| yambabe |
 yambabe World Chat Champion
 Posted: 21:26 - 04 Jun 2012 Post subject: Cleaning Brakes |
Would appreciate your advice please, this is re my "summer" bike, a Suzuki VS800. Due to inclement weather and some health issues it's barely moved in a year , and in the autumn as per usual it was coated in ACF50/WD40 to protect against the winter corrosion.
It's now out and been hosed off and polished, but I have an issue with the front brake. Basically it's crap, I barely have one, and each time I use it I'm seeing a sort of gooey yet dusty film form on the disc. Have tried cleaning this with what I had to hand (degreaser basically) and been out and done several miles of a-road "speed up, nothing behind, big handful of front" in the hope that usage might burn it off but it's barely made a difference if I'm honest.
Do these brake-cleaner sprays work? Cos I'm thinking if I have to take the brakes to bits to clean them properly I might as well treat it to a new set of pads anyway......
Advice and opinions would be welcome please!  ____________________ Sod falling in love, I wanna fall in chocolate.  |
| Pete. |
 Pete. Super Spammer
 Posted: 21:46 - 04 Jun 2012 Post subject: |
Brake cleaner is little more than a very high powered solvent, so if you have any oil-based product on the disc it will wash that away. ____________________ a.k.a 'Geri'
| andym |
 andym World Chat Champion
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 12:19 - 07 Jun 2012 Post subject: |
As above, brake cleaner is a very volatile solvent, it rinses away any oil and then evaporates without leaving a residue. If you happen to have access to any other similarly volatile solvents (pure ethanol, isopropanol etc) then you can use them instead.
How much meat do the pads have left? The workshop answer is that you probably don't fancy chancing hard braking on a defective brake system , new pads and cleaning the discs with a decent solvent will sort it out.
Do you know what the oily residue is? Check to make sure that it isn't brake fluid leaking out as that could explain both the contamination and the shite brakes.
| Hetzer |
 Hetzer Super Spammer
| MarJay |
 MarJay But it's British!
 Posted: 12:33 - 07 Jun 2012 Post subject: |
Brake cleaner is both good and bad.
Good, because it can clean discs and brake calipers without leaving a residue.
Bad because its rather toxic, and if exposed to temperatures above about 300 degrees C, turns into a nasty gas which eats your lungs.
To be honest Jo, if I were you I'd loosen the pad retaining pin(s), remove the caliper, remove the pads, give it a thorough clean, examine the pistons for corrosion and look for leaks, then re assemble with red rubber grease on the sides of the pistons (after removing any corrosion with fine emery paper or a soft wire brush). Then I'd push the pistons back into the caliper, fit new brake pads and re-assemble. Check the braking system works then take it for a test ride if all is OK. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| DrDonnyBrago |
| MarJay |
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:08 - 07 Jun 2012 Post subject: |
| MarJay wrote: | | DonnyBrago wrote: |
 when exactly will it be exposed to 300 degrees C?
I know, some idiot on the internet used it to cool down a weld that he had done. |
Amazingly, it wasn't Warped, but when he reads about it I'm damn sure that he'll claim to have welded some baking soda into anthrax.
OT, I use acetone, isopropanol or whatever other degreaser that I happen to have handy, then sluice down with water. ____________________ Biking is 1/20th as dangerous as horse riding.
| DrDonnyBrago |
 Posted: 14:31 - 07 Jun 2012 Post subject: |
I didn't realise someone had actually almost killed themselves with it.
Nasty! |
| MrPink |
 MrPink Derestricted Danger
| yambabe |
 Posted: 22:04 - 11 Jun 2012 Post subject: |
https://i12.photobucket.com/albums/a229/Yambabe/pads.jpg
Thanks for all the advice everyone.
Seals were fine, no fluid leaks, problem was caused by the above!
New pads fitted yesterday, MOT duly passed today and much less chance of me rear-ending someone now.........  ____________________ Sod falling in love, I wanna fall in chocolate.  |
| Pete. |
 Pete. Super Spammer
 Posted: 23:39 - 11 Jun 2012 Post subject: |
Those pads were just about naked anyway, best thing you could have done was change them. ____________________ a.k.a 'Geri'
The last post was made 14 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
