| southpoint |
 southpoint L Plate Warrior
| koolio |
 koolio Spanner Monkey
 Posted: 16:14 - 24 Jun 2012 Post subject: More info |
Potentially could be many things, more info needed.
Did you actually remove the idle mixture screws when you cleaned the carb? You will need to do this and replace any o-rings there.
Are you running the carbs with the air filter on?
Did you check float height?
Try this:
Open the idle mixture screws fully (anti clockwise or clockwise depending on your carb), if you over open them on CV carbs for example, they also dont work so dont over do it.
Then try starting the bike without the choke if you can, you can give it some pull on the throttle while starting (but make sure you don't over do it).
When the bike starts keep it on lower revs holding the throttle slightly open, when sufficiently warm release the throttle, if the bike dies you know you have an idle system problem.
Remove the carbs and go through them again thoroughly.
This manual helps greatly for understanding:
https://wwwclassiccyclesorg.mediafire.com/?c1wk828k2wtri5i |
| nightshaddow |
 nightshaddow Nearly there...
 Posted: 16:57 - 24 Jun 2012 Post subject: |
the problem with these twins is there is 2 of everything,
2 cylinders 4 valves 2 carbs etc etc i find with mine it hates being out of balance, mine is the later tde model but is essentially the same bike.
first thing i would do with this bike is a full service, oil, plugs, valve clearances etc and as i am sure teflon mike will tell you make sure you clean the oil strainer found inside the clutch cover.
once serviced if you have one available i would balance the carbs with a carb balancer. if you dont have one i would buy one as for a garage to balance them for you would cost an hours labour which is between £35 and £50 for most garages, my balencer cost me £25
https://www.ebay.co.uk/itm/Motorcycle-Carb-Carburettor-Vacuum-Balancer-Gauge-2-Cylinder-Gauges-Balancing-/280881813602?pt=UK_Motorcycle_Parts&hash=item4165dc5862
i had helish problems with mine due to scrotes changing carb slides and all sorts so i would have a good look at all the parts and make sure it all matches up ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| Usher4566 |
 Usher4566 Spanner Monkey
| nightshaddow |
| Robby |
 Robby Dirty Old Man
| southpoint |
 Posted: 05:36 - 25 Jun 2012 Post subject: |
Thanks for replying everyone,
I stripped it down again and went through it just as I did before, reassembled it and then noticed that the fuel flow from the tank was slow- checked the petcock and spotted a load of crap had gone in there from the tank and almost blocked it, I did clean it before but obviously not good enough.
Cleaned it out swilled a gallon of petrol through the tank and put some fresh in.
Started up straight away - dammn crap in the tank had done it - ahh well I will know now to check that first.
Thanks again. |
| Robby |
 Robby Dirty Old Man
| southpoint |
| southpoint |
| koolio |
 Posted: 08:11 - 02 Jul 2012 Post subject: |
Sounds like a carb issue to me (although could be timing). Really clean out the carbs and all the jets using a very fine guitar string, make sure all the passages are super clean. Replace idle o-rings that are obviously compressed or really should get replacement.
Study a carb manual (if you haven't already) so you will exactly know what you will need to clean out to where.
This is the one I meant to show you before, its a very good source.
https://dl.dropbox.com/u/106752/Manuals/Honda/Honda_Motorcycle_Carburetion_1975.pdf
Litmus test is swapping the carbs around and seeing how the bike runs then. |
| southpoint |
 Posted: 15:53 - 02 Jul 2012 Post subject: |
Thanks Koolio - that manual is great but has made my earlier post make me look like a complete idiot LOL
I just wrongly assumed that the mixture screw was controlling fuel but it isnt is it it controls the air at idle when the sliders are down on the stops - makes far more sense now. I suppose if the seal is broken and not seating properly the left cylinder is letting too much air through which in turn draws more fuel out - hence it was running more powerfully than the right one - I am on track now or have I got it wrong again?
I suppose the way to go is to replace the idle mixture screws, seals and washer and we should be back in business again after another good clean out and reset.
Just out of curiosity on old carbs like these do you normally have to make any adjustments to the mixture screws once the carbs are back on to get some initial balance prior to vacuum balancing - tweaks - or is it normally all done via the throttle stops and the slider top screws when balancing with the vacuum guages? |
| nightshaddow |
 Posted: 16:32 - 02 Jul 2012 Post subject: |
it might be worth doing a compression test on both cylinders, no matter how much you fiddle or adjust you will never get the carbs balanced if there is something wrong with the engine,
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-snc7/418283_10150671171848846_987263031_n.jpg
these are the pistons out of mine as you see one is badly scored the other is fine. i also needed to re grind my valves as they where pitted and i had similar symptoms as you
first thing i would do is whip the rocker cover off and set the valve gaps,
next fit brand new plugs and gap them correctly, set both mixture screws the same and try to balance the carbs with the carb balancer a bit of ptfe tape will do the job till the new inserts come.
if you cant balance the carbs once you have done all this you need to look into your engine for the problem ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
| southpoint |
| blurredman |
 Posted: 09:28 - 03 Jul 2012 Post subject: |
Make sure there is no gaps in the manifolds. They can prevent a proper vaccum and can do similar to this too.
Possibly use the instagasket stuff and make a seal on the manifolds. This is 30 year old rubber/plastic. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 51k. |
| koolio |
 Posted: 17:20 - 03 Jul 2012 Post subject: |
| southpoint wrote: | Thanks Koolio - that manual is great but has made my earlier post make me look like a complete idiot LOL |
No problem glad I could have helped, it certainly helped me
| Quote: | I just wrongly assumed that the mixture screw was controlling fuel but it isnt is it it controls the air at idle when the sliders are down on the stops - makes far more sense now. I suppose if the seal is broken and not seating properly the left cylinder is letting too much air through which in turn draws more fuel out - hence it was running more powerfully than the right one - I am on track now or have I got it wrong again? |
Yes that sounds right, if the idle mixture screw seal is not good, you will not be able to idle as there is too much air and it may affect the running as a whole making it leaner on one side.
| Quote: | I suppose the way to go is to replace the idle mixture screws, seals and washer and we should be back in business again after another good clean out and reset. |
Yes exactly, but note there maybe other systems on your carb that you will need to take note of (i.e. I have an annoying air-cut valve on mine, don't ask!), I don't know your carbs unfortunately . Also make sure you clean out all the jets with a very fine soft guitar string even if visually they look ok. This is sneaky and can catch people out as there can be lose dirt lodged in them even though you can see through the jet holes, only for the dirt to clog again once fuel passes through it, i.e. especially pilot jets, slow jets.
You need to also check float heights and other standard things.
| Quote: | Just out of curiosity on old carbs like these do you normally have to make any adjustments to the mixture screws once the carbs are back on to get some initial balance prior to vacuum balancing - tweaks - or is it normally all done via the throttle stops and the slider top screws when balancing with the vacuum guages? |
Yours being an old twin if its anything like mine, what I first do is connect all the throttle cables to the carbs, then rest them somewhere on the bike so the throttle cable doesn't snag and I can see both butterflies. Then I synchronise them exactly with the cable adjuster screw so when you lightly pull on the throttle the butterflies open and close at exactly the same time and they also fully open at exactly the same time.
Then I tighten the adjuster screw nut and mount the carbs to the bike, do not be tempted to start the bike without the air filters, they must also go on. Make sure the rubber boots on both sides provide a tight seal.
Now only now are you ready to adjust the idle mixture screws, clockwise or anti-clockwise dependent on your carb type, I start by opening them very far (but obviously not too far as they stop working if they are too far out or in).
Then I start the bike the idling should be fast, I then reduce accordingly either using a manometer or putting my hands behind each pipe until pressures are balanced and idling is nice and smooth.
Then I check the bike revs and then returns smoothly to idle.
Compression test is a good idea (and what nightshaddow said), but I have a sneaking suspicion your problem lays with the carb and then a little timing. If you exhaust yourself on the carbs then check the timing, I would do this even if your compression is out on each side.
Hope this helps.
| Quote: | Make sure there is no gaps in the manifolds. They can prevent a proper vaccum and can do similar to this too. |
..and this +1 |
| southpoint |
| Usher4566 |
| Usher4566 |
| southpoint |
| Usher4566 |
| nfo |
 nfo Nova Slayer
 Posted: 20:02 - 12 Jul 2012 Post subject: |
Isn't this just due to bike gearboxes having no synchromesh? If the dogs are meeting end-on with both the main and counter shafts stationary (i.e. the rear wheel isn't turning, the clutch has been disengaged long enough for the input shaft to come to a stop), then they'll never engage. You need some relative rotary motion between the sliding gear and the gear it locks to the shaft.
Here's a photo of some Honda gearbox innards:
https://i278.photobucket.com/albums/kk83/no_bb/CB125-SML/DSCF6871.jpg
(Exploded diagram here: https://images.cmsnl.com/img/partslists/honda-cb125s-s1-usa-transmission_bighu0213e4111_8d76.gif)
You can see that on the countershaft (which is at the top), the dogs on the third and fourth cogs from the left are meeting end on, whereas to engage successfully the dogs on one need to drop into the gaps in the other.
Correct me if I'm wrong, but with the bike stopped and engine running, if you start with the clutch engaged and the box in neutral, the mainshaft will be spinning. Pull the clutch in, engage first as it spins down and both shafts will now be stationary (you've connected the mainshaft to the stationary countershaft via 1st egear). If you're lucky, the dogs on second gear will be aligned correctly, and you'll be able to shift up, if not they'll clash.
If I'm right, rolling the bike back or forward a little should allow the dogs to engage. The honda gearbox has sliding gears, I'm more familiar with a sequential gearbox where the gears don't slide and there are separate dog-rings.
Hope that makes sense, I'm thinking on my feet. ____________________ Mar's Law: Everything is linear if plotted log-log with a fat magic marker.
1975 CB125S 'repair and tidy up' project thread here... |
The last post was made 13 years, 247 days ago. Instead of replying here, would creating a new thread be more useful? |
