buy a torque wrench
Meshuggah
PostPosted: 16:56 - 18 Jun 2012    Post subject: buy a torque wrench Reply with quote
I will need it on my Fazer to change the front sprocket, real wheel nut and so on. From what I come to understand there isn't one that goes all the way from 10 nm to 150nm which is the range that covers all the possible tightening setting on my bike. I also don't wanna spend a fortune. so I've decided to go for this one https://www.amazon.co.uk/Draper-30357-Micrometer-Adjustment-Torque/dp/B0001K9S52/ref=sr_1_2?s=diy&ie=UTF8&qid=1340034688&sr=1-2
do you have any suggestions for other products or anything else? any advice is welcome Smile thanks
Triumph Tiger 800 2012
PostPosted: 17:10 - 18 Jun 2012    Post subject: Reply with quote
I have a very similar one.
I got an expensive one for small stuff and a cheap one for big stuff on the basis that a 10% error on 7ft/lb can mean a snapped or loose bolt but a 10% error on 140ft/lb is less of an issue.
IanF
PostPosted: 20:46 - 18 Jun 2012    Post subject: Reply with quote
The trouble with torque wrenches is that they are less accurate at the extremes of their range. So the best thing is a few that have overlapping ranges.
Slacker24seve...
PostPosted: 21:12 - 18 Jun 2012    Post subject: Reply with quote
I have that very one. Its decent enough.
Having said that, for a front sprocket I'd have just gone for 'pretty fucking tight' and left it at that.
Banger rallies are ace
GSTEEL32
PostPosted: 21:17 - 18 Jun 2012    Post subject: Reply with quote
This one also gets a vote from me, I've used mine for a couple of years no problem.
Saying that, I only ever use it on engine parts. I have to agree with the above post...... when it comes to wheel nuts, they tend to get the old "whole body weight plus hammer when required" treatment....
Dazbo666
PostPosted: 21:20 - 18 Jun 2012    Post subject: Reply with quote
I have a very similar one for about the same price. Mine is Clarke branded, from Machine Mart Thumbs Up
(Only used it 3 or 4 times in the last couple of years, but at least it's there when I need it)
Word of the day : DILLIGAF
map
Mr Calendar
PostPosted: 21:29 - 18 Jun 2012    Post subject: Reply with quote
Have to say my small one is a Draper as well. Does most of the stuff around the bike with exception of the wheels.
I was advised that if I could to try before I buy. Ideally see if can put in vice and test that you're happy with the break/click. Even different models of the same wrench can have a different feel.
The last post was made 14 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 53.16 Kb
