crank case breather
Usher4566
PostPosted: 21:33 - 20 Jun 2012    Post subject: crank case breather Reply with quote
Hi peps just woundered if any body could clarify this I have a thick black pipe coming off crank case ime guessing its a breather and is not ment to be connected to any thing ?
New cd200 benly owner
Fizzer Thou
PostPosted: 00:31 - 21 Jun 2012    Post subject: Reply with quote
From what I remember when I rebuilt my CD200T there was a big bore pipe that came from the top of the crankcase that pulsed with the engine running.On my CB125T2 that I am rebuilding at the moment this pipe goes up onto a connector on the bottom of the airbox,but on the 200 it was not connected to anything.
Always have a 'Plan B'
Casper
PostPosted: 00:34 - 21 Jun 2012    Post subject: Reply with quote
Some connect back to the airbox. Age of your bike i would say it just hangs out the back.
Usher4566
PostPosted: 07:09 - 21 Jun 2012    Post subject: Reply with quote
Hi thanks for both your replys .did your 200 run fine with it loose
Usher4566
PostPosted: 07:15 - 21 Jun 2012    Post subject: Reply with quote
also when u rebuilt the 200 did u replace the carb manifold gasket if so where did u sorce one .also carb rubber
Usher4566
Fizzer Thou
PostPosted: 09:55 - 21 Jun 2012    Post subject: Reply with quote
I did check the inlet manifold gasket and it was in reasonable condition so I added a thin smear of Hylomar just to be on the safe side.As for the rubber between the airbox and the carb this quite flexible so was reused.
Usher4566
PostPosted: 10:18 - 21 Jun 2012    Post subject: Reply with quote
Ok many thanks
reckless_b
PostPosted: 11:53 - 21 Jun 2012    Post subject: Reply with quote
the breather usually connects to the air box, down stream of the air filter, if yours is like this then either reconnect the breather pipe or blank off the stabbing in the air box, screws up mixture and/or runs very lean otherwise
40 years on the road on and sometimes off bikes with a very recent OFF
Usher4566
PostPosted: 12:38 - 21 Jun 2012    Post subject: Reply with quote
So I should look for hole in air.box or connecting pipe yea ?
Usher4566
PostPosted: 12:39 - 21 Jun 2012    Post subject: Reply with quote
And if I can't find one its ment to be not connected yea ?
Usher4566
PostPosted: 12:45 - 21 Jun 2012    Post subject: Reply with quote
the breather isn't ment to be blocked with bung
Usher4566
PostPosted: 13:02 - 21 Jun 2012    Post subject: Reply with quote
Usher4566 wrote:
Ok many thanks
also when you done your rebuild did you find one single gasket on carb inlet or two o rings .David silver spares say two o rings ?
reckless_b
PostPosted: 13:37 - 21 Jun 2012    Post subject: Reply with quote
the breather isn't meant to be blocked I said on the air box the breather pipe spigot can be blocked and the breather pipe left open, although I prefer to fit a filter either to the end of the breather pipe or direct onto the crank case, but if there is a connection on the air box feel free to fit your breather pipe to that
von1papen
PostPosted: 16:01 - 21 Jun 2012    Post subject: Reply with quote
In a full gasket set you get a gasket for between the carb and the heatshield, a gasket between the heatshield the the manifold, and two O rings for each of the manifold legs that connect to the engine if that makes sense?
Usher4566
PostPosted: 16:44 - 21 Jun 2012    Post subject: Reply with quote
Ok thanks guys I've just ordered two o rings for inlet legs and one gasket that goesbefore heat sheild all they do .but can't get repkacment heat sheild any idears ? Still got problem where revs take a little while to drop .
The last post was made 13 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 86.34 Kb
