CPI 50 SM Starting problems
Redbullracer
PostPosted: 13:29 - 03 Jun 2012    Post subject: CPI 50 SM Starting problems Reply with quote
Just wondered if anyone on here could help me out. My nephew has a 2009 CPI 50 SM with 600 miles on the clock. The problem is that when you try to start the bike with the electric start the engine locks up when it tries to fire. Then if you try to start it with the kick start the engine fires in to life for about 1 - 2 seconds then stalls. I tried on a different carb with a manual choke but just got the same result I have also fitted a new spark plug with no luck. I'm wondering if it could be the stator or cdi unit that might be causing the problem.
Any help would be much appreciated.
Taught2BCauti...
PostPosted: 12:02 - 05 Jun 2012    Post subject: Reply with quote
Will it start and run from a push?
Check the ignition timing - something may have slipped.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
shippy
PostPosted: 19:48 - 05 Jun 2012    Post subject: Reply with quote
Has the bike been de-restricted?
Redbullracer
PostPosted: 01:12 - 08 Jun 2012    Post subject: Reply with quote
Bike won't start with a push and it's standard. I removed the flywheel and checked the stator to see if it could be adjusted but it seems that it wont adjust so the timing seems to be set at a fixed position. The cdi unit must control the timing.
shippy
PostPosted: 15:50 - 09 Jun 2012    Post subject: Reply with quote
_Iain_ wrote:
Or he's messed about with it, trying to "swop dem jetz boii" to go faster
It definately sounds like the bike is running way too rich and flooding everytime. I had a similar problem with my old motocross bike by putting too much oil in with the fuel and with the same outcome Doh!
Riding faster than everyone else only guarantees you'll ride alone.
TGB This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
The last post was made 14 years, 111 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 53.63 Kb
