4'th Mod 2
Scootaloo
PostPosted: 13:10 - 27 Jun 2012    Post subject: 4'th Mod 2 Reply with quote
I have mod 2 tomorrow again for the 4th time, and am determined not to f*** it up again.
Any words of wisdom? before I blow £75 smackers.
MattJ
PostPosted: 13:11 - 27 Jun 2012    Post subject: Reply with quote
Don't fail. That way, you pass.
dungbug
PostPosted: 13:15 - 27 Jun 2012    Post subject: Reply with quote
Relax & listen to the examiner, you CAN ride a bike so just do it well. Good luck. Thumbs Up
CBT: Pass 25/06/2011 Theory Test: Pass12/06/2012 Mod 1: Fail 08/07/2012
Mod 1 Retest: Pass 15/0702012 Mod 2: Pass 03/08/2012
Suzuki GN125 (Sold) ~ Current bike: Yamaha YZF 600R Thundercat
Cuchulain
PostPosted: 13:15 - 27 Jun 2012    Post subject: Re: 4'th Mod 2 Reply with quote
What did you fail the previous 3 on?
CBT 15/6/2011 Theory Test Passed 6/2/2012 Module 1 Passed 11/6/2012
Module 2 Passed!!! 19/6/2012
Andy_Pagin
PostPosted: 13:19 - 27 Jun 2012    Post subject: Reply with quote
Usual stuff...
Turn up in plenty of time so you start off relaxed.
Treat the examiner as a satnav.
Remember to cancel indicators - double click the switch each time.
Keep well back from the car in front - the most common reason for MOD2 fails apparently.
Keep an eye out for sneaky changes in speed limits, for example there's a route near Enfield where you go from 60mph down to 30mph in a village, no problems, but as you exit the village there's a loong stretch of open road and no speed signs, very easy to convince yourself you've missed the nsl sign and pin your way to failure, only realising as you clear a bend and there's the sign saying you can finally go up from 30 to 40mph.
Finally try not to collapse in a quivering heap when the examiner casually tells you that you've passed.
PostPosted: 14:05 - 27 Jun 2012    Post subject: Reply with quote
Doesn't matter where go go, as long as you go there safely.
Scootaloo
PostPosted: 14:49 - 27 Jun 2012    Post subject: Re: 4'th Mod 2 Reply with quote
First time
Too much caution on a roundabout/holding up traffic behind the examiner.
Some observations we not quite "there"
Second time
Being a twat.
Third time
Again too much caution on a busy mini roundabout.
Being a few MPH under each speed limit.
(CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87)
Scootaloo
PostPosted: 14:51 - 27 Jun 2012    Post subject: Reply with quote
Himmm, interesting concept Thinking
guile
PostPosted: 15:32 - 27 Jun 2012    Post subject: Re: 4'th Mod 2 Reply with quote
How is that even a minor? Unless you mean you were going 20 in a 30?
Do you need to do a life-saver when turning right at a mini roundabout? It's something I would never do IRL but do these examiners want it?
Andy_Pagin
PostPosted: 15:42 - 27 Jun 2012    Post subject: Re: 4'th Mod 2 Reply with quote
Because if you do less than the limit when conditions would reasonably allow you to do so then you're impeding the progress of following traffic, also a rear shunt is more likely.
Well it can't do any harm if time permits, but I'd be surprised if it was a minor.
map
Mr Calendar
PostPosted: 15:49 - 27 Jun 2012    Post subject: Re: 4'th Mod 2 Reply with quote
Turning right on any roundabout do a left lifesaver before entry to the roundabout. More for multi-lane where someone can come inside you (ohh, err Embarassed , you know what I mean). Before exit roundabout another left lifesaver is a must. Good practice on all roundabouts except I was told treat mini ones as a junction turn (i.e. turning right indicate right with all the checks, no need to then indicate left before exit).
If you're having a lesson before your test check with instructor as they'll probably be more aware of what the local inspectors expect.
Bets of luck Thumbs Up
Scootaloo
PostPosted: 15:53 - 27 Jun 2012    Post subject: Re: 4'th Mod 2 Reply with quote
I was doing 25-30 in 30 zones and 45-50 in 50 zones.
+ one of the roundabouts was a mini one with an iland, I foolishly indicated right then left on exit straight on. it did feel a bit weird at first due to how quickly I needed indicate.
Scootaloo
PostPosted: 16:28 - 27 Jun 2012    Post subject: Reply with quote
Quick last minute question.
On a large multi-lane roundabout left is always best? unless otherwise marked out on the road.
Thank's
harscot
PostPosted: 16:30 - 27 Jun 2012    Post subject: Reply with quote
Smile Ditto to the above replies, just remember, if you can't briskly walk ( not run ) across the roundabout before a vehicle would hit you then wait for the next opening, apart from that stay relaxed and do your shoulder checks, you can never do to many ( unless your looking like your watching tennis HaHa) and it looks like your making good observations, get up to NSL speed as quickly and SAFELY as you can, be carefull around schools ect, in 20mp zones 15 to18mp is plenty and be aware of your surroundings in there, good luck next time round and stay positive.. Thumbs Up
First bike R reg Suzuki 125 GT twin in 1978:
2nd bike X reg Honda 650 Deauville in 2011:
Wish bike a Triumph Thunderbird: Dream bike Triumph Rocket........
harscot
PostPosted: 16:33 - 27 Jun 2012    Post subject: Reply with quote
Thank's
Smile Yes, unless turning right, and watch out for cork screw round abouts, there a feckin night mare, just pay attention, and you'll be ok. Thumbs Up
waffles
PostPosted: 16:34 - 27 Jun 2012    Post subject: Reply with quote
Get a good nights sleep before and make sure you have a proper brekkie on the day, none of that "I'm too nervous to eat shite". All the hard stuff is done, all you need to do now is ride around town for half an hour or so and it's job done.
map
Mr Calendar
PostPosted: 16:43 - 27 Jun 2012    Post subject: Reply with quote
Scootaloo wrote:
...On a large multi-lane roundabout left is always best? unless otherwise marked out on the road....
Best follow road lane markings if you can see them in time (i.e. not covered by traffic).
Generally if going left or straight on use left. Right then use right lane and check your left inside for other vehicles.
PostPosted: 16:52 - 27 Jun 2012    Post subject: Re: 4'th Mod 2 Reply with quote
Thinking
Are those the speeds that you were told, or the speeds that you saw on your speedo?
If the latter, is it possible that it's reading way over?
Scootaloo
PostPosted: 17:05 - 27 Jun 2012    Post subject: Re: 4'th Mod 2 Reply with quote
Rogerborg wrote:
Thinking
Speedo readings, I know its best to be bang on the speed limit but I thought being a few mph under wouldn't hurt... turns out it did!
PostPosted: 18:50 - 27 Jun 2012    Post subject: Reply with quote
Almost all speedos read over, it's a question of how much. If yours said 25, the examiners could have been saying 22 or 23.
map
Mr Calendar
PostPosted: 19:41 - 27 Jun 2012    Post subject: Reply with quote
Do examiners have to have calibrated speedo (as one police bikes)?. If they do then maybe politely asking when last calibrated if there are any more speed queries.
Having said that examiner could be using sat nav as speed indication. Thinking several million dollars of satellites versus a couple of quids worth of wire.
Would like to know the answer to the examiner calibrated speedo though Thumbs Up
Andy_Pagin
PostPosted: 21:05 - 27 Jun 2012    Post subject: Reply with quote
Examiners do their stuff all day every day, they just know.
pendulum
PostPosted: 21:28 - 27 Jun 2012    Post subject: Reply with quote
Don't go in there thinking "this is my 4th time, I've got to pass it this time", I felt like that on my car tests (I needed a fair few tests Embarassed ) and it'll just make you feel more pressured. It will happen when it happens, £75 seems a lot, but in the scheme of things it isn't. Enjoy the ride out, relax and see what happens, good luck Thumbs Up
1998 CG125 (Sold) CB500 [+ Clio 172]
Usually_Wrong: I tend to fail more than pass. [Speaking about Theory Practice]
Usually_Wrong: im on unemployment at the moment
TomGT
PostPosted: 22:10 - 27 Jun 2012    Post subject: Reply with quote
Good luck mate!
It's not really relevant but I failed my theory twice before I passed, really frustrating...
All the best for tomorrow Wink
1992 ZXR 400
Scootaloo
PostPosted: 11:10 - 28 Jun 2012    Post subject: Reply with quote
I dun did it!
Cheers everyone, your advice was invaluable!
Good luck to everyone doing their mod 1's and 2's!
If you don't get it the first... few times, just keep at it, its soo worth it.
Thanks, Scootaloo
The last post was made 14 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.94 - MySQL Queries: 13 - Page Size: 133.51 Kb
