| luckatme85 |
 luckatme85 Borekit Bruiser
| TGB |
 TGB Two Stroke Sniffer
| woodie |
 woodie Derestricted Danger
| MarJay |
 MarJay But it's British!
| luckatme85 |
 Posted: 15:08 - 11 Jun 2012 Post subject: ts |
right guys top end is off and it is buggered, the exhaust port is very thin, the rings have seized solid to the piston and the barrel is scored, only slightly but tbh with the exhaust port as it is top end is rendered useless anyway.
the cause of the seizure to me looks like overheating, this was proved when i removed top end because no water came from main hose as it should when removed.
tbh the engine looks like its had a hard life and not really been taken care of as most 125 2t are these days by learners. it has had restrictor removed from exhaust and probably just thrashed to within a inch of its life by spotty 17 year olds who know nothing, all the ports are carboned up and the exhaust is more like a old coal fire chimney.
someone mentioned that my bike (1994 ts125r) has a steel barrel but when i took it off it looks like it is a nikosil lined barrel?
if it is im sure it would be cheaper and easier just to source a decent 2nd hand barrel off a ts or a rg, i know one of the rg's is the same engine but am not sure which one.
while the engines in bits like it is im just gunna do the crankseals anyway for peace of mind, i also would like to find out which wire it is to derestrict it, not because i want to derestrict it but because i want to re-restrict it, sounds daft maybe to some people but its always gunna be less reliable as a higher power bike so would just like it a bit more reliable, reliable 2t i hear you say? maybe i am kidding myself a bit but nvm.
thanks for advice so far guys it is very much appreciated and if anyone could point me in the right direction of a new barrel in good nick that would be very much appreciated aswell
thanks again lee |
| Vincent |
 Vincent Banned
 Posted: 15:18 - 11 Jun 2012 Post subject: |
| Vincent |
 Vincent Banned
| MarJay |
 Posted: 15:27 - 11 Jun 2012 Post subject: Re: ts |
| luckatme85 wrote: | right guys top end is off and it is buggered, the exhaust port is very thin, the rings have seized solid to the piston and the barrel is scored, only slightly but tbh with the exhaust port as it is top end is rendered useless anyway.
thanks again lee |
If its going to be reliable it will be reliable at full power. A good thrash now and again clears them of carbon deposits. Two strokes like to be thrashed.
If I were you I'd try honing the barrel and seeing if the scoring is any better. if not I'd go for a re-bore and a new piston and rings. Don't touch the crank seals unless they need doing.
I'm not sure if the TS125 barrel is nikasil plated or steel liner, but if its steel I'd definitely rebore it rather than look for a s/h barrel because it will be dead easy and give you a quality result. If you buy a secondhand barrel it could also be scrap for all you know.
If its nikasil then you can get them replated, but it might be cheaper to source a s/h barrel. You've still got the chance that it is scrap but the risk is more worth it in that case because of the cost and hassle of Nikasil plating. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| luckatme85 |
| Blau Zedong |
 Blau Zedong Banned
| TGB |
| luckatme85 |
| P.addy |
 P.addy Red Rocket
 Posted: 16:41 - 11 Jun 2012 Post subject: |
Nikasil can be repaired, but sometimes cheaper to just grab a new barrel.
Was for my RS anywho  |
| luckatme85 |
 Posted: 17:23 - 11 Jun 2012 Post subject: ts |
| Ivor-Byke |
 Ivor-Byke Borekit Bruiser
| Vincent |
 Vincent Banned
| luckatme85 |
| MarJay |
| GrumpyGuts |
 GrumpyGuts World Chat Champion
| luckatme85 |
| stevo as b4 |
 Posted: 20:16 - 11 Jun 2012 Post subject: |
I'd be almost certain that your cylinder can be saved, with a re-plate and maybe welded if required. £120 odd should cover the cost of the work and then £50-70 for a new piston, rings, small bearing and gasket set etc.
I wish i has pics of my KMX200 barrel to show you, as there are some really deep gouges in the bore, where the piston broke up and jammed in the ports. I've shown it to a couple of bike mechanics who have said it's definately repairable, so yours should be too!
I think you need to be more worried about the state of your powervalves, as if they are like the RGV250 ones and they should be, being a related to the RG125FUN and RGV250, then they seem to have serious reliability issues. Personally to justify the cost of an all new top end, id want to buy a set of the special aftermarket one piece valves as insurance really. I can't remember who makes them, but Stan Stephens talked about them in one of his CMM tuning articles recently. I think they are £100+, but look very nicely made and should stop the problem occuring that Suzuki unfortunately never managed to fix.
With the potrs all de-carbonised and cleaned and a de-coked expansion chamber and re-packed silencer, you should have all of the 20 something bhp back and it be reliable as well as pokey.
The bike that has the similar cylinder to yours is the RG125FUN, but the barrel and head do look slightly different so both might be needed, and the porting is definately different between the bikes as is the carb size. Yours has a 27mm TMX Mikuni, and the RG a TM30SS carb i think. |
| Vincent |
 Vincent Banned
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 20:56 - 11 Jun 2012 Post subject: |
I've seen worse bores re-used with no incidents. I'd just replace the piston and rings, and leave it at that.
Ignore the ''pro'', he's a 'tard. His defence will be something like ''mer mer do it properly'' etc etc, but on a bike that's only worth a few hundred quid, you're a fool to spend the value of the bike getting it running, when you can get away with a £20 piston.
The bridge on the port within the bore is the important part. If that's fine, then I'd just leave it. if not, then unfortunately it needs to be done. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| luckatme85 |
The last post was made 13 years, 340 days ago. Instead of replying here, would creating a new thread be more useful? |
