no spark cg125
blackbird-1100
PostPosted: 21:56 - 11 Jun 2012    Post subject: no spark cg125 Reply with quote
no spark on my cg125
bike was running great up untill a wire had dried out on the ignition barrel black/white wire had came of, so i got a new barrel put that on and since then i have no spark.
ignition wires are in the right way my old ignition was on, on my old ignition barrel there was a black wire that was snipped of and never been used, and everything was working right with out that wire.
when the ignition is off i have a negative feed from the coil but when ignition is on i have no feed.
from either side of the points i have 2 negatives.
im just a bit confused why there is a negative feed from the coil,
any advice would be great many thanks
cb1rocket
PostPosted: 23:27 - 11 Jun 2012    Post subject: Reply with quote
check the ignition switch, its quite likely to be the culprit as it has to be coming from that end.
Are the wires connected up properly and to the correct colours?
cb1rocket
PostPosted: 23:28 - 11 Jun 2012    Post subject: Reply with quote
oh and the negative feed is what kills the spark when you turn off. That how they work, there is no negative feed when running/on position
blackbird-1100
PostPosted: 07:38 - 12 Jun 2012    Post subject: Reply with quote
update
i am now getting a negative feed from the coil pack weather the ignition is off or on, ignition is working correctly when turning it on it cuts the negative feed from the coil. so the coil is getting a negative feed from some where else any ideas ??
cheers
cb1rocket
PostPosted: 09:26 - 12 Jun 2012    Post subject: Reply with quote
kill switch? check contacts
blackbird-1100
PostPosted: 16:17 - 12 Jun 2012    Post subject: Reply with quote
it hasnt got a kill switch on it
cb1rocket
PostPosted: 21:20 - 12 Jun 2012    Post subject: Reply with quote
your getting a negative feed somewhere which is grounding to the frame where it shouldn't
disconnect the switch wire one by one and kick start it and see what happens.
Yes the ignition switch on these are a crap design by the way.....
Usher4566
PostPosted: 22:07 - 12 Jun 2012    Post subject: Reply with quote
If you unplug it compleatly it will start off kick or bump start.if u need it going
New cd200 benly owner
Walloper
PostPosted: 09:17 - 13 Jun 2012    Post subject: Reply with quote
WTF is a 'Negative Feed' on a DC circuit?
The last post was made 14 years, 91 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 57.37 Kb
