
What will you use it for? Carrying your assless chaps? Wink
2012 Sinnis apache
EazyDuz
PostPosted: 09:54 - 04 Jun 2012    Post subject: Reply with quote
Awesome thanks for the advice, i guess that requires sewing, better get my mum to do it lol
PostPosted: 09:59 - 04 Jun 2012    Post subject: Reply with quote
Get you mum to show you how, it's a worthwhile life skill.
[edit] Have they stopped teaching sewing in school?
EazyDuz
PostPosted: 10:26 - 04 Jun 2012    Post subject: Reply with quote
I used a sewing machine in high school, hated it.
I'll sew an extra clip and strap, onto the existing one, the short one can be wrapped around the rack bar just to hold it if it ever came off, and the new sewn in strap will go around the back rest
The last post was made 14 years, 69 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.96 - MySQL Queries: 15 - Page Size: 127.18 Kb
