Where is Earth?
fatjames
PostPosted: 16:01 - 18 Jun 2012    Post subject: Where is Earth? Reply with quote
Following on from this mornings discussion. Does anyone know where all of the frames earths are on vx 535 Virago?
FJ
P.
PostPosted: 16:18 - 18 Jun 2012    Post subject: Reply with quote
On the frame
:troll:
cb1rocket
PostPosted: 17:14 - 18 Jun 2012    Post subject: Reply with quote
follow the negative lead from the battery...... that goes to earth, ie the frame
fatjames
PostPosted: 08:30 - 19 Jun 2012    Post subject: Reply with quote
Yeah, I did that. I thought there was more than one point on the frame. Embarassed
Alpha-9
PostPosted: 08:38 - 19 Jun 2012    Post subject: Reply with quote
https://geographyandhistory.wikispaces.com/file/view/solar-system.jpg/43342111/552x434/solar-system.jpg
HTH Thumbs Up
Fzr-600 1999
fatjames
PostPosted: 09:32 - 19 Jun 2012    Post subject: Reply with quote
Alpha-9 wrote:
HTH Thumbs Up
I styled the title for this, you took your time!
Bezzer
PostPosted: 10:22 - 19 Jun 2012    Post subject: Reply with quote
There is often more than one main type earth lead, one usually bolts to an engine mount then there could be another somewhere higher up on the actual frame usually under the tank area.
fatjames
PostPosted: 10:57 - 19 Jun 2012    Post subject: Reply with quote
Thank you. I think I'll have to take a bit more time over this and "properly" check the whole wiring loom. The last thing I want is to damage a new reg/rec.
cb1rocket
PostPosted: 12:46 - 19 Jun 2012    Post subject: Reply with quote
depending on the reg/rec. If it has an earth lead that should be connected to the frame, then wire it straight to the battery if so
The last post was made 13 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 58.38 Kb
