No spark 2009 Sinnis Stealth 125
kramdra
PostPosted: 17:53 - 04 Jun 2012    Post subject: No spark 2009 Sinnis Stealth 125 Reply with quote
I just got a bike for my brother to learn on, it was cheap and wont start, but other than that is in good condition. Its been sitting outside for a year. chain is rusted to fuck.
What size chain does it use? 428 x ?
It turns over and can smell fuel in exhaust.
got the spark plug out, and it wont spark.
1) it turns over with the kill switch in either position? is this normal for a chinky bike?
2) No spark from HT lead.
3) multimeter reads 1v on the coil terminals. I was expecting 12v, but it might be too short for my meter to pick up?
I should probably check the grounds, most electics work, no indicators or horn tho.
does this bike have points or eleccy timing? what should I check if the coil is fine...
There is also some worrying grinding ? marks on the forks and front brake hoses, I think they must have rubbed...
nowhere.elysium
The Pork Lord
PostPosted: 19:11 - 04 Jun 2012    Post subject: Reply with quote
It'll most likely be CDI, as opposed to points ignition.
From what I remember of my Chinese thing, the killswitch stops it from sparking, not turning over, so I'd have the switchgear apart, and check the state of the contacts. I've been inside Chinese switchgear before, and it's not very complicated, so don't worry about getting confused when you've got it apart; it's really, really simply laid out.
kramdra
PostPosted: 21:27 - 04 Jun 2012    Post subject: Reply with quote
thanks Ill try that.
Noone knows about chain/spark plug? type
dungbug
PostPosted: 00:38 - 05 Jun 2012    Post subject: Reply with quote
These are based on the Suzuki GS/GN gubbings I believe, is there a switch on the side stand? If it's been outside the connections might be crusty (?)
CBT: Pass 25/06/2011 Theory Test: Pass12/06/2012 Mod 1: Fail 08/07/2012
Mod 1 Retest: Pass 15/0702012 Mod 2: Pass 03/08/2012
Suzuki GN125 (Sold) ~ Current bike: Yamaha YZF 600R Thundercat
Robby
Dirty Old Man
PostPosted: 11:19 - 05 Jun 2012    Post subject: Reply with quote
No indicators or horn points at a flat, or very low, battery. Quite possibly not helped by a corroded terminal or 10 somewhere.
Charge the battery overnight, or hook it up to a decent (car or bike) battery. If that doesn't make much difference, clean up the earthing points. Start at the battery and work forwards. If there is an earth from the battery negative to the frame, this is the most likely one to be a problem.
kramdra
PostPosted: 18:45 - 05 Jun 2012    Post subject: Reply with quote
Nah using a car battery... the orginal was flat and cant find my charger.
I checked most of the grounds. Havent opened up the headlight yet, but I think most of the wiring and switch gear are gone. I will be rewiring it next week but want engine running first...
Piccy below, not bad for £200 Smile
Moxey
PostPosted: 18:57 - 05 Jun 2012    Post subject: Reply with quote
Another vote for the CDI, had a Vonroad 125 scoot gifted to me from a mate and turned out to be the CDI that had gone kaput seems to be a point of fault on chinky bikes.
kramdra
PostPosted: 21:49 - 05 Jun 2012    Post subject: Reply with quote
The coil terminals are both getting +12?
No change on multimeter when trying to start.
Kill switch is good.
Most of the wiring looks good tho... need a diagram Sad
bought a new spark plug, NGK CR8EIX (iridium was only a quid more), but its missing the bloody screw in bit on cable end Sad
humanbeing
PostPosted: 05:29 - 06 Jun 2012    Post subject: Reply with quote
The chance of this ??? is very low BUT it's possible.
kramdra
PostPosted: 00:05 - 07 Jun 2012    Post subject: Reply with quote
pulse generator is going to be the next thing I test. if its fine ill buy a new CdI....
Any suggstions where I can buy one? went into dealership today and no stock of chain... but the cock muncher refused to tell me what size it needs, so fuck them.
humanbeing
PostPosted: 06:06 - 07 Jun 2012    Post subject: Reply with quote
kramdra wrote:
...went into dealership today and no stock of chain... but the cock muncher refused to tell me what size it needs, so fuck them.
Known as Qingqi QM125-2D from maker. Stock = https://www.jtsprockets.com/catalogue/model/3949
Don't know the history, previous owner may F***ed "stock".
the "fool" method. Determinate it's 428 or 520 https://www.kmcchain.com/tw/business_units.php?act=view&id=1 1st , then count the the links by urself.
The Suzi EN125-2A service manual (in Spanish) had details how to test the CDI. Mr. Green https://www.4shared.com/office/Y8LWA4la/
TGB This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
PostPosted: 18:01 - 09 Jun 2012    Post subject: Reply with quote
TGB wrote:
side stand cut out switch is most likely stuck in. follow the wires back to its connection point and disconnect. its a common fault i often offer customers the option to remove it because of this fault.
Usually stops it turning over though.
PostPosted: 18:22 - 09 Jun 2012    Post subject: Reply with quote
TGB wrote:
usaly it would but on the ones i sell the side stand cut out does not stop it from turning over. but either way its worth checking out.
So you fiddle with the bikes? Laughing
kramdra
PostPosted: 09:48 - 10 Jun 2012    Post subject: Reply with quote
it was the sidestand switch. thanks.
she runs! can't get a chain today wemoto is shut Sad
other than that, the wheels don't turn very freely. no play in wheel so not sure if bearings rusted or brakes binding...
needs new brake fluid tho, rear brake has a poo.brown colour to it.
should I change fork oil? bike almost 3 years old.
TGB interested in doing the brakes and forks? two things I can't really be fucked with myself.
TGB This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
dungbug
PostPosted: 11:07 - 14 Jun 2012    Post subject: Reply with quote
Good news fella, I suggested the side stand switch as my GN had the same problem. Glad she's running, seems a good buy for £200! Thumbs Up
There is a gap of 2 years, 340 days between these two posts...
jamie.ray1984
PostPosted: 14:18 - 20 May 2015    Post subject: SINNIS STEALTH 125 2009 Reply with quote
Hi I am hoping someone could give me some advice, I have the above bike and am getting no spark, have replaced wiring loom as was in a bad state, new ignition coil, new cdi unit. still no joy. I have looked at the side stand switch but it seems that it has been cut off and there are no wires to trace back to the loom. Its driving me crazy trying to figure it out. Thanks for any advice jamie
kramdra
PostPosted: 22:38 - 20 May 2015    Post subject: Re: SINNIS STEALTH 125 2009 Reply with quote
There should be a pair of bullet connectors dangling down under the left plastic, they need to be plugged together for bike to spark (switch should be open with stand down).
It should not be removed.. if its dodgy replace with one from a proper bike. It is very easy to ride off with the side stand down Laughing
The last post was made 11 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 108.37 Kb
