brake reservoir top up
donniemateno
PostPosted: 08:57 - 04 Jun 2012    Post subject: brake reservoir top up Reply with quote
i went to top up my brake reservoir as the brake felt a little spongey
i went to undo the bolts to remove the reservoir cap only to find they have already been rounded by previous owner as they have been sprayed pink! as well
i am just wondering where to go from this?
either to buy a new reservoir unit from somewhere
or drill the old lid off and find some new bolts
Current bike: Honda CBR 600 F3
Previous bikes: Honda XR 125L5 , BMW 800 ST, Honda CB500
Hetzer
PostPosted: 09:07 - 04 Jun 2012    Post subject: Reply with quote
Bolts? Confused They should be flat-headed screws.
If they're screws try super-gluing something of the same size to their tops and twisting on that, you never know.
anthony_r6
PostPosted: 09:14 - 04 Jun 2012    Post subject: Reply with quote
Start with a small drill bit and go down the center of the bolt. Get slightly larger until the screw caves in, or just drill the head off (be careful not to bore into the plastic) and it should just slide off the top. Those screws won't be hard to find.
c_dug
PostPosted: 09:24 - 04 Jun 2012    Post subject: Reply with quote
Impact driver is your friend.
Hetzer
PostPosted: 09:26 - 04 Jun 2012    Post subject: Reply with quote
On a resevoir? I think not.
c_dug
PostPosted: 09:33 - 04 Jun 2012    Post subject: Reply with quote
I suppose maybe not the brightest idea Laughing
You can get small impact drivers that are designed for that kind of thing though, not that I've ever seen one in a shop.
PostPosted: 11:02 - 04 Jun 2012    Post subject: Reply with quote
If it is a combined master cylinder and reservoir of metal construction then an impact driver would be my first choice.
Failing that drill the heads off the bolts and the cap will lift off, then you can use mole grips to remove the remains.
The bolts almost certainly have a countersunk head.
Hetzer
PostPosted: 11:06 - 04 Jun 2012    Post subject: Reply with quote
Good luck with that. Laughing
If it doesn't take a spanner (by design) it's not a bolt, it's a screw.
PostPosted: 11:09 - 04 Jun 2012    Post subject: Reply with quote
Worked many times in the past. Zero chance that gluing anything to the bolt head will work, and any other method is far more destructive.
Casper
PostPosted: 11:51 - 04 Jun 2012    Post subject: Reply with quote
Used an impact driver myself a few times with no trouble. I tend to change the screws for allen bolts now and keep them clean.
kestrel
PostPosted: 12:02 - 04 Jun 2012    Post subject: Reply with quote
Same here. One of the first jobs i do on any bike i get is replace all fluids. If the reservoirs have screws in the top i always replace them with stainless countersunk socket screws plus a dab of coppaslip.
Isle of Man.........Road Racing Capital Of The World
PostPosted: 12:50 - 04 Jun 2012    Post subject: Reply with quote
Untrue, although there are loads of different definitions of what is a bolt and what is a screw.
Hetzer
PostPosted: 15:34 - 04 Jun 2012    Post subject: Reply with quote
Go on then, define a bolt and explain how it's different to a screw.
brythered92
PostPosted: 16:04 - 04 Jun 2012    Post subject: Reply with quote
if possible at all hacksaw the exposed part of the head on the bolt then flat head to get them out
r6 99 quill pipe ....
PostPosted: 16:24 - 04 Jun 2012    Post subject: Reply with quote
Main one appears to be that a bolt goes through to be secured on the other side with a nut while a screw just goes in, screwing into the piece.
Nick 50
PostPosted: 16:43 - 04 Jun 2012    Post subject: Reply with quote
File 2 edges either side of the bolt to fit a spanner on to.
Walloper
PostPosted: 18:49 - 04 Jun 2012    Post subject: Reply with quote
If you top up then you will have to mop up if you change the pads later.
Check the pad wear.
Brake systems have enough fluid in the reservior to complete a full wear cycle. If not below the Low level leave it.
If spongy then there is a brake syatem problem low level will not cause a problem unless it is empty.
donniemateno
PostPosted: 13:48 - 05 Jun 2012    Post subject: Reply with quote
i am looking to top up because from what i can see there is no fluid in the reservoir! it looks empty i cant find out until the cap is off. the pads are looking very thin as well
but anyway the heads of the screws on the cap are torx counter sunk
they are neither 10 nor 15 their a happy medium which i dont have Sad and since the previous owner looks to have tried to remove them already they arent really 15 now
i am thinking i might have to go with the drill option to take the heads off and then replce the bolts
dodgydog
PostPosted: 14:28 - 05 Jun 2012    Post subject: Reply with quote
Bolts are threaded part way up the shank. Screws (or set screws) are threaded all the way to the head, either bolt or screw may be hex, allen, torx or whatever.
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
flumpy7
PostPosted: 14:35 - 05 Jun 2012    Post subject: Reply with quote
IF it genuinely is empty then you will have sucked air into the system my friend and topping up will not suffice you will need to rebleed.
2012 Sinnis apache
EazyDuz
PostPosted: 14:37 - 05 Jun 2012    Post subject: Reply with quote
Dont think the brakes would work at all if its empty
PostPosted: 15:34 - 05 Jun 2012    Post subject: Reply with quote
That seems to be one of the definitions (and goes along to an extent with the definition of a bolt as 'an externally threaded headed fastener, which is used in conjunction with a nut')
donniemateno
PostPosted: 06:45 - 07 Jun 2012    Post subject: Reply with quote
i took a measurment of the pads today and they are very thin to say the least....0.6 mm of thread
i will buy some off ebay ( and not sue the bike as the brakes are unbelieveably crap now , Rear brake is good though ) and im probably going to buy a new brake lever / reservoir assembly as well as i have noticed when i apply the front brake my brake light wont go out unless i push the lever forward and i can see what looks like a small switch which is just hanging and when i push it back with my finger it just pops back out and moves around quite freely. it isnt "located"
im just hoping i can find a assembly all in one as the ones i found on ebay are for cb400 etc
after a bit of research its a brake lever stop switch which would fix this problem not a new lever.....doh!
donniemateno
PostPosted: 14:12 - 16 Jun 2012    Post subject: Reply with quote
finally had a chance to look at the reservoir again!
anyway i tried a hex head socket to undo one of the bolts and just spun
so I'm guessing the best bet as mentioned before will be for me to just drill these out and get the remaining thread out with mole grips?
just a quick question does anyone know what size thread the new bolts/screws will need to be?
otherwise my bike won't be in use for a bit while i look for some Razz
any help mcuh appreciated
Raffles
PostPosted: 19:53 - 16 Jun 2012    Post subject: Reply with quote
I'd guess that the screws will be M4 and probably be 12mm in length.
The last post was made 14 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 132.45 Kb
