R6 intermittantly cutting out
ozzy r6
PostPosted: 11:14 - 17 Jun 2012    Post subject: R6 intermittantly cutting out Reply with quote
my 03 5SL R6 keeps cutting out when dropping down to idle its intermittant some days it does it some days it doesn't, it will restart straight away but will just cut out again if allowed to drop to idle, if i leave it for ten minutes its fine again.
anyone had this before??
yamaha r6 5sl
lihp
PostPosted: 12:16 - 17 Jun 2012    Post subject: Reply with quote
Check over your fuel and air filters. Also check your throttle bodies are balanced
Fizzer Thou
PostPosted: 12:41 - 17 Jun 2012    Post subject: Reply with quote
When were the shims last checked?
There are only 16 to check - a lot easier than the 20 on the early R1s Wink
Also - check to make sure that the plugs are clean and the plug caps resistance are within spec - normally between 5-10k ohms.I have had one break down when hot and the internal resistor goes open circuit.
Always have a 'Plan B'
ozzy r6
PostPosted: 15:05 - 17 Jun 2012    Post subject: Reply with quote
i have checked and checked the air filter and fuel lines
i have also changed the spark plugs and coil packs as i got a misfire about 2 months ago
mine is the injection model, are the throttle body know to come unbalanced on these i will check the shims. cheers
yamaha r6 5sl
lihp
PostPosted: 15:11 - 17 Jun 2012    Post subject: Reply with quote
They still have to be balanced to ensure all 4 cylinders are working equally and in synch with each other. How many miles are you on?
ozzy r6
PostPosted: 15:14 - 17 Jun 2012    Post subject: Reply with quote
18000 now
yamaha r6 5sl
lihp
PostPosted: 15:17 - 17 Jun 2012    Post subject: Reply with quote
Check shims and throttle body balance would be my first point of call
The last post was made 14 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 16 - Page Size: 52.02 Kb
