| Itxi |
 Itxi Scooby Slapper
 Posted: 07:38 - 15 Jun 2012 Post subject: One problem after another (CG problems) |
I try not to post too much on this board but I'm needing some help with this one.
The CG (6V model) has been standing for a month and a half as I've been cleaning and lining the tank. I also took the opportunity to clean the carbs and lube the chain. (Plus a few other cosmetic things).
The bike ran well before (apart from the carb clogging with rust from the tank ) started fine as I'd put new points in it at the end of last year. But now it's not starting and doesn't seem to spark (Held the plug against the engine and turned it over, didn't see or hear a spark).
Does anyone know what could have deteriorated within that month? The engine hasn't been touched and it's been kept under a cover outside, the battery is most likely flat but it should start without one. |
| stocksmenace |
 stocksmenace Scooby Slapper
| Itxi |
 Itxi Scooby Slapper
| Ichy |
 Ichy World Chat Champion
 Posted: 08:40 - 15 Jun 2012 Post subject: |
I'm assuming it is kickstart? The GS I had use to be a pain to start unless the battery had 'some' charge. I think the neutral light drained whatever the generator kicked out
Is it possible that you may of dislodged a wire to or from the coil when you moved the tank? ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| Itxi |
 Itxi Scooby Slapper
 Posted: 08:59 - 15 Jun 2012 Post subject: |
Charging the battery may help then, I'll look into that.
It's possibly I knocked a wire loose as well, hadn't thought of that.  |
| tomh |
 tomh Scooby Slapper
| Itxi |
 Itxi Scooby Slapper
| shadesofglory |
 shadesofglory L Plate Warrior
| Itxi |
 Itxi Scooby Slapper
 Posted: 16:52 - 16 Jun 2012 Post subject: |
Fuel is flowing well now, better than it was  |
| Robby |
 Robby Dirty Old Man
The last post was made 14 years, 156 days ago. Instead of replying here, would creating a new thread be more useful? |
