cylinder flooding
Kawksam
PostPosted: 12:06 - 17 Jun 2012    Post subject: cylinder flooding Reply with quote
got bike back from garage and have messed with it,
the carb is letting too much fuel into cylinder and not starting wetting plug is this an easy fix
they also removed fuel filter and scratched exhaust and left fuel hose bung off letting rain in to side casing and carburretor.
Found the cause of the kawks running problems before this, crank seals have gone.
lihp
PostPosted: 12:14 - 17 Jun 2012    Post subject: Reply with quote
Take it back to them?
Kawksam
PostPosted: 12:34 - 17 Jun 2012    Post subject: Reply with quote
don't trust them, enough damage as it is and had to get RAC break down to take me home.
to adjust it will there be an adjuster screw for the mixture setting.
GrumpyGuts
PostPosted: 13:02 - 17 Jun 2012    Post subject: Reply with quote
On the carb where the throttle cable it attatched there should be a screw where you can adjust the amount of fuel that goes into the engine.
https://www.youtube.com/watch?v=J8ikzcaMWg0
That should help
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
lihp
PostPosted: 13:04 - 17 Jun 2012    Post subject: Reply with quote
It would also be helpful to know what bike it is. Wink
Kawksam
PostPosted: 14:09 - 17 Jun 2012    Post subject: Reply with quote
its a kawasaki kh100 ex 1990
do i need a manuel to find the right setting
GrumpyGuts
PostPosted: 15:32 - 17 Jun 2012    Post subject: Reply with quote
Here is an eBay link to a Haynes manual
Normally you can adjust the screw until it nearly cuts out, then adjust it until it "sounds right", typically around 1,500-2000 RPM
Kawksam
PostPosted: 16:36 - 17 Jun 2012    Post subject: Reply with quote
I got a manuel but has disappered in the house some where.
is there a different screw for mixture and then idle
GrumpyGuts
PostPosted: 17:17 - 17 Jun 2012    Post subject: Reply with quote
Mixture would be your choke...i.e. choke on for more fuel (only for cold starts) and off for normal.
The throttle cable is attachted to your idle screw.
Rob W
PostPosted: 17:22 - 17 Jun 2012    Post subject: Reply with quote
Do you have even the remotest clue what your talking about?
Rob W
PostPosted: 17:28 - 17 Jun 2012    Post subject: Reply with quote
If you have no idea what your talking about, it's best just to not say anything.
temeluchus
PostPosted: 17:49 - 17 Jun 2012    Post subject: Reply with quote
Check whether it is oil or fuel wetting the plug.
If it is definitely petrol, there are a few things to check:
The choke cable and piston are in good nick and move freely
The adjustment of the float and condition of the float needle
Condition of the various gaskets around the carburettor
Condition of the idle circuit and that the idle screw isn't badgered
Air filter is clean and in good condition
If it is over oiled you will need to check the adjustment of the oil pump. I've not seen the guts of a two stroke in many years, someone on here will be able to help with this I'm sure.
temeluchus
PostPosted: 17:52 - 17 Jun 2012    Post subject: Reply with quote
I do love how if you want to hear the most unreliable outrageous bullshit in the motorbike world you only have to listen to people talk about small two strokes!
Kawksam
PostPosted: 18:04 - 17 Jun 2012    Post subject: Reply with quote
is fuel wetting plug, found manuel now so should be easier.
temeluchus
PostPosted: 18:22 - 17 Jun 2012    Post subject: Reply with quote
Carburettor will most likely need a general overhaul.
Look at getting a gasket set and a replacement float needle/seat.
Don't scrimp on the carburettor-it will only cause you grief!
Kawksam
PostPosted: 18:40 - 17 Jun 2012    Post subject: Reply with quote
carb was fine before that bleeding pikey started faffing with it,
might be just mixture setting sorted.
temeluchus
PostPosted: 18:45 - 17 Jun 2012    Post subject: Reply with quote
Set the idle screw from 1 1/2 turns out if memory serves.
Kawksam
PostPosted: 19:07 - 17 Jun 2012    Post subject: Reply with quote
ok thanks for that I will see how I go tomorrow and try and not get to mad at it, once that and crank seals and bearings done it will be a nice little bike.
The last post was made 14 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 96.25 Kb
