Front brake
promufa
PostPosted: 14:31 - 01 Jun 2012    Post subject: Front brake Reply with quote
Hey guys,
The bike is a 02 speed four. It's got Nissin 4 piston callipers. A single line goes from the master cylinder to the right calliper and a second line goes from the right to the left calliper. I have realised that my front brake has become a bit spongy so I bled the brakes, got some contaminated fluid and a couple of small air bubbles from the right calliper.
When I moved to the left calliper, again a bit of contaminated fluid and lots of air. No matter how many times a press the lever, air keeps coming out. Also, when I press and then tighten the nipple, normally the brake fluid should not move in the draining line (should it?) In this case it does...
Is it a problem with the nipple being leaky and letting air into the system or could it be piston seals?
Thanks
'02 Triumph Speed Four
promufa
PostPosted: 22:53 - 02 Jun 2012    Post subject: Reply with quote
*bump* any ideas anyone?
CaNsA
PostPosted: 22:59 - 02 Jun 2012    Post subject: Reply with quote
flush out the old fluid, replace the copper crush washers.
Casper
PostPosted: 23:44 - 02 Jun 2012    Post subject: Reply with quote
You can heat the washers over the gas cooker until they glow and let them cool on there own for another shot. Get a bit syringe and bleed from the nipple up but it sound like you have shit under your nipple. Gee it a clean or get new ones.
https://www.youtube.com/watch?v=lBk00597EyE
Nick_Giles
PostPosted: 09:23 - 03 Jun 2012    Post subject: Reply with quote
1888 wrote:
That's a good video. Smile
The most straight forward one I have seen for that method.
Cheers, Nick
promufa
PostPosted: 13:45 - 03 Jun 2012    Post subject: Reply with quote
OK, then. Ordered new washers, bleed nipples and brake fluid. Will post back when I go through with this. Hopefully should sort it.
Thanks guys.
The last post was made 13 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 47.51 Kb
