What's this tool?
astroscope
PostPosted: 09:17 - 06 Jul 2012    Post subject: What's this tool? Reply with quote
Hi Guys,
What is this tool he's using to cut the chain, and where to get one?
Cheers Thumbs Up
https://i1267.photobucket.com/albums/jj543/astroscope/Untitled.jpg
2010 Honda FES S Wing 125
nowhere.elysium
The Pork Lord
PostPosted: 09:19 - 06 Jul 2012    Post subject: Re: What's this tool? Reply with quote
astroscope wrote:
Hi Guys,
What is this tool and where to get one?
Cheers Thumbs Up
It's a dremel with a cutting disc. Google 'dremel', and you'll see just how universally available they are. I got the B&Q own-brand equivalent a while ago when my previous one died, and given that it was on sale for half the normal price, with a whole shedload of bits for it, I'm pretty chuffed with it. Still going strong.
Suntan Sid
PostPosted: 09:32 - 06 Jul 2012    Post subject: Reply with quote
Alternatively, buy one of these, a fraction of the cost, it'll last longer, it won't break down, and doesn't need battreries or an electrical socket!
https://span-trade.co.uk/images/uploads/file1.jpg
PostPosted: 09:33 - 06 Jul 2012    Post subject: Reply with quote
Although a chain tool would be more appropriate, quicker and more effective for that job.
PostPosted: 09:49 - 06 Jul 2012    Post subject: Reply with quote
As would one of these if it's just for breaking the chains:
https://www.toolstream.com/assets/images/products/webbig/783173.jpg
It may need electricity and is more likely to break down that Sid's suggestion; but it does make a lot more noise and sparks Very Happy.
supZ
PostPosted: 09:58 - 06 Jul 2012    Post subject: Reply with quote
thats what i use to slice through chains Smile
got a chain tool but thats more fun!
dremel would take too long and you'd probably break about 5 cutting discs doing it
CBR954RR - Daily toy
CBR600RR - Trackbike
Hetzer
PostPosted: 10:07 - 06 Jul 2012    Post subject: Reply with quote
He's not cutting the chain, he's taking the head off the rivet.
Snodvan
PostPosted: 10:20 - 06 Jul 2012    Post subject: Reply with quote
Well spotted that man. Much better way to do it.
Snod
(owner of 2 mains powered Dremel types and one rechargable battery job - would not be without them for all sorts of jobs)
04 (UK Reg) BMW F650cs, but really 02 first Reg in Holland
DrDonnyBrago
PostPosted: 11:02 - 06 Jul 2012    Post subject: Reply with quote
Once he has finished grinding the head off, he'll be using a chain breaker to press the headless rivet out. The green chain in the pic is new and needs shortening, hence the non destructive way of chain splitting.
If you are just trying to remove the old chain so you can put it in the bin and replace it, use whatever destructive method you want. Hacksaw, file, bolt croppers, gas axe, nuke it from space, death star, pray to a deity etc etc. Doesn't matter.
Hetzer
PostPosted: 11:05 - 06 Jul 2012    Post subject: Reply with quote
Or a hammer and a piece of rod, which'd be considerably cheaper.
supZ
PostPosted: 11:13 - 06 Jul 2012    Post subject: Reply with quote
in that case id just use my chain splitter Smile
had to take a link out of my trackbikes chain, didnt have to fiddle about with grinding rivet heads off, just used the tool to push it out.
Quote Me Happy
PostPosted: 11:27 - 06 Jul 2012    Post subject: Reply with quote
The chain tool I've got has two attachments to push out the pin rivets - a short strong one to push the head through the link and then a longer one just to push the rest of the pin out once there isn't much resistence.
Fizzer Thou
PostPosted: 14:08 - 06 Jul 2012    Post subject: Reply with quote
Having the right tools to do the work is the biggest part of the job.But occasionally one has to adapt to achieve.Luckily I have the right tools and shortening and rivetting a chain is normally a few minutes work.
But I have seen people in a workshop trying to use a hammer and a nail to remove the pins without grinding off the head of the pin.This happened to me when on the Isle of Man at a dealer in Ramsey.Luckily I managed to stop the 'mechanic' before he broke my plastic rear sprocket when trying to use it as a rest.I ended up having to do the job myself.
Always have a 'Plan B'
astroscope
PostPosted: 14:36 - 06 Jul 2012    Post subject: Reply with quote
thanks Thumbs Up
Just ordered this to fit in my corded drill machine.
This should sort out the rivets, right?
https://i1267.photobucket.com/albums/jj543/astroscope/Untitled-2.jpg
astro
Fizzer Thou
PostPosted: 14:48 - 06 Jul 2012    Post subject: Reply with quote
In the original picture at the top of the post it looks as though the disc is being used to cut the side plate.But then on closer scrutiny it appears that the cutting disc is being used to 'grind' off the head of the rivet.Might it not be easier to get a small grinding stone so as to do the job.
Once the head of the rivet is ground off you will still need to push out the pin so that you can seperate the unwanted links.Would it not be easier to buy a chain which is the correct length in the first place?
astroscope
PostPosted: 15:10 - 06 Jul 2012    Post subject: Reply with quote
yes, i'll be using these discs to cut off the links then use a chain press to push out the old links from the chain.
I'll use these cutting discs to cut off the extra links off the new chain, and then use the riveter to press the new links into the chain.
astro Thumbs Up
PostPosted: 15:37 - 06 Jul 2012    Post subject: Reply with quote
It's totally unecessary to grind the ends off the pins like that. A good chain tool will press the pins out.
Actually, even a crappy one will but a good one will do it more often without breaking.
baldy
PostPosted: 15:47 - 06 Jul 2012    Post subject: Reply with quote
I'm not a tool but that is. Very Happy
I always use an angle grinder on my chains. it only takes 2 seconds. it would take forever with a Dremel cutting disc.
One day i will rule the world, just not today.
fatjames
PostPosted: 17:01 - 06 Jul 2012    Post subject: Reply with quote
I bought on of the cheaper blue tools from wilko's for about £20, it's shite and the cutting discs just shatter. I have ordered some of those silverline ones though, so I'll report back...when I next need to test it.
astroscope
PostPosted: 20:02 - 06 Jul 2012    Post subject: Reply with quote
Definitely let me know on the test. Thumbs Up
Astro
PostPosted: 21:47 - 06 Jul 2012    Post subject: Reply with quote
If you really must, then Aldi are doing them on a special this week for £13
https://www.aldi.co.uk/uk/html/offers/offers_week28Sunday12.htm
astroscope
PostPosted: 11:03 - 13 Jul 2012    Post subject: Reply with quote
astroscope wrote:
thanks Thumbs Up
astro
I've given up on these. They just keep revolving around the screw and cannot cut off that small link in the chain Sad
The last post was made 13 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 131.14 Kb
