| Usher4566 |
 Usher4566 Spanner Monkey
| TGB |
 TGB Two Stroke Sniffer
| Usher4566 |
| von1papen |
 von1papen Spanner Monkey
 Posted: 14:11 - 13 Jun 2012 Post subject: |
From someone who has just rebuilt the top end of a cm200, I can tell you now the cam chain is a pain in the hole!
There is bugger all play in the chain so we found you had to lift one link at one end of the cam sprocket and carry this on like a mexican wave until the other end, moving the sprocket round by one tooth, continue doing this till cam assembly and sprocket are in the correct position! (with the wee cut out facing the 3 o'clock position)
Removing it in the first place isn't too bad, like I said its just getting the correct timing that is annoying when you've put it back together because of the lack of room to work and tight tolerances.
I throughly advise getting a 6 sided socket for the 12mm nuts that hold the rocker assemblies on, they can round off easily because they're torqued down plus they hold the whole top end together more or less.
If you find the edges are in any way beginning to sheer off on the nut when using a 12 sided standard socket for the love of the lord, STOP. (someone had done this to one of the nuts in my engine)
However, it is all worth it! I rebored the barrel, fitted oversize pistons and lapped the valves and she now runs beautifully  |
| Usher4566 |
 Posted: 16:38 - 13 Jun 2012 Post subject: |
| von1papen wrote: | From someone who has just rebuilt the top end of a cm200, I can tell you now the cam chain is a pain in the hole!
However, it is all worth it! I rebored the barrel, fitted oversize pistons and lapped the valves and she now runs beautifully  | sound advise thanks but as for timings is it just set to 3? ____________________ New cd200 benly owner |
| von1papen |
| Usher4566 |
| von1papen |
| MarJay |
 MarJay But it's British!
| Usher4566 |
The last post was made 14 years, 103 days ago. Instead of replying here, would creating a new thread be more useful? |
