| Acemastr |
 Acemastr World Chat Champion
| salty21 |
 salty21 World Chat Champion
 Posted: 22:49 - 25 Jun 2012 Post subject: |
i've been playing with my suspension on my 600rr-5 over the course of about 2 months and i pretty much have it as i want it now. Not sure how you like your bike set up to feel but your welcome to try my settings if you want, even if it doesnt suit you it will probably be a good base to work from.
Just noticed you say you weigh 60kg, which is about 9st 4lbs, are you annorexic  ____________________ 04 NSR 125(sold) ---- 03 CBR 600rr(sold) ----90 pan euro ST1100 ' ' ----02 CG 125
94 CB400 Super Four ---- 2000 VTR SP1 (sold) ---- 08 ninja p8f(sold, meh) ----05 CBR600rr  |
| Acemastr |
 Posted: 22:59 - 25 Jun 2012 Post subject: |
If you could lob those over that'd be appreciated.
My biggest issue is stopping the bloody bars from slapping, hit a bump mid corner and the front wiggles all over, I've now gotten rid of the wiggles but i've sacrificed slow speed and overall lean angle.
**Edit** and yes, weight is a difficult thing to put on  ____________________ 2017 KTM 350 XC-F - 2014 Yamaha R6 - 2005 Yamaha YZ125
2016 Toyota Tacoma Limited |
| Seb |
 Seb World Chat Champion
 Posted: 23:03 - 25 Jun 2012 Post subject: |
Go spend ~£30 on getting it set up by a pro, out of the box my ZX9R was an ill handling barge that dragged it's nose on the floor at the mention of a bump mid corner and and felt like the swing arm bearings had fallen out if I opened up the taps coming out of the turn.
An hour with a highly recommended guy in Exeter later and it finally steered and held a line like a fairly capable sports bike should, it honestly felt like someone had chopped 30 kilos from the front end of the bike, it really did turn in that much better.
Suspension is a pretty serious dark art and not many people can get it truly right imo  ____________________ 2010 Triumph 1050 Sprint ST |
| Acemastr |
| Seb |
| salty21 |
 Posted: 23:22 - 25 Jun 2012 Post subject: |
not really sure if these will be any use to you as i weigh close to 14 stone.
Rear preload is set to position 3
rear comp and rebound are set to default.
I did mess about with the rear shock a bit but found that standard settings felt about right.
Front preload= 2 full turns stiffer than standard
compression= 1/4 turn stiffer (clockwise) than standard
rebound= 1/2 turn anticlockwise or out from standard
might be worth changing the fork oil if it hasnt been done for a while. I did mine the other week and it felt a lot better for it. ____________________ 04 NSR 125(sold) ---- 03 CBR 600rr(sold) ----90 pan euro ST1100 ' ' ----02 CG 125
| MarJay |
 MarJay But it's British!
The last post was made 14 years, 95 days ago. Instead of replying here, would creating a new thread be more useful? |
