cam chain benly
Usher4566
PostPosted: 07:26 - 13 Jun 2012    Post subject: cam chain benly Reply with quote
In the next couple of mounths I may have a go at top end on my benly .the question is how do I go about the timing chain ? How do I get it se right when put all bck together?
New cd200 benly owner
TGB This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Usher4566
PostPosted: 10:28 - 13 Jun 2012    Post subject: Reply with quote
It's a benly not a NASA rocket shit I don't need speacail tools
von1papen
PostPosted: 14:11 - 13 Jun 2012    Post subject: Reply with quote
From someone who has just rebuilt the top end of a cm200, I can tell you now the cam chain is a pain in the hole!
There is bugger all play in the chain so we found you had to lift one link at one end of the cam sprocket and carry this on like a mexican wave until the other end, moving the sprocket round by one tooth, continue doing this till cam assembly and sprocket are in the correct position! (with the wee cut out facing the 3 o'clock position)
Removing it in the first place isn't too bad, like I said its just getting the correct timing that is annoying when you've put it back together because of the lack of room to work and tight tolerances.
I throughly advise getting a 6 sided socket for the 12mm nuts that hold the rocker assemblies on, they can round off easily because they're torqued down plus they hold the whole top end together more or less.
If you find the edges are in any way beginning to sheer off on the nut when using a 12 sided standard socket for the love of the lord, STOP. (someone had done this to one of the nuts in my engine)
However, it is all worth it! I rebored the barrel, fitted oversize pistons and lapped the valves and she now runs beautifully Very Happy
Usher4566
PostPosted: 16:38 - 13 Jun 2012    Post subject: Reply with quote
sound advise thanks but as for timings is it just set to 3?
von1papen
PostPosted: 00:50 - 14 Jun 2012    Post subject: Reply with quote
Theres a wee cut in section in the cam assembly rod end (best way I can think of describing it) that must be at the 3 O'clock position when the pistons are at TDC, ensuring that they open and close at the right times! The Haynes manual is invaluable
Usher4566
PostPosted: 06:06 - 14 Jun 2012    Post subject: Reply with quote
so if I look in the timming there is a mark for top dead centre yea
von1papen
PostPosted: 15:06 - 14 Jun 2012    Post subject: Reply with quote
There is a 'T' mark for TDC when you taken the points cover off, you can see it through a small aperture, you'd use it when setting the valve clearances!
Once this is set you then have to get the cam assembly cut out in the right place by moving the chain along the sprocket till it sits in the right position at TDC
Manual will explain/show it better than I can
PostPosted: 15:14 - 14 Jun 2012    Post subject: Reply with quote
TGB wrote:
cam chains are not a job for the amiture home diy. as these cam chains run through the centre of the two cylinders. and is too technical to explain in words over the forum and the tools needed are complex. so my advice is have a pro do the job.
Plenty of people on here have done camchains on plenty of bikes. It is not that hard, and on a Honda Benly it should be relatively straightforward.
I'm not a professional mechanic, yet I've rebuilt forks, rear ends, brakes, top ends and the like. Plenty of amateurs on here have done gearboxes, bottom ends etc etc. Its not rocket science.
Usher4566
PostPosted: 16:17 - 14 Jun 2012    Post subject: Reply with quote
Thanks yea seems strait forward
The last post was made 14 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 65.17 Kb
