ER5 - Handlebar shake
goto10
PostPosted: 22:38 - 13 Jun 2012    Post subject: ER5 - Handlebar shake Reply with quote
I've noticed my ER5 has developed a handlebar shake when I loosen my grip.
Anyone have any ideas what might be to blame?
Suntan Sid
PostPosted: 06:22 - 14 Jun 2012    Post subject: Reply with quote
Head bearings, would be the most likely source.
You need to look at tyre wear as well, not necessarily the front tyre. Any damge to the wheels themselves? Tyre pressures?
Least likely is front suspension, fork seals ok, correct amount of oil?
I'd put my money on head bearings though, see if it makes any difference if you re-grease and nip the bearings up a bit, if that solves your problem then I'd be looking at replacing them.
CaNsA
PostPosted: 07:43 - 14 Jun 2012    Post subject: Reply with quote
Front wheel might need balancing again.
The weights fell off mine and the same thing happened.
w650
PostPosted: 18:06 - 14 Jun 2012    Post subject: Reply with quote
Same problem occured on myW650. Front tyre wear was the culprit.
Easter Bunny
PostPosted: 18:41 - 14 Jun 2012    Post subject: Reply with quote
Front tyre wear!
The last post was made 14 years, 105 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 42.64 Kb
