| sgtcalle |
 sgtcalle Spanner Monkey
| iooi |
 iooi Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 19:11 - 19 Jun 2012 Post subject: |
You need a solid state flasher relay. To pass the MOT your indicators must flash at a rate of between once a second and once in two seconds. ____________________ a.k.a 'Geri'
| ZebraDriver |
 ZebraDriver Scooby Slapper
| Llama-Farmer |
 Llama-Farmer World Chat Champion
| Pete. |
 Pete. Super Spammer
| sgtcalle |
| map |
 map Mr Calendar
 Posted: 21:07 - 19 Jun 2012 Post subject: |
You need to do a search as I'm sure the information is there.
IIRC the relay switch is for a full LED system. For a mixed system, again from memory, you keep the original filament flasher and fit resistors in-line with your LED indicators to trick them to flash at the correct rate. I think a search will tell you what values to get for the additional electric bits.
Basically your flasher unit will be rated for a certain wattage. The filament indicator bulbs will be rated at that wattage. The LED ones will not be. So the resistors pull up the wattage to trick the electrics to work. Be careful though as the resistors will get hot.
Hope that's as clear as mud.
Maybe this is useful - from this thread... | chris-red wrote: | | Souleh wrote: | Just solder on some inline resistors (ebay) and youre done |
Buy a constant rate Flasher unit, more expensive but better than doing the above, uses less power and you wont have to hack your the wires up and create another point for it to fail. It is also simpler as it just required replacing the unit it took me about a minute to do on my bike. |
As said, do a search and some investigation.
Then you can decide on costs, ease of fitting, etc,
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| truslack |
 truslack World Chat Champion
| sgtcalle |
The last post was made 13 years, 198 days ago. Instead of replying here, would creating a new thread be more useful? |
