Removing chain
Bubbs
PostPosted: 21:41 - 19 Jun 2012    Post subject: Removing chain Reply with quote
Looking to save money on chain maintenance, I hear a lot of people remove their drive chain and soak in kerosine to get rid of the muck which I presume saves money due to the extortionate costs of muck off and the like.
Is it a pain to get the chain off or something you can learn to do really quick? Haynes gives it a 2 spanner but haynes can sometimes be a fucker for explaining things in a way that makes sense to the layman.
Also does anyone use old engine oil for lube? Or is there another alternative that splatter less.
Boring question I know, but I got's to know.
anthony_r6
PostPosted: 21:45 - 19 Jun 2012    Post subject: Reply with quote
Two ways to get the chain off. Either remove the split link, or remove the rear wheel and slide it off. I've heard of people using engine oil, I personally just use generic chain lube.
iMark
PostPosted: 21:46 - 19 Jun 2012    Post subject: Reply with quote
I just use an old paint brush with paraffin(Kerosene) while its still attached to the bike to clean it... lubing it up, I still have a cheap generic spray of chain lube, but you can use engine oil.... although it tends to fling off quite easily Sad
Soaking it over night in paraffin will mean you need to let it completely dry inside too, then soak it again in oil to make sure its lubed up properly afterwards
K8 GSXR 1000
Drake
depends on if your using a split link or a rivet link
DrDonnyBrago
PostPosted: 21:52 - 19 Jun 2012    Post subject: Reply with quote
Your Kwak will almost certainly have a rivet link and an O ring chain which makes removal of your chain something you only really do when it is due to be replaced.
Get a bowl of paraffin and an old paint brush - does the trick nicely as the bristles are too soft to damage the O rings and the brush holds loads of paraffin to rinse the grime out, soaking an O ring chain in paraffin wouldn't really achieve anything that a brush and bowl wouldn't. Paraffin can be had in B+Q, homebase etc, sold as outdoor lamp fuel for about £5 for 4L.
As for reoiling, I dry the chain with a rag or leave it to dry (paraffin evaporates, albeit slowly) and reoil with gear oil on a rag. If you don't put too much on it doesn't fling and gear oil is a bit thicker than engine oil which also helps.
GREENI3
PostPosted: 21:57 - 19 Jun 2012    Post subject: Reply with quote
You can clean it with it still on the bike you know?
Obviously not as good as if you removed it, but even so.
Just go over it with a toothbrush and paraffin, then wipe it down with a rag.
Leave the paraffin to evaporate overnight, before applying any lubricant.
I use 80-90w gear oil for lube.
Slap it on with a cut down paint brush on the bottom run of the chain, then wipe off the excess.
I used to use that wurth dry chain lube, but didn't think it did anything and had absolutely no corrosion resistance properties whatsoever.
Costs about £8 for a 500ml can and only used to get about 4 uses out of it.
Gear oil cost £3.69 for a 1 litre bottle and I've used barely any of it after about 10 uses.
It's more viscous than engine oil, so you'll get less fling off on the rear tyre.
Honda recommend using gear oil in my owners manual, so it must be good.
Bubbs
PostPosted: 22:05 - 19 Jun 2012    Post subject: Reply with quote
Ah cool, I'll continue to clean without removal then. Thanks for the advice. Thumbs Up
flumpy7
PostPosted: 22:12 - 19 Jun 2012    Post subject: Reply with quote
I use scottoil for lubing... with or without a scottoiler - just paint it on. Its not so flingy as engine oil and really easy to clean off.
2012 Sinnis apache
Jersum
PostPosted: 22:15 - 19 Jun 2012    Post subject: Reply with quote
Apparently it's a good idea to clean out the small sprocket housing so you don't get loads of crap on the chain as soon as you start riding.
Full Licence acquired December 2011.
1st bike Honda CG125 '04 in silver, 2nd Suzuki Bandit 600S '96 Very Happy
Derivative
PostPosted: 22:17 - 19 Jun 2012    Post subject: Reply with quote
On my CG it was pretty trivial to get the rear wheel off, though I suppose your ZX6 is likely to not have a centre stand.
On the centre stand, the bike naturally balanced itself on the front wheel, unbolt the rear, take off the sprocket casing (does this have a better name?), pull the chain off without having to split it.
I tend to think that it's only worth doing very occasionally though. Chains are expensive, but not so expensive as to faff about taking wheels off every month just to save a little bit on wear. Get a brush and some sort of solvent while it's on the bike, done.
GREENI3
PostPosted: 22:19 - 19 Jun 2012    Post subject: Reply with quote
How would you go about doing this?
I've got about 11 years worth of oil caked on the inside of the sprocket cover, but is a pain in the backside to wipe off.
Would a good soak in paraffin do the job?
PostPosted: 22:21 - 19 Jun 2012    Post subject: Reply with quote
Derivative wrote:
On my CG......pull the chain off without having to split it.
You trolling?
I prefer smaller cc because you can just use the split link rather than remove the whole rear wheel etc
map
Mr Calendar
PostPosted: 22:26 - 19 Jun 2012    Post subject: Reply with quote
iMark wrote:
... lubing it up...you can use engine oil.... although it tends to fling off quite easily Sad...
Some people believe in being green and re-use old engine oil as chain lube. However old engine oil is a known carcinogen (as in causes cancer) so some caution is required.
Agree with above posts. Only remove chain when you have to.
Derivative
PostPosted: 22:35 - 19 Jun 2012    Post subject: Reply with quote
##Paddy## wrote:
You trolling?
Well, taking the rear wheel off my CG took all of 5 minutes, and that was the first (and only) time I'd done it. No rear disc, centre stand holds bike, it is basically an unbolt and pull job.
I cleaned everything else while I was at it.
bikertomm
PostPosted: 22:42 - 19 Jun 2012    Post subject: Reply with quote
OP, I don't know!
What I can reccomend is that S.Doc 100 white chain cleaner that was only a quid not long ago.
Mine came the other day and I've just done my chain and been for a 60 mile hoon with virtually no fling off!
There's about 8 dots on my numberplate, can't notice anywhere else!
Get some of that once you've soaked it Thumbs Up
truslack
PostPosted: 22:55 - 19 Jun 2012    Post subject: Reply with quote
You cant take the chain off without splitting it unless you take the swingarm out...
Bubbs
PostPosted: 22:59 - 19 Jun 2012    Post subject: Reply with quote
Only reason I ask about chain removal is because quite a few people say they soak their chain in paraffin oil, looking at the chain it won't come off with just the rear wheel, looks like quite a few bits need to come loose to do it. But I'll stick with the same method only using paraffin instead.
Need to buy a frigging paddock stand now too as mother in law managed to loose the parts that prop the bike up.. My paddock stand is now a paddock paper weight. Rolling Eyes
Anyone got a spare they want to sell me?
Bubbs
PostPosted: 23:00 - 19 Jun 2012    Post subject: Reply with quote
Mr Haynes concurs with you.
Derivative
Not on my M1.
I may have had to remove a rear shock, it was a while back though.
truslack
PostPosted: 23:05 - 19 Jun 2012    Post subject: Reply with quote
Are you trolling or just stupid? The engine is in front of the swingarm, the chain goes above and below the swingarm. how could you possibly remove an endless chain that is round the swingarm without removing the swingarm itself?
Derivative
PostPosted: 23:09 - 19 Jun 2012    Post subject: Reply with quote
Perhaps you are talking about the ZX6, whereas I'm talking about a CG?
I was responding to Paddy's post, it is much simpler on naked 125's that weigh virtually nothing and have centre stands. Which is annoying, because the chains are worth much less to bother cleaning in the first place.
TamaJosh
PostPosted: 23:13 - 19 Jun 2012    Post subject: Reply with quote
I've always just oiled my chain. My ninja 250 has a small grille near my left foot where the gearbox sprocket is so you can see it. Looks like it might be easy to remove (from memory, not actually looking at it now) or at least squirt a hose into it to clean out the crap before oiling the chain.
Not oiled my ninja chain yet (it's new so haven't had the chance) but did on my old cbf by rotating the wheel on it's centre stand. Sportsbikes don't normally have a centre stand as far as I know but I guess you could just oil a bit, roll the bike forward and oil a bit more and repeat...
Avoid HASTINGS DIRECT SCUM
https://www.bikechatforums.com/viewtopic.php?t=235369
Just doing my bit Smile
truslack
Sorry, all the CG's I've ridden had a normal swingarm and chain arrangement, yours must be different. Rolling Eyes
DrDonnyBrago
PostPosted: 23:14 - 19 Jun 2012    Post subject: Reply with quote
With the rear wheel out and rear shock off, you can remove the chain from a CB250 without removing the swingarm.
It is not a common thing to be able to do though, most bikes cannot. Thumbs Up
Derivative
PostPosted: 23:21 - 19 Jun 2012    Post subject: Reply with quote
https://i108.photobucket.com/albums/n39/mredgey/bike/20100920-left.jpg
Fair enough if they're not mostly like this. Mine is the odd Brazilian one.
I hope it's fairly obvious from the photo that I'm not trying to be awkward.
Very Happy
The last post was made 14 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 129.24 Kb
