2 stroke help please
luckatme85
PostPosted: 12:23 - 11 Jun 2012    Post subject: 2 stroke help please Reply with quote
hi guys new to the forum so please be gentle.
i own a 1994 ts125r and lost all compression whilst out yesterday, im gunna go take the head off today when rain stops,
my question is though, when i was riding it it always lost power and started to slow down whenever i hit the top 2 gears, it was like it was gunna die on me. if i changed down 2 it would accelerate straight back up into the powerband but as soon as i chnage back up same would happen again, could this have been due to low compression? or could it have been a powervvlve problem?
any help much appreciated
thanks in advance lee
TGB This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
woodie
PostPosted: 13:49 - 11 Jun 2012    Post subject: Reply with quote
sounds more like valve or carb to me .
PostPosted: 13:54 - 11 Jun 2012    Post subject: Reply with quote
TGB wrote:
the suzuki TS125 wow havent seen one of those for a log time. right three things to look at ignition the dreded top end rebuild and of course crank seals.
top end: in most cases a new barrel and piston wil be needed. but as its just a steel barrel you can rebore it with ease and fit an over size pistion.
ignition timing: if you are unlucky you will have points and so setting up is a pain. but booking it in to a workshop will cost you no more than £30 + VAT + PARTS
crank seals: when you have the head, barrel and pistion off. fill the crank mouth with diesel and leave it for a few hours. if the level has not droped your fine. if it has the new seals are needed. but these are easy to fit. just remove the flywheel coils ect. screw into the seal a self tapping screw and pull it out then drift in the new one. as for the other side you will need to drain the oil remove the clutch cable, gear lever and then the clutch cover now you will need to remove the clutch it self then behind that is the other crank seal. and you remove that and refit the same way as the other side. when your done refit in reverse order.
thats the quick way. but if your in doubt seek the help of a pro like my self.
Mr Pro.
You sure its sensible to advise a n00b on the internet to fill his crankcase with diesel? Seriously?
First thing I'd do, absolute first thing is to check the spark plug and make sure its not too coked up. I'd then check the spark from the plug and make sure its a nice strong blue spark. Then I'd do a compression test and see if the engine is within tolerance. If it is, then I'd look at the carb, I'd probably take it off and take the float bowl off to look for debris, and clean out the jets.
If the engine is low on compression then it could probably do with a new piston and rings. I'd take the barrel off and inspect and measure it. If it is clean, round and not worn, I'd just change the piston and rings.
I certainly wouldn't be messing around filling the engine with diesel.
luckatme85
PostPosted: 15:08 - 11 Jun 2012    Post subject: ts Reply with quote
right guys top end is off and it is buggered, the exhaust port is very thin, the rings have seized solid to the piston and the barrel is scored, only slightly but tbh with the exhaust port as it is top end is rendered useless anyway.
the cause of the seizure to me looks like overheating, this was proved when i removed top end because no water came from main hose as it should when removed.
tbh the engine looks like its had a hard life and not really been taken care of as most 125 2t are these days by learners. it has had restrictor removed from exhaust and probably just thrashed to within a inch of its life by spotty 17 year olds who know nothing, all the ports are carboned up and the exhaust is more like a old coal fire chimney.
someone mentioned that my bike (1994 ts125r) has a steel barrel but when i took it off it looks like it is a nikosil lined barrel?
if it is im sure it would be cheaper and easier just to source a decent 2nd hand barrel off a ts or a rg, i know one of the rg's is the same engine but am not sure which one.
while the engines in bits like it is im just gunna do the crankseals anyway for peace of mind, i also would like to find out which wire it is to derestrict it, not because i want to derestrict it but because i want to re-restrict it, sounds daft maybe to some people but its always gunna be less reliable as a higher power bike so would just like it a bit more reliable, reliable 2t i hear you say? maybe i am kidding myself a bit but nvm.
thanks for advice so far guys it is very much appreciated and if anyone could point me in the right direction of a new barrel in good nick that would be very much appreciated aswell
thanks again lee
PostPosted: 15:27 - 11 Jun 2012    Post subject: Re: ts Reply with quote
thanks again lee
If its going to be reliable it will be reliable at full power. A good thrash now and again clears them of carbon deposits. Two strokes like to be thrashed.
If I were you I'd try honing the barrel and seeing if the scoring is any better. if not I'd go for a re-bore and a new piston and rings. Don't touch the crank seals unless they need doing.
I'm not sure if the TS125 barrel is nikasil plated or steel liner, but if its steel I'd definitely rebore it rather than look for a s/h barrel because it will be dead easy and give you a quality result. If you buy a secondhand barrel it could also be scrap for all you know.
If its nikasil then you can get them replated, but it might be cheaper to source a s/h barrel. You've still got the chance that it is scrap but the risk is more worth it in that case because of the cost and hassle of Nikasil plating.
luckatme85
PostPosted: 15:35 - 11 Jun 2012    Post subject: ts Reply with quote
i get what you are saying bout the barrel but the ports on my original are shagged so a new barrel is the only way i think?
luckatme85
PostPosted: 16:31 - 11 Jun 2012    Post subject: ts Reply with quote
well ive just been to 2 of my local bike shops and both say the barrel is shagged and the barrel is nikosil lined so. do i try source a new barrel a good 2nd hand one or do i just get this one re-plated and fit a new powervalve? becuase my old powervalve is shagged too, a piece of it was stuck in the exhaust port.
can anyone tell me which other barrel may fit because im having no luck finding one for my model bike. if it was a/c then yeah i can get 10 top ends but for my model nope none.
thanks lee
PostPosted: 16:41 - 11 Jun 2012    Post subject: Reply with quote
Nikasil can be repaired, but sometimes cheaper to just grab a new barrel.
Was for my RS anywho Laughing
luckatme85
PostPosted: 17:23 - 11 Jun 2012    Post subject: ts Reply with quote
right heres some pics show you all the damage lol
https://i.imgur.com/KbEhA.jpg
https://i.imgur.com/RTOB6.jpg
https://i.imgur.com/rbqFw.jpg
https://i.imgur.com/pI878.jpg
https://i.imgur.com/SXMNL.jpg
https://i.imgur.com/dAK98.jpg
https://i.imgur.com/XQUrC.jpg
so does anyone think this barrel can be saved?? i think not but theres a lot of you that know a lot more than i do
thanks
Ivor-Byke
PostPosted: 17:30 - 11 Jun 2012    Post subject: Reply with quote
barrel just needs a nikasil replate decoke the ports and new piston and powervalves, jobs a gud un
luckatme85
PostPosted: 19:38 - 11 Jun 2012    Post subject: ts Reply with quote
well after talking to a mate and explaining everything he thinks that i should be able to get the exhaust port welded with aluminium and as the barrel isnt damaged other than port that will sort it
im not sure myself
how much will it be to get it replated roughly as i cant find a 2nd hand barrel anywhere
thanks
PostPosted: 19:48 - 11 Jun 2012    Post subject: Reply with quote
Replate will be a bit over £100 (you will need gaskets, piston, etc, on top of that).
I can't really see in your pics, but if the actual bore is scored it will need replating. Damage can be welded up before it is replated.
PostPosted: 19:51 - 11 Jun 2012    Post subject: Reply with quote
The ports look good to me...
GrumpyGuts
PostPosted: 20:01 - 11 Jun 2012    Post subject: Reply with quote
On my old '76 two stroke, the fuel petcock was corroded which was preventing fuel reaching the engine at high revs. I thought it was the condenser and points, but no it was that!
Worth checking your fuel lines whilst you're at it!
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
luckatme85
PostPosted: 20:12 - 11 Jun 2012    Post subject: ts Reply with quote
the fuel flow is fine if you look at the powervalves in the picture that was my problem not fuel starvation.
the only port thats not ok is the exhaust port which is very thin so am gunna take it to a local 2t tuner and see if he can do anythng with it or reccomend anyone that can
i plan on getting a new piston, rings and gaskets etc but getting the barrel sorted is top of my priority list right now as without that everything else is useless.
also does anyone know which rg barrel will fit?
thanks again lee
stevo as b4
PostPosted: 20:16 - 11 Jun 2012    Post subject: Reply with quote
I'd be almost certain that your cylinder can be saved, with a re-plate and maybe welded if required. £120 odd should cover the cost of the work and then £50-70 for a new piston, rings, small bearing and gasket set etc.
I wish i has pics of my KMX200 barrel to show you, as there are some really deep gouges in the bore, where the piston broke up and jammed in the ports. I've shown it to a couple of bike mechanics who have said it's definately repairable, so yours should be too!
I think you need to be more worried about the state of your powervalves, as if they are like the RGV250 ones and they should be, being a related to the RG125FUN and RGV250, then they seem to have serious reliability issues. Personally to justify the cost of an all new top end, id want to buy a set of the special aftermarket one piece valves as insurance really. I can't remember who makes them, but Stan Stephens talked about them in one of his CMM tuning articles recently. I think they are £100+, but look very nicely made and should stop the problem occuring that Suzuki unfortunately never managed to fix.
With the potrs all de-carbonised and cleaned and a de-coked expansion chamber and re-packed silencer, you should have all of the 20 something bhp back and it be reliable as well as pokey.
The bike that has the similar cylinder to yours is the RG125FUN, but the barrel and head do look slightly different so both might be needed, and the porting is definately different between the bikes as is the carb size. Yours has a 27mm TMX Mikuni, and the RG a TM30SS carb i think.
MaybeGuy
PostPosted: 20:56 - 11 Jun 2012    Post subject: Reply with quote
I've seen worse bores re-used with no incidents. I'd just replace the piston and rings, and leave it at that.
Ignore the ''pro'', he's a 'tard. His defence will be something like ''mer mer do it properly'' etc etc, but on a bike that's only worth a few hundred quid, you're a fool to spend the value of the bike getting it running, when you can get away with a £20 piston.
The bridge on the port within the bore is the important part. If that's fine, then I'd just leave it. if not, then unfortunately it needs to be done.
luckatme85
PostPosted: 21:10 - 11 Jun 2012    Post subject: ts Reply with quote
well have you seen the pic of the centre of exhaust port?
do you think that would be ok?
ive run worse on a old kx but this is my daily road legal ride
The last post was made 13 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 2.94 - MySQL Queries: 13 - Page Size: 140.07 Kb
